Navigation Lights
ken 120
City/Region: Sea Isle City,
State or Province: NJ
PostPosted: Sat Jul 08, 2006 4:40 pm    Post subject: Navigation Lights Reply with quote
Hello Out there:
Just replaced a blown navigation port light - When checking to make sure that everything was working noticed on my 01 22 that the port and starboard navigations lights do not come on unless the anchor light is on.
Never noticed that before since when cruising I put the three lights on at dusk.
Is that the way it is suppose to be or do I have troubles? My boat has separate rocker panels for the anchor light and the navigation lights and you would think that the anchor light and navigation lights would work independently. Anchor light comes on without the navigation lights on.
Ken
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Sat Jul 08, 2006 5:08 pm    Post subject: Reply with quote
The anchor light is your 360 deg white light while "powering" required by Coast Guard regulations. That's the way it should work. My boat has a triple position rocker switch, left is anchor and nav lights, middle OFF, right is anchor only.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
PostPosted: Sat Jul 08, 2006 7:01 pm    Post subject: Reply with quote
On my boat, I have separate rocker panels and the lights are independent. E.g. I can switch either the nav lights or the anchor lot on independently. This is how it was wired at the factory but I think with different people rigging lights both at the factory and eslewhere, it gets done different ways. It seems to me that as long as you can turn the anchor light on by itself and have the nav lights optionally on, the wiring is OK.
SeaSpray
City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
PostPosted: Sun Jul 09, 2006 5:52 pm    Post subject: Reply with quote
On my 2004 22 when I turn on the nav light switch all 3 come on. When I turn on the anchor light switch only the white comes on. This is accomplished with a diode between the nav lights switch and the anchor light switch that lets the power flow to the white light when the nav switch is turned on.
I discovered this because on my boat the diode was put in backwards and when I turned on the anchor light switch all 3 lights came on. Once I turned the diode around it worked as intended.
Steve
Big Mac
City/Region: Chehalis
Vessel Name: Mary Ellen
Photos: Mary Ellen
PostPosted: Mon Jul 10, 2006 12:18 am    Post subject: Navigation and anchor lights Reply with quote
I just went out to the shop and tried the lights on the Mary Ellen. When the anchor light post is installed it comes on with the navigation rocker switch. If you turn the navigation rocker switch off and turn on the anchor rocker switch only the anchor light comes on. The Mary Ellen is a 2001 22 foot cruiser. Hope this helps, Big Mac.
MikeMac
City/Region: Stafford
State or Province: TX
C-Dory Model: 22 Classic
Photos: MikeMac
PostPosted: Mon Jul 10, 2006 9:24 pm    Post subject: Reply with quote
The old boats could have some fun problems. I think they were rigged for International Rules and had a forward 20 point running light on the removable post, an aft 12 point running light over the cabin door, a combined 10 point red and green forward of the cabin hatch, and an aft 12 point anchor light on the post (which would combine with the forward 20 point running light on the post for anchoring), all running on a three-position pull switch. So you had a three-position switch and four lights. The possibilities for getting the hookup wrong were just about endless!
The previous owner of my boat could never get the lights right. I don't know if he fooled around with the connections but it took me about two hours to get it hooked up properly when I bought the boat. I think it was wired incorrectly from the factory.
Mike
Page generation time: 0.0517s (PHP: 63% - SQL: 37%) - SQL queries: 19 - GZIP disabled - Debug on
