Gene Morris
Joined: 28 Sep 2006 Posts: 424 City/Region: Eureka CA
Vessel Name: Reef Madness
Photos: Reefmadness
Posted: Wed Nov 15, 2006 4:44 pm Post subject: Holding tank on tc255 |
What is the capacity of the holding tank on the tc255?
Gene Morris _________________ tight lines |
Dreamer
Joined: 01 Jan 2006 Posts: 1766 City/Region: Really Sunny SaddleBrooke
Photos: Dreamer
Posted: Thu Nov 16, 2006 1:28 am Post subject: |
Gene, If you have the toilet with integral holding tank under it, 9 gallons. Wish it were bigger. _________________ Roger
Dreamer- Sold 25 Feb. 2013 |
Posted: Sat Nov 18, 2006 6:43 pm Post subject: |
We have a Road Trek with a 10 gallon holding tank--similar capacity to the 9 gal of the TC 255 and have gone a week without dumping. We keep the water pump off for urine---and just wrinse the head bowl a couple of times a day. One of the problems with the system is that the fresh water puts in one pint of fresh water for each "Flush". This means that 8 flushes are a gallon--and 72 were a full tank--with out any waste material. _________________ Bob Austin
Discovery
Joined: 08 Dec 2003 Posts: 1245 City/Region: LOA, UTAH
Vessel Name: Discovery
Photos: Discovery
Posted: Sun Nov 19, 2006 9:03 am Post subject: |
I cut the water inlet line a few inches from the toilet and put in a ball valve. We use as little water as possible per flush. _________________
Brent and Dixie,
1984 22' Classic sold 2003
2003 24' TomCat sold 2005
2006 CD 22' Angler Sold 2014
"Free men do not ask permission to bear arms." ~ Thomas Jefferson |
Joined: 01 Mar 2005 Posts: 7484 City/Region: from island boy to desert dweller
Posted: Sun Nov 19, 2006 10:37 am Post subject: |
Along the lines of this question... what is the point of having the water pump switch on the helm panel? Every motorhome/motorcoach we've owned has the pump switch(es) by where you use the water - at the sink or by the toilet.
We also conserve water onboard by careful use of the head, and don't have the pump on for urine. Just a very short rinse afterwards (what comes out with the pump off). Then turn the pump on for a couple seconds to be ready for the next use. Then, pump off. We only turn the pump on when actually using water.
I have to say that I much prefer this head set-up compared to a seawater flush... use black tank chemical and there is no odor. We can go for days without needing a pumpout or dumping. More capacity than this, and you are hauling around unnecessary weight.
Joan says, "One thing on the boat that is full of crap is enough." Hmmm... I don't think she was talking about the head.
http://captnjim.blogspot.com/
Dora~Jean
Joined: 09 Mar 2004 Posts: 1515 City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
Posted: Sun Nov 19, 2006 11:40 am Post subject: |
Hi Jim, BTW great pics of your cruises, as someone said, gives us 'still-working-stiffs' hope!
Quote: | Along the lines of this question... what is the point of having the water pump switch on the helm panel? Every motorhome/motorcoach we've owned has the pump switch(es) by where you use the water - at the sink or by the toilet. |
I added that problem to my 'list' and last year it bubbled to the top! I bought a heavy duty switch from Radio Jap (20-25amps) with light and a 9ft 110V heavy duty Air Conditioner cord, cut both ends, wired from electrical panel back under the gunnel on inside past throttle controls and mounted under gunnel right next to the sink. VERY handy now. We turn the pump on/off for each use because mine cycles too about every 20 seconds (internal pressure leak in pump). I'll post pictures next opportunity. _________________ Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
+4 Previous, 1/2 sail, 1/2 power |
