Navman Fuel 3100
PostPosted: Wed May 10, 2006 11:11 pm    Post subject: Navman Fuel 3100 Reply with quote
I'm trying to install a Navman Fuel 3100, and I know several people have them and they work. So, my question is:
To hook up the NMEA in (GPS output, 3100 input) signal the Navman manual shows a single NMEA in signal (white wire). My GPS outputs NMEA data on two wires (NMEA out + and NMEA out -.
The Navman manual also shows the NMEA ground (I assume it's also power ground) going to the battery. The GPS also has a NMEA data ground, did someone connect it to the 3100 ground?
Given that plethora of data, how did you hook up the meter? Single ended or somehow differential?
Help, Boris
Capt'n Bill
City/Region: Big Island
State or Province: HI
C-Dory Year: 1994
Vessel Name: Malia Kai
PostPosted: Thu May 11, 2006 3:11 am    Post subject: I'll Be Watching Reply with quote
I've had my eye on the 3100. Will follow to see how things go and how you like the device.
PostPosted: Thu May 11, 2006 9:56 am    Post subject: Reply with quote
Well, I called the USA Navman rep, and here's the scoop:
1. The wiring diagram they show in the installation manual is wrong (pg 19.) The correct wiring is shown in Appendix A, (pg 22.)
2. They use single ended circuits, which as we all know are more susceptible to noise. Nevertheless, connect the GPS Data+ lead to the 3100 NMEA IN (Yellow lead) and the GPS Data - lead to the 3100 return (black wire, actually, the shield ground.)
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Thu May 11, 2006 10:07 am    Post subject: Reply with quote
Thanks...that will be real handy with me retroing C-Byrd this month and ya bet your bippy that this gadget will be on my ride.
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Thu May 11, 2006 10:35 am    Post subject: Reply with quote
Oops, you answered your own question faster than I found the answer, Boris.
There's a great NAVMAN 3100 thread on The Hull Truth electronics forum. Echoes what you found and added a little more to the Navman knowledge base.
Don
Sneaks
Vessel Name: C-Brat
PostPosted: Thu May 11, 2006 10:44 am    Post subject: Reply with quote
Pat, one very minor comment. The Navman 3100 is a space hog if you plan to put it around the helm of a C-22 and I expect even worse with the smaller C-Dorys. There's probably plenty of room if one uses forethought in planning all the gauge/trim/autopilot/windlass control locations, but don't count me in that elite crowd. Sad
Don
Byrdman
PostPosted: Thu May 11, 2006 12:55 pm    Post subject: Reply with quote
space is limited... in fact on the old angler, the current tach is mounted "flat" up on the top of the "helm dash" and not on the vertical side facing the helm seat. My thoughts are to use the same "hole", but sort of make a "wedge shape" item as to slant the instrument back towards me at the helm. Sort of two "door wedges" so to speak on each of the sides with the item mounted onto them. If you can kinda picture what I am going after. Nothing real high...just give her a tilt of about 1" to 1 1/2" high in back to basically flat in front, angled towards the helm. I have to kinda raise up out of my seat and glance down at the flat surface now....or, sit on a boat cushion.... being the vertically challenged individual that I am....but...I do have plenty of head room....even for a cowboy hat if I so choose.
Sawdust
City/Region: Oak Harbor
C-Dory Model: 22 Classic
Photos: C-Salt
PostPosted: Thu May 11, 2006 3:05 pm    Post subject: Reply with quote
Hmmmmmmm - and with current belt size how do you plan to get close enough to read the numbers? huh?? Wink Wink
1984 22 Classic
PostPosted: Thu May 11, 2006 4:20 pm    Post subject: Reply with quote
Dusty- Shame on you!!! That's an intentionally embarassing question and especially from a guy from the Sequim High School Class of 1894!
Joe.
PostPosted: Thu May 11, 2006 6:03 pm    Post subject: Reply with quote
Well, the Navman display and the Raymarine autopilot display are the same size. And the factory steals all the real estate on the "dash", since they get first crack. Even where they don't mount instruments, they've used the other side to mount stuff.
What I did was to build an auxiliary dash that fits fore and aft, just in front and outboard of the throttle , since one doesn't need to see those units full time. There was enough length to throw in a voltmeter. Angeled back 20 deg., you can even see the display faces without bending down. Used Starboard for the structure.
boris
Sea Angel
Photos: Sea Angel
PostPosted: Thu May 11, 2006 7:11 pm    Post subject: Reply with quote
Sea Angel here,
You see the setup on the [CD25] Sea Angel's helm... immediately to the left [port] side of the wheel. Good visability for this helm.
As to the wiring... 'single ended' here and fed directly from the Garman 2006C with a parallel input also to the VHF, ICOM502, radio for the DSC function. You can safely feed 2 devices this way.
Hope this may help others..
Art ka1rx
CBRAT #208
USCGAUX (RET), USN(RET)
Broadcast TV ENG(RET)
ka1rx@verizon.net
SKYPE: Art.Bartlett4
Byrdman
PostPosted: Fri May 12, 2006 10:48 am    Post subject: Reply with quote
Ouch Dusty... I guess cause I generally keep a magnifying glass around the helm in the boat bag as to help me see the little things on the ol faithful never needs batteries paper maps... Yep... I love back-ups. .....and....they do have big readouts on them... Grin.
Sawdust
Photos: C-Salt
PostPosted: Fri May 12, 2006 11:46 am    Post subject: Reply with quote
Pat,
Just an old NAVY guy pulling your chain a bit. I'm a bit sensitive in that area because Diane is buying the next size larger for me Rolling Eyes. Too many fresh shrimp and halibut!! Get back up here guy, miss you.
Love
Dusty
PostPosted: Fri May 12, 2006 10:28 pm    Post subject: Reply with quote
Sea Angel;
When you ran your single ended GPS output (3100 input), did you connect the 3100 power return to the GPS - (low) signal wire? I'd like to know before I turn the power on.
In all my years of interfacing data signals, the one thing I learned was to separate power and signal returns. Now Navman is asking me to connect them. It's hard.
Thanks, Boris
PostPosted: Tue May 30, 2006 5:21 pm    Post subject: Reply with quote
OK, the Navman 3100 fuel flow meter is installed. To interface the !@#$ thing to the GPS, I got a NoLand Engineering XP15 Expander. This is a buffer amplifier, with a single NMEA input, 5 ea differential outputs (RS-422) and 1 ea single ended output (RS 232.) So now I have GPS to the autopilot, VHF radio, fuel flow, and more available (the depth sounder has a GPS input, for goodness sake.) The computer has its own GPS, but there is an output available.
Since there is now position data to the VHF, we got a MMI number. Free, Boat us. So now if we're in trouble, all we need to do is push a single button and there's the emergency signal, with our number and position. We can also get a (co-operating) boats position, by just requesting it, automatically. We just need to know the MMI number. Will wonders never cease. All new fixed VHF radios have this capability (I think.)
Will try out everything on the water Thursday (after my last day at work,) and then off to the San Juan Isls, and thereabouts. See you up there.
Page generation time: 0.0728s (PHP: 55% - SQL: 45%) - SQL queries: 28 - GZIP disabled - Debug on
