Time to recarpet the trailer siderails.
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Thu Mar 23, 2006 4:32 pm    Post subject: Time to recarpet the trailer siderails. Reply with quote
The side rails on our King trailer are really worn from numerous climbs in and out of the boat over the years. Time to "recarpet."
Seems like a straight forward job - but before I launch into it, thought I'd ask the C-Brats for thoughts/ideas.
Any recommendations on the type of carpet to use (I'm assuming some sort of indoor/outdoor...), or more importantly, any recommnendations of what NOT to use!?
I'm also thinking about using some type of rubber dock bumper material in lieu of carpet. Anybody tried that?
Appreciate your thoughts!
Casey
C-Dory Naknek
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Thu Mar 23, 2006 4:42 pm    Post subject: Reply with quote
I see West Marine sells the stuff, but it just looks like indoor/outdoor stuff...
Home Depot has the same stuff..(I think)
I just had sideboards installed on my trailer... my question is, and you might be the best to answer.... how much clearance between the boat and the boards should you have ?? when they were installed they were tight against the boat..... I think they would wear the side of the boat... I backed them off ... to give about 1/2" clearance...is this good..or should I back it off more??
Joel
SEA3PO
PostPosted: Thu Mar 23, 2006 5:20 pm    Post subject: Reply with quote
I don't have sideboards but I would think that wear would be caused with movement while traveling (not launching or retrieving as long as it's a smooth surface) and that a tighter fit would be better. If it can't move, it can't/won't wear.... I would think/hope...
There's some thoughts from someone who doesn't have any experience with the issue. Never stopped me before! Smile
Casey
Photos: Dessert 1st
PostPosted: Thu Mar 23, 2006 5:27 pm    Post subject: Reply with quote
Joel,
I'd say 1/2 inch clearance is about what we have as well. Seems to work ok, but sometimes I wish there was a little tendency to center the boat when loading - but I think that's a issue topic than side rail clearance (more like the flat hull wants to wander a bit). The bow will come into the chock ok, but the stern sometimes want to wander a bit. ...still looking for a solution.
We'll be seeing you at Powell next month. Bring a couple pic's of your Beemer(s); but please don't bring a pic of a 1973 R75/5 Toaster tank, unless you want to see me cry. Long story.
Later,
Casey
C-Dory Naknek
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Thu Mar 23, 2006 5:28 pm    Post subject: Reply with quote
When the boat is perfectly centered, I have about 1/2" clearance on each side at the fat belly point on the Jenny B. Thumbs Up
Mary & Don Anderson
Brat #483
PostPosted: Thu Mar 23, 2006 5:51 pm    Post subject: Reply with quote
I've still got the originals on my "87 trailer! I think it's partly due to the fact that the carpet is of an I/O type that doesn't retain water and rot.
Stay away from normal carpet with a lot of jute or wool. Synthetics are better, i.e., rot less or not at all.
A dark color will absorb more heat from the sun and dry out better.
Look at the stuff sold for this purposes and buy it or the equivalent.
Use stainless staples or brads. Regular steel rusts out within a two year period in fresh water, probably a year in salt.
The wood underneath must be allowed to dry to stop it from rotting. Paint any exposed areas black to heat it up.
My rails were attached to the trailer with lag screws and the wood rotted out aroud them. Replaced them with stainless carriage bolts = end of problem.
If you have to replace the rails, use redwood heartwood or something that won't rot out quickly. Pressure treated wood might be the best.
My rails are curved to the hull form. Don't really know whether or not they're laminated up from thinner stock on a form. Replacing a curved rail might require you to build a form and lay the rails up from 1/4" strips with waterproof glue. Another wood shop project!
I have 3/4 inch clearance on each side. from 1/2 to 1 inch is probably OK. It may depend on how your side rails / guide-ons are designed. You want to be able to center the boat, but not rub off the gelcoat.
If you can get away with it, move the side clearance lights from wheel level up to the top front of the guide-on to keep them out of the water when launching. Less likely to get smacked by another trailer in the parking lot too!
Joe.
Sneaks
Vessel Name: C-Brat
PostPosted: Thu Mar 23, 2006 6:02 pm    Post subject: Reply with quote
Sea Wolf wrote:
My rails are curved to the hull form. Don't really know whether or not they're laminated up from thinner stock on a form. Replacing a curved rail might require you to build a form and lay the rails up from 1/4" strips with waterproof glue. Another wood shop project! Joe.
Joe, I think you'll find your rails are curved more because you slammed them too many times while boating under the influence of Shasta water. Remember, the boat's fat belly has to get past the rear rail mounting posts and if the boards are parallel, 1/2" at the belly point translates to about 3 1/2-4" at the rear. Moon
OTOH, maybe the distance between your front mounting posts is way narrower than usual
Don
stevej
City/Region: Gaston
Vessel Name: Shearwater
Photos: Shearwater
PostPosted: Thu Mar 23, 2006 6:06 pm    Post subject: Reply with quote
I have about two inches of clearance with my side bunkers on my trailer. Couple of reason I would not adjust tighter that may be specific to my setup.
