water stains on windows
Chubby Bunny
C-Dory Year: 1998
Vessel Name: Jenny G
Photos: Jenny G
PostPosted: Tue Aug 29, 2006 7:43 pm    Post subject: water stains on windows Reply with quote
Hi all; our recently purchased 1998 22' Cruiser has a very light but uniform coat of (salt)water stains on the pilothouse windows. Certainly not worth replacing the windows but annoying nevertheless.
Anybody know a way to remove these stains? After several washings and dryings, I'm not seeing much of an improvement with plain old boat wash.
Chubby Bunny
PostPosted: Tue Aug 29, 2006 7:55 pm    Post subject: Reply with quote
Chubby Bunny-
Several solutions of varying degrees of success.
1. Easy/mild one- Try vinegar, it's weak, but will dissolve some calcium and other stains.
2. Bon Ami is next-a bit stronger and mildly abrasive. Will remove some stains.
3. The Bartenders Friend (Helper?) - very abrasive, but less so than Ajax, which will definitely scratch your windows. Be careful with the Bartender's Buddy- might scratch some things, probably not glass. Will grind off a lot of bad stuff. Great on non-skid stains. Used on gel coat, requires re-waxing. Good all-around polishing agent for fairly hard surfaces. Test a small area first.
Joe. (TOOOOOOOOOO much coffee today!!!)
PostPosted: Tue Aug 29, 2006 10:03 pm    Post subject: Reply with quote
Another possibility is the "Clay" that auto body shops use for removing over spray from glass. I have found this very effective in removing mineral stains from windows.
sailor-d
Photos: Sailor-D
PostPosted: Tue Aug 29, 2006 10:10 pm    Post subject: Water stains on windows Reply with quote
CB
I had that problem when I bought my '91. I called various glass shops for a remedy. I think I finally hit on it; thoroughly clean the windows with windex or a vinegar solution and scrape with a razor blade (the ones with a rigid side) held at a low angle. It works cleaning gunge from a ceramic cooktop with no scratches and worked well on my windows - just have to be careful. Hope it works for you.
cheers - Dave
oldgrowth
City/Region: Rochester
Vessel Name: C-Voyager
Photos: C-Voyager
PostPosted: Thu Aug 31, 2006 2:06 am    Post subject: Re: Water stains on windows Reply with quote
I have used sailor-d's method and find it works better than anything else.
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Thu Aug 31, 2006 6:15 am    Post subject: Reply with quote
Have also heard of using Coke. The acid or something in the beverage is suppose to cut things a bit. I need to try this myself with my 1985 boat... and I always have apple cider viniger around... in fact.... jut mix it 50/50 with the coke...and you have a wonderful BBQ spray for the grill. We have been using that for over 5 generations in our family. Good stuff.
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Thu Aug 31, 2006 11:12 am    Post subject: Reply with quote
The ports used on sailboats are a similar material and I had good luck with Brasso. I know it is intended for use on boating metals but it worked real good for the window. When I bought the boat the windows had been neglected and were totally fogged over. A little Brasso on a soft cloth and some rubbing and they cleared right up.
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Thu Aug 31, 2006 11:41 am    Post subject: Reply with quote
Lime Elim or CRS are common household acidic mineral removal agents. The best boat products for that include Oxalic Acid. Star brite used to have an oxalic acid product. I would avoid abrasive products such as Brasso.
Sold 2007 TomCat TC255, Tom-a-Hawk
digger
City/Region: Spokane
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Thu Aug 31, 2006 12:28 pm    Post subject: Barkeepers Friend Reply with quote
The Barkeepers Friend is the only thing that worked for me. Tyboo suggested it to me. Try it on one window, and you'll be sold. Don't use it on the inside because they have tinted film. Good luck. Ron, aka "digger" on Snoopy-C
previous snoopy-c owner, previous c-miner owner, current C-Sik owner(22 angler)
True Story
City/Region: Snoqualmie
Vessel Name: True Story
Photos: True Story
PostPosted: Thu Aug 31, 2006 1:20 pm    Post subject: Reply with quote
Trust Tyboo!. 10-4 on Barkeepers Friend. Wet rag, liberal amount of BF and elbow grease completely removed the stains and shined up the windows. I tried several non-abrasive approaches to removing these stains with zero effect.
Wayne McCown
State or Province: NY
Vessel Name: Little Mac
Photos: Little Mac
PostPosted: Thu Aug 31, 2006 4:52 pm    Post subject: Barkeeper's Friend? Reply with quote
Where can one buy Barkeeper's Friend?
Flip
City/Region: Potter Valley
Vessel Name: Pooch
Photos: Pooch
PostPosted: Thu Aug 31, 2006 5:09 pm    Post subject: Reply with quote
Walmart has it as many Supermarkets good luck
Wayne McCown
Photos: Little Mac
PostPosted: Thu Aug 31, 2006 5:31 pm    Post subject: Where in Wal-mart? Reply with quote
Do I look for it in the liquor section, or ??
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Thu Aug 31, 2006 5:49 pm    Post subject: Re: Where in Wal-mart? Reply with quote
If you find it there, don't drink it! Disgust
It should be located with the "Comet" (house cleaning product section)....if it is not there tell your grocer to start ordering it. I asked our grocer if he would order it years ago and now it is in demand. (I initially purchased it for the "fiberglass" tubs, showers, sinks etc. in the house....works great!).
Dave S.
"Sea Shift"
C-Brat #16
Wayne McCown
Photos: Little Mac
PostPosted: Fri Sep 01, 2006 9:35 am    Post subject: Got it! Reply with quote
THANKS!! (I won't drink it!)
Page generation time: 0.0595s (PHP: 51% - SQL: 49%) - SQL queries: 28 - GZIP disabled - Debug on
