Alasgun Guest
Posted: Sun Oct 22, 2006 4:33 pm Post subject: Honda Trim Gage question |
On the dash, we have the factory mounted trim gage and when running in perfect seas with everything optimized the pointer is WAY low. Is it possible to adjust this item to run in the center (level) position? 25 ft/ 150 Honda. No information in the recently sent out owners manual nor on the net, I suppose I could impose on the local dealer but you're a lot more fun, Thanks Mike on Huda Thunkit |
Alyssa Jean
Joined: 02 Nov 2003 Posts: 2375 City/Region: Guemes Is.(Anacortes)
Vessel Name: Alyssa Jean
Posted: Sun Oct 22, 2006 5:37 pm Post subject: |
I run my Honda 150 with the engine trim all the way down. Just seems to ride best there. Then I use the trim tabs for the rest. I am pretty sure that Pat on Daydream does pretty much the same. _________________ David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51 |
Stanley-J
Joined: 20 Sep 2005 Posts: 122 City/Region: Highland, NY
State or Province: NY
Vessel Name: Plan- B
Photos: Stanley-J
Posted: Sun Oct 22, 2006 5:40 pm Post subject: Same here |
I do the same on my twin Honda 75's. Set all the way down and fine tune to the GPS mph with the trim tabs _________________ Chuck
WA2YMF |
Dora~Jean
Joined: 09 Mar 2004 Posts: 1505 City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
Posted: Sun Oct 22, 2006 5:44 pm Post subject: |
I do the same with my twin Yami 80's, all the way down is best performance. Tried them level with the bottom of the boat (recommended by most mfrs), then adjusted my extra large trim tabs to adjust the boat's attitude, not as efficient speed-wise at same throttle position. Have no idea why, eludes logic to me. Good news though, no pressure on the hydraulic tilt mechanism when it's down against the stops! _________________ Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
+4 Previous, 1/2 sail, 1/2 power |
Grumpy Man
Joined: 21 Sep 2006 Posts: 18 City/Region: Ferndale/Sandy Point
Vessel Name: Sass Sea Lady
Posted: Sun Oct 22, 2006 11:47 pm Post subject: |
Mike;
If you have the boat out of the water and have the motor tilted all the way up you can find the trim sensor on the right side of the motor mounting bracket on the inside at about the same hight as the top mounting bolt. It is a black lever thingie that kinda rotates when the engine gets towards the bottom of its trim. You can turn the engine key to the on position and have someone watch the gauge as you move the black lever thingie back and forth to show that it is working properly. They sometimes get gummed up with salt if your boat has been out of the water for a while, so a little WD-40 and working the lever back and forth until free usually works. As for adjustment it is what it is. You can a resistors but you really don't want to go there.
Not much help but.........
Don
Sass Sea Lady
YSMB |
