Mysterious Black Spots
rcwass
City/Region: South Berwick
State or Province: ME
C-Dory Year: 1990
Vessel Name: Lorraine J
PostPosted: Wed May 31, 2006 6:05 pm    Post subject: Mysterious Black Spots Reply with quote
My C-Dory was on a boat lift in Maryland for 6 years. I started getting these tiny pin head black spots all over the outside of the boat. These are like raised bubbles and are hard. My boat is a 1990 that has been exposed to California and Maryland sun since new so the gel coat is pretty much gone. When I scrape these spots off they leave a stain in the fiberglass. I've since moved to Maine and have noticed these same spots on my galvanized trailer. The boat was on the trailer in California and in storage in Maryland. I haven't found anything that removes these spots or stains. It was suggested I use accetone but I'm hesitant. Does anyone know what these black spots are and have any idea how to get rid of them? Right now I have about a thousand of these on the fiberglass, stainless steel and trailer.
I have photo's if needed but they don't show up that well.
Thanks for your help.
Dick
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Wed May 31, 2006 6:16 pm    Post subject: Reply with quote
The most obvious GUESS would be liquid ashphalt kicked up from the tow vehicle tires. It would harden over a short time, and when rubbed off would leave a brownish-black stain. They can usually be rubbed out easily with rubbing compound on the boat. Probably on the trailer as well.
Patrout
City/Region: NORTH POLE
C-Dory Year: 1983
C-Dory Model: 22 Classic
Vessel Name: C-FARER
Photos: C-FARER
PostPosted: Wed May 31, 2006 6:24 pm    Post subject: Reply with quote
Those spots could also be organic residue from trees or insects. Have you tried solvents designed to get rid of that kind of stuff?
Pat
rcwass
C-Dory Year: 1990
PostPosted: Wed May 31, 2006 7:04 pm    Post subject: Mysterious Black Spots Reply with quote
I've tried mild rubbing compound, waxes and marine cleaners with no results. I've tried scraping the bubbles off which can be done but the stain below is stubborn. I doubt if its asphalt related because the bubble shell is hard and when scraped in the sun there's no smudge.
Thanks for the input.
Dick
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Wed May 31, 2006 7:13 pm    Post subject: Reply with quote
Perform a search here for "barkeepers".
Barkeeper's Friend is the gelcoat and stainless secret weapon. I've yet to find any gelcoat stain it would not easily remove, and it takes rust off of stainless like nobody's business. Mix it thick with water so it forms a paste, rub it a bit, and presto...
Your stains may be the first it fails to remove...but I'd be surprised.
Tux Will, C-Brat Nerd Tux
Patrout
C-Dory Year: 1983
Photos: C-FARER
PostPosted: Wed May 31, 2006 7:15 pm    Post subject: Reply with quote
Right, Bill.
I get my Barkeeper's Friend at Walmart.
Pat
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Wed May 31, 2006 11:07 pm    Post subject: Reply with quote
Yup...I've seen it at some Safeways as well. Not sure how wide-spread Smart & Final is, but that's where we get ours - they sell a 3-pack of tall cans cheap.
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Thu Jun 01, 2006 4:52 am    Post subject: Reply with quote
Dick,
Was your boat near any oil wells? An oil well near my marina in LA leaked and sprayed a fine mist of crude oil into the air. All the boats in the marina had tiny black dots!
Paint thinner or kerosene would dissolve asphalt, tar, or crude oil.
Acetone or lacquer thinner will also work and since it won't hurt galvanized (or stainless) steel I would practice removing the spots on the trailer or SS rails first!
Larry H
A C-Brat since Nov 1, 2003
Papillon
Vessel Name: Papillon
Photos: Papillon
PostPosted: Thu Jun 01, 2006 11:26 am    Post subject: Reply with quote
Dick,
Scrape off a bit of the black and take a taste....I bet you can figure out what it is without having to call 911. If it taste nasty spit it out and rinse with Jack Daniels. Heck, I might have to look for some black spots on my boat now I think about it.
Mike
Mike Taylor
330-936-1030
Swee Pea
City/Region: Bath
Vessel Name: Swee Pea
Photos: Swee Pea
PostPosted: Thu Jun 01, 2006 1:19 pm    Post subject: Reply with quote
I do not want to be an alarmist, but when you said "bubbles", it may be what is referred to as "osmosis". I am no where near an expert, but if you go to the bottom paint discussion refer to the aurora web site, www.auroramarine.com. Join the aurora marine "club" and search for osmosis. They have a picture posted of the bubbles. THEY ARE NOT BLACK, SO THIS MAY BE A FALSE ALARM. But it's worth the effort to eliminate this possibility.
Swee Pea
Papillon
Photos: Papillon
PostPosted: Thu Jun 01, 2006 1:39 pm    Post subject: Reply with quote
I can't remember seeing any "osmosis" on trailers or stainlass seel before, so I would pretty much rule it out in this case.
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Thu Jun 01, 2006 1:52 pm    Post subject: Reply with quote
Mike I think you are right on this....but I'd keep the Jack handy just in case. Ya never know when it might start hitting the metal stuff...
lloyds
PostPosted: Thu Jun 01, 2006 1:56 pm    Post subject: Reply with quote
Osmosis, or blistering, is pretty easy to see and identify. Even the untrained eye will recognize it if they see it. Just go to any boatyard and look for boats with lots of spots sanded or opened on their bottoms. Then go to a boat on blocks with a dry bottom but no prep work and spot the blisters. This can and does happen in all regions, types of weather, salt or fresh water. They vary in size from the size of the lead in a pencil to a silver dollar, and are usually round. Once they get past a dime or so the chances of them going into the core material is much greater. I haven't heard of C-Dory having much of a problem, but I am sure there are a few around in this brand as well. But the problem in this thread is not osmosis. They don't take on a color, at least not much. If you drain a blister the liquid will come out about the color of light varnish, and will smell somewhat like varnish, because it has some of the same chemical makeup. But these black spots are kind of intriguing. If it isn't petroleum, it almost has to be some foreign substance landing on the hull, then possibly reacting with sunlight. Maybe some petroleum based substance or insecticide emulsified in the water the boat is in.
PostPosted: Thu Jun 01, 2006 2:16 pm    Post subject: Reply with quote
Two possible explanations arise:
1. Bug poop. (or)
2. For years cosmologists have speculated about where all the material goes that is sucked into giant black holes in the Universe so large that not even light can escape their gravitational pull. Where can all those untold billions of suns masses of matter be? Is it all locked up inside the black holes? Or does it reappear in another parallel Universe at another time or dimension of space? Could it reappear as black spots on boat hulls in Maine? Inquiring astrophysists want to know!
Get the BarKeepr's Friends:
Booze
Friendly Women
Scouring cleanser
oldgrowth
City/Region: Rochester
Vessel Name: C-Voyager
Photos: C-Voyager
PostPosted: Fri Jun 02, 2006 2:42 am    Post subject: Reply with quote
rcwass – I get the same thing on my boat. If I clean it on a regular basis the spots come off easily. My boat is stored in my equipment shed and I believe the spots are caused by spider poop. The spiders are in the rafters above my boat, the spiders catch other insects, suck their juices out, then poop on my boat. I put up with it because they keep the insect population down.
Page generation time: 0.0416s (PHP: 69% - SQL: 31%) - SQL queries: 28 - GZIP disabled - Debug on
