bilge plug between cabin and cockpit
computer-rooter
City/Region: Sitka
C-Dory Year: 1982
C-Dory Model: 22 Classic
Vessel Name: RAGING FERRET
PostPosted: Mon May 01, 2006 9:38 pm    Post subject: bilge plug between cabin and cockpit Reply with quote
I haven't seen this discussed yet, so maybe it's a fresh topic:
My 22 classic gets wet in the cabin a lot (Why isn't really part of the story). I'm thinking about drilling through the crossmember that the rear cabin bulkhead sits on (at deck level) and puckying in a thru-hull tube. Then I can use a bilge plug to auto-drain the cabin when I'm on step. Anyone see a downside to this?
If it's not fun, I won't do it!
Mr. Fisherman
Vessel Name: Sea Lion
Photos: Sea Lion
PostPosted: Mon May 01, 2006 10:39 pm    Post subject: Reply with quote
My 95 Angler has one. I thought it was stock?
I usually don't have issue with water in the cabin unless it is rain water when it sits on the trailer.
Live to Fish
Fish to Live
PostPosted: Mon May 01, 2006 10:44 pm    Post subject: Reply with quote
My 2002 22 has one - mine has a nylon fitting with a screw in plug that I leave in all the time. When I'm at rest, and it's raining, water pools just in front of the door so I want it plugged. However, if you use a normal through hull/plug combo (like the cockpit drain), it should be easy enough to plug and unplug as needed.
PostPosted: Tue May 02, 2006 1:40 am    Post subject: Reply with quote
I had the factory add on last year while the boat was in for some work. My sons friends got the floor soaked while swimming and tubing last summer. there was no way to drain the floor, I had to use towels instead. now I have a drain.
computer-rooter
City/Region: Sitka
C-Dory Year: 1982
PostPosted: Tue May 02, 2006 5:01 am    Post subject: Reply with quote
Thanks all for the input!
My c-dory so old it's in black and white instead of color. If the newer ones are coming with cabin drains and the factory is refitting for them, I'll upgrade too.
My water issues happen when I leave the boat with a window or hatch open, or when I want to hose out the cabin. Otherwise it's an acceptably dry house.
Page generation time: 0.0431s (PHP: 47% - SQL: 53%) - SQL queries: 18 - GZIP disabled - Debug on
