Wildlife Invasion
rcwass
City/Region: South Berwick
State or Province: ME
C-Dory Year: 1990
Vessel Name: Lorraine J
PostPosted: Thu Mar 30, 2006 5:42 pm    Post subject: Wildlife Invasion Reply with quote
My 22' Cruiser has been up on blocks and covered for the winter. Last week I removed the cover to do some repairs for the upcoming season. I removed my kicker and brought it into the basement. When I removed the shroud I found a large nest made of TP. When I checked inside the cabin I found acorn shells and pieces of TP. Under the sink, more TP. In the V-Berth another nest of TP, more acorn shells and Pea and Pooo!
Chipmunks have invaded my C-Dory. I've been told to put moth balls in the boat next winter. Any other suggestions. What a mess! Hope they haven't eaten any wires.
Dick
SOLD IT. Bought my 1990 22' C-Dory Cruiser new in Fairfield CA. Lived in Vallejo CA. Fished the bays and the Sacramento River. Towed it across country in 1995 to Maryland. Lived in Tall Timbers MD and fished the Potomac River. Towed the C-Dory to Maine in 2001. Now settled and will be fishing the rivers, bays and Atlantic. Boats Name: Hunky Dory. Yes another "Hunky Dory".
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Thu Mar 30, 2006 6:09 pm    Post subject: Reply with quote
Sorry to hear of the rodent problems. Rodents invading farm equipment, planes, autos, motorhomes is a very common problem. A special spray was developed to prevent them from climbing up the inside wheel/ brake line access areas. I believe it is called "Mouse Out". I got some at a small town auto parts store. They use it alot on the farms 'cause the mice get up in the tractors, combines, etc., and chew up the hydraulics something terrible.
Here in Kansas, the fall is the worst time for these invasions. Mice took over my motorhome stored in the roundtop last year. I started spraying from the roof a/c heat vents first, then lower each day. They hated the spray so much they were actually running out while I sprayed.
The stuff smells like concentrated mothballs, so I am certain it is not intended for much inside use, but it seems to air out OK. I have had them in my trucks and balers, too, so I spray everything around the wheel access areas in the Fall and that seems to work.
I hope this might help you out a bit, John
Sold 2007 TomCat TC255, Tom-a-Hawk
Larry K
City/Region: Port Huron, MI
Vessel Name: Odyssey
Photos: The Odyssey
PostPosted: Thu Mar 30, 2006 6:24 pm    Post subject: Reply with quote
I've used dryer softener sheets like Bounce. It has worked for the last 3 years and smells a lot better in the spring.
I know it works for mice but don't know about Chipmunks.
Larry K -Odyssey
iggy
City/Region: Hillsboro, OR
Vessel Name: Edward Gallaher
PostPosted: Thu Mar 30, 2006 6:37 pm    Post subject: Reply with quote
Obviously this can be a much larger problem on bigger boats. PassageMaker Magazine just had an article this month on a marina invasion of rats, apparently due to nearby construction.
The author spent a great deal of time solving his problem, including gnawed teak floor board grids in the shower, etc. etc. Another boat incurred tens of thousands of dollars of damage, which is often not covered by insurance!
Once aboard, you cannot be sure that -anything- is intact! Wires. Cushions. Carpets and floorboards. Water hoses. The list goes on . . .
I hope you don't have these problems, but I'd suggest a very careful inspection.
e.g.
PostPosted: Thu Mar 30, 2006 6:52 pm    Post subject: Reply with quote
Larry K -Odyssey
I know it works on mice in our travel trailer. If it doesn't, at least your Chipmunks will be soft and fluffy. You might also try renting a cat... Cat Cat
Charlie Laughing
PostPosted: Thu Mar 30, 2006 7:27 pm    Post subject: Reply with quote
Besides the dryer sheets, which really work well, we put D-Con around the boat and motorhome. The rodents (a chipmunk is just a rat with better PR) eat it and go outside to die. We also put Comet cleanser around the tires and the trailer jack (sprinkled in a 6" circle around anything that touches the ground). I've been told this also keeps the crawly critters out... must work, we haven't found any in our stuff. If there are any gaps/openings in walls or storage space, we put steel wool in there. No free rent for the varmits. Evil or Very Mad
http://captnjim.blogspot.com/
AstoriaDave
City/Region: Astoria
PostPosted: Thu Mar 30, 2006 8:58 pm    Post subject: Reply with quote
The mothballs will also keep yellowjackets from nesting or wintering over. [The queens generated from an old hive spread out and hibernate ... to spring to life in April or so.]
Dave Kruger
Astoria, OR
Chris Bulovsky
City/Region: Washburn
C-Dory Year: 1998
Vessel Name: SCOUT
Photos: SCOUT
PostPosted: Thu Mar 30, 2006 11:44 pm    Post subject: Reply with quote
I had a mouse trouble in an other boat and a car a couple of years ago. They like to chew wires Evil or Very Mad . I placed some rat poison from the feed store. That did the trick. Also started storing bird seed in metal trash cans with lids. That also helps. Eliminate the food sources and apply poison.
Good hunting
Chris Bulovsky
Page generation time: 0.0447s (PHP: 59% - SQL: 41%) - SQL queries: 25 - GZIP disabled - Debug on