First I got rid of the lag bolts that held the side boards to the brackets and replaced with a flathead countersunk stainless 5/16 bolt. Did not counter sink the board I just wrenched the things down and they sunk into the bunker board with no problem.
Now the reason for the additional clearance. I used nylock nuts to attach to the brackets so if I want to remove sideboard with the boat on the trailer I need to get an allen wrench between the side bunker and the boat. Why would you need to remove the side boards? They get in the way when you wax the hull.
stevej
1995 25' Cruise Ship #3
PostPosted: Thu Mar 23, 2006 6:20 pm    Post subject: Reply with quote
Don-
Good point about how the hull's max width must go up inside the rails, which just might not be parallel.
I know the front and back widths are independently adjustable.
Will measure next time I see the trailer (stored elsewhere).
Joe.
rcwass
City/Region: South Berwick
State or Province: ME
C-Dory Year: 1990
Vessel Name: Lorraine J
PostPosted: Thu Mar 23, 2006 8:09 pm    Post subject: Trailer Siderails Reply with quote
I think 1/2" is just right. The hole idea of siderails is to help center the boat on the trailer. I have about 2" on each side and quite often I pull the boat out off center and have to float it again to correct it. Never took the time to adjust the siderails after the boats put away. Not too bright!
My problem now is the wood in my siderails in showing signs of wrought so I'll need to replace the wood as well as the carpet. I'd be interested in what type of adhesive to use to attach the carpet. Upholstery staples would rust quick.
Your input would be appreciated. Thanks,
Dick
SOLD IT. Bought my 1990 22' C-Dory Cruiser new in Fairfield CA. Lived in Vallejo CA. Fished the bays and the Sacramento River. Towed it across country in 1995 to Maryland. Lived in Tall Timbers MD and fished the Potomac River. Towed the C-Dory to Maine in 2001. Now settled and will be fishing the rivers, bays and Atlantic. Boats Name: Hunky Dory. Yes another "Hunky Dory".
PostPosted: Thu Mar 23, 2006 8:47 pm    Post subject: Reply with quote
Dick-
As I suggested earlier, stainless steel staples on the sides of the wood that don't face the boat seem to work.
If you want to use adhesives, resistance to extreme heat and some UV penetration would bear consideration.
Regular contact cement or Liquid Nails will work for a few years.
For a permanent fix, go to an RV dealer and get their very best urethane roof sealer, just plan on throwing away the rails with the used carpet after the carpet wears out, as you won't be getting the old carpet away from the wood without using a pneumatic muffler cutting tool!
Joe.
SeaSpray
City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
PostPosted: Thu Mar 23, 2006 10:54 pm    Post subject: Reply with quote
I have noticed that my left side guide rail vibrates when towing. Not constanly but frequently. The right side does not do this. Any one else have this problem?
I just noticed the vibrating but on the way home from Desolation Sound last Sept. that rail came loose on one end while trailering. It had pulled loose from the lag screws and it was only 1 year old.
I want to adjust that side to see if I can stop it from vibrating but it is stored elsewhere for now.
Steve
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Thu Mar 23, 2006 10:56 pm    Post subject: Reply with quote
Interesting comments. My side bunks are tight up against the hull, with about maybe 5-10 lbs of force. Even with that though, my hull wouldn't center very well between the wheel fenders (only 1/2" clearance each side). So picked up what I call "cheek blocks" from WM at $79 for the pair, they're 2x4's about 2 ft long. They're made to mount to the trailer's frame, but I mounted them to the built-in trailer ladder on the starboard side and the rear vertical strut of the side bunk on the port side. Positioned them low on the hull, just above the waterline. They are very stiff--they don't bend. My boat centers itself now everytime within +/- 1/2"; if high winds I have someone help hold a neutral position for the boat as I slowly pull out -- until the cheek blocks kick in.
Steve
PostPosted: Fri Mar 24, 2006 1:11 am    Post subject: Reply with quote
Steve-
Your solution sounds like a "breakthrough"!
If you could get a picture of it and post it here or in your album we'd appreciate it very much to help us visualize exactly how it works.
Thanks!
Joe.
Dora~Jean
Photos: Dora~Jean
PostPosted: Fri Mar 24, 2006 2:44 am    Post subject: Reply with quote
Took me several attempts to even get this site to come up, might be on its LAST LEGS...
I'll get some pics Saturday and post when I'm home in the 'daylight'. CoolSmile
Steve
Page generation time: 0.0798s (PHP: 63% - SQL: 37%) - SQL queries: 32 - GZIP disabled - Debug on
