fisherkb
State or Province: TX
Vessel Name: Slack Tide
Photos: C-Hunt
Posted: Tue Sep 19, 2006 10:33 am Post subject: Trash ideas |
This is a pretty mundane issue, but I am interested in any ideas that folks have for storing trash on short trips. I have been very uncreative in the past and simply brought a trash bag onboard. We try hard to minimize the trash but we still seem to end up tripping over any bag in the main cabin (which is also unsightly). I hate to sacrifice room under the sink (an obvious spot). Any clever ideas would be appreciated. |
B~C
Vessel Name: Blue~C
Photos: Blue~C
Posted: Tue Sep 19, 2006 10:45 am Post subject: |
there's a guy I know that has a 25' cruise ship that usually attends any gatherings that we go to, we just pitch our trash on his vesel early in the morning while they sleep  _________________ Ken
1999 22' boaterhome |
drjohn71a
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
Posted: Tue Sep 19, 2006 11:15 am Post subject: |
West Marine Catalog, and/or Overton's has a large, mesh bag with a mountable (via suction cups, adhesive tape, or screws) flat bracket that holds it upright with an elastic top opening so you can put wet stuff,etc, in. When fulll, you snap it off the mount and unzip the large bottom edge so all the trash falls out. One could be mounted inside and one outside. John
I am wondering if someone makes a "smasher" like the can smashers that could compact the trash by hand. |
Joined: 01 Mar 2005 Posts: 7481 City/Region: from island boy to desert dweller
Posted: Tue Sep 19, 2006 12:40 pm Post subject: |
We picked up a small (4 gallon) waste basket at Target. Heck, it's even blue and matches the boat; it's the kind with the swivel opening in the top, so you don't have to look at the garbage. When trailering, it goes in the head on our 25; otherwise it's in the cockpit. It holds 4 gallon trash bags, so when it's full we drop the bag into a dumpster in a marina or other trash can ashore. Since the 22 doesn't have a separate head, you could put it under the table when traveling. It's plastic - no rust and easy to hose out if it needs it.
As a side note, when provisioning for the boat we eliminate as much packaging as convenient and toss it before it gets to the boat... that much less trash to have to deal with onboard. Cardboard isn't a good thing in a marine environment.
http://captnjim.blogspot.com/
Joined: 02 Nov 2003 Posts: 8556 City/Region: Birch Bay, WA
Posted: Tue Sep 19, 2006 3:04 pm Post subject: |
Just one more advantage of the Airhead Composting Marine Toilet! Since there is no macerator pump, the well in the aft port area of the cockpit usually taken up by macerator is empty - a great place to store full trash bags out of sight until we can dispose of them on shore. Also, if we keep the CD25, I definitely want to remove the holding tank and put a Bomar door in for access to that area. Of course does not help the folks with either a CD22 or a standard marine head! _________________
Falco
Joined: 20 Dec 2004 Posts: 164 City/Region: Flagstaff
Photos: Bucking Coho
Posted: Tue Sep 19, 2006 4:25 pm Post subject: |
I use a large sized trash bag in a half size Rubbermaid tote. See the light blue tote under the wire shelves here:
The interim trash bin is the sink - eg while underway, etc. |
Joined: 02 Nov 2003 Posts: 21380 City/Region: Pensacola
Posted: Tue Sep 19, 2006 5:08 pm Post subject: |
You can make a manual trash compactor. Plywood box, which is of dimentions which are to your liking (best place to stow). (actually the same size as a standard trash compactor would allow use of their bags. Glass it inside and out. Make a "Compactor" which is about 1/4" less than the dimensions of the inside of the box out of 3/4" plywood, put a holder for the back of the lever on the back of the box, a tubing from the lever to the "compactor" and then as the trash recpitical fills up, "compact it"--you will get about 3x the "normal" amount in the same size container. Then double bag it in "Construction bags" until you find some place to legally dump the trash. _________________ Bob Austin
drjohn71a
Photos: Tom-a-Hawk
Posted: Wed Sep 20, 2006 11:45 am Post subject: |
We might need a compactor compactor to compact the plywood compactor! John |
Falco
Posted: Wed Sep 20, 2006 12:08 pm Post subject: |
A teenage son makes a good trash compactor so long as you provide very clear instructions and a firm deadline. |
CatyMae n Steve
Joined: 18 Jun 2005 Posts: 838 City/Region: Jefferson, OR
Vessel Name: CatyMae
Photos: CatyMae
Posted: Wed Sep 20, 2006 7:12 pm Post subject: |
I found a fabric "popup" trash can (it folds back down flat when not in use) at Wally World...works great, and it's just the right size to sit under the dinette in the corner...but large enough in the base that it doesn't tip over...holds a small 3 (I think) gallon bag. |
Joined: 07 Nov 2003 Posts: 7932 City/Region: marysville
Posted: Thu Sep 21, 2006 1:05 am Post subject: |
We just use the port lazaret. I have a battery in there so I can not use it for bait or crabs. we just have a small wire basket behind the sink with a small store bag in it . when it gets full we move it to a plastic bag in the lazaret. you can really get a lot in there. _________________ Thomas J Elliott
Bob Cat
Joined: 28 Dec 2004 Posts: 262 City/Region: Santa Monica
Vessel Name: Dive Cat
Photos: Dive Cat
Posted: Thu Sep 21, 2006 9:14 am Post subject: |
One of the biggest trash problems on multi-days trips for us has been plastic water bottles. We tried the large 2.5 gal, but the nozzle opened accidentally and dumped a gallon into a storage compartment.
Possible solution: Use larger personal bottles with secure opening and put your name on it. When finished, crush and put in small trash bag mounted on hooks inside cabinet door under sink. We recycle
the plastic bags from the supermarket for this. Put filled trash bag into big trash bag into the stb sponson forward under berth, which is a very large space on a TC255 and can hold a lot of stuff you don't need to get to too often.
Bob Cat |
Posted: Thu Sep 21, 2006 12:44 pm Post subject: |
For drinking water we use the Brita pitcher filter--and the built in water tanks. That way, no water bottles. How is the water maker working?--that will give you water which is as pure as the bottled water--you might consider a small tank for the product water, than spill over into the main tank--that way you would always have drinking water separate,plus a water source free of chlorine for back flushing. |
Dreamer
Joined: 01 Jan 2006 Posts: 1766 City/Region: Really Sunny SaddleBrooke
Photos: Dreamer
Posted: Thu Sep 21, 2006 7:48 pm Post subject: |
fisherkb, There is a catalogue from a company called Welcome Aboard where we purchased a plastic manual trash compactor. It's normal size and has a flip up handle that plunges a flat plate down into the container. being manual, it probably compresses 2:1 to 3:1 It's about $50 and well worth it. _________________ Roger
Dreamer- Sold 25 Feb. 2013 |
Cheers
Joined: 31 Oct 2003 Posts: 236 City/Region: Vancouver
Vessel Name: Cheers
Photos: Cheers
Posted: Fri Sep 22, 2006 8:08 pm Post subject: |
Roger/Dreamer - You got a web link to that Company? |
