Sticky Sliding Windows
seahooked
City/Region: Redmond
Photos: SeaHooked
PostPosted: Fri Aug 25, 2006 4:39 pm    Post subject: Sticky Sliding Windows Reply with quote
The sliding windows on my new CD25 are very hard to move back and forth. I was about to try some silicon grease as a lubricant, but I'm concerned the grease will be an attractant for dirt and end up making things worse in the long run. Is there something better to use such as graphite or Teflon?
Thanks.
Chris Brown
Redmond, WA
2006 CD-25 Cruiser "SeaHooked" 2006-2012
PostPosted: Fri Aug 25, 2006 5:24 pm    Post subject: Reply with quote
seahooked-
This is a good question for us, but the best answer would come from Diamond Sea Glaze, who builds the windows. Several recent threads have delt with window issuess from them. I'll add their address as soon as I can find it.
Here's the contact information address for asking them about this:
LINK
Joe.
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Fri Aug 25, 2006 6:56 pm    Post subject: Reply with quote
Personally, I use a product called "Liquid Rollers". It's a silicon spray that has lasted almost a year and is made for trailer bunks but works just great when sprayed on the little furry liner.
West Marine carries it.
Don
Mary & Don Anderson
Brat #483
Dreamer
Photos: Dreamer
PostPosted: Fri Aug 25, 2006 9:06 pm    Post subject: Reply with quote
You might ask the factory. They just cured that complaint on our TC-255. I think they spread the channels somehow. As far as a spray lube, use teflon spray instead of silicone. It doesn't attract and collect dust.
Dreamer- Sold 25 Feb. 2013
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Fri Aug 25, 2006 9:51 pm    Post subject: Reply with quote
Jeez, you mean I don't have to mount those come-alongs after all. I thought the window design was part of an aerobic program. Try to open the windows at least twice on each trip and your heart rate will stay up for 15 minutes!! Very Happy Very Happy
Patti and Barry
formerly C-Cakes, now
rving around N. America
Grumpy
City/Region: Whidbey Is
Vessel Name: Kingfisher II
Photos: Kingfisher
PostPosted: Fri Aug 25, 2006 10:30 pm    Post subject: Reply with quote
Amen Barry bin there too !!
Now what happens if you have tried both Silicone implantation and Teflon politics ??
Only thing I can say is mine are still muscle busters and if you get either one on the vertical "brush" section you will have the biggest "schmeer" problem on the aft portion of the window.
Only thing I have found that works is to get 'em wet. (Windows, that is...)
Merv
PostPosted: Sat Aug 26, 2006 12:45 am    Post subject: Reply with quote
Grumpy-
Your Question:
"Now what happens if you have tried both Silicone implantation and Teflon politics ??"
Friday Night Answer:
You'd be an instant T-V Prima Donna hit on Castro Street in S.F.!!!Smile
Hi, Sailor, Wanna get lucky? Lips
Just for Laughs!
Grumpy
Photos: Kingfisher
PostPosted: Sat Aug 26, 2006 7:35 pm    Post subject: Reply with quote
Sea Wolf,
Now you know why I am staying North of the Border with my windows shut !!
Good response though. Thanks for the laugh.
Laughing
Merv
seahooked
Photos: SeaHooked
PostPosted: Mon Aug 28, 2006 4:18 pm    Post subject: Reply with quote
Thanks for the replies guys. I followed Joe's link to Diamond Sea Glaze and their recommendation was "clean out any salt build-up from the tracks and use silicone spray". However they admitted dirt buildup was a valid concern and a dry lubricant such as Teflon might be better.
I going with Roger and will try Teflon. I'll post the results later.
seahooked
Photos: SeaHooked
PostPosted: Sat Oct 21, 2006 11:16 am    Post subject: Reply with quote
I bought a can of TFE Dry Lube and tried it about a month ago. I sprayed only the lower track of all the windows since it seems like most of the friction would be there. The windows are still snug but at least now I can move them all back and forth with one hand (my wife and kids as well).
I've used the boat half a dozen times since applying the spray and haven't noticed any change in friction over that period.
I'm satisified, at least for now.
PostPosted: Sat Oct 21, 2006 11:27 am    Post subject: Reply with quote
I hate these windows on the CD25, and I hated them on the CD22...from time to time, the helm side window on the CD25 will not budge. I don't want to even think about spreading the track - my motto is "Don't make a problem worse" - but I guess I will have to look for some teflon lubricant. My problem is I am SO unmechanical, it took a year before someone showed me how to remove the window screens! How do you "clean the track" while it is full of sliding window?
oldgrowth
City/Region: Rochester
Vessel Name: C-Voyager
Photos: C-Voyager
PostPosted: Sun Oct 22, 2006 2:07 am    Post subject: Reply with quote
Pat, have you heard of David of the Anna Leigh?
I am having the same problem on the Port window. I will spray the groves with water then blow them out with the compressor. After it dries, I will use the TFE Dry Lube.
Will let you know how it works.
UncleRichie
City/Region: Bainbridge Is.
Vessel Name: C-Critter
Photos: C-Critter
PostPosted: Sun Oct 22, 2006 2:47 am    Post subject: Reply with quote
hello,
Had the same problem on the windows I used an old tooth brush and compressed air open the window as far as possible and brush the heck out of it blow out repeat until it works easy. Silicon spray doesn't hurt eather. Has worked so far on mine and it 6 years old now.
Richard
Jeff Brigner
State or Province: TN
Vessel Name: C-Pearl
Photos: C-Pearl
PostPosted: Mon Oct 23, 2006 11:54 pm    Post subject: Reply with quote
Pat Anderson wrote:
I hate these windows on the CD25, and I hated them on the CD22...from time to time, the helm side window on the CD25 will not budge. I it took a year before someone showed me how to remove the window screens! How do you "clean the track" while it is full of sliding window?
How do you remove the screens?
Jeff Brigner
Photos: C-Pearl
Page generation time: 0.0333s (PHP: 76% - SQL: 24%) - SQL queries: 28 - GZIP disabled - Debug on
