downrigger installation question
flapbreaker
City/Region: Hillsboro
Vessel Name: Playin' Hooky
Photos: Playin' Hooky
PostPosted: Sat Apr 01, 2006 2:54 pm    Post subject: Reply with quote
Ok I still need some help. I set the scotty swivel mount on the gunnel and it looks like if I were to simply drill the holes where they have them in the mounting plate I would be either in or right up next to both of the inside walls of the gunnel. There wouldn't be room for a washer let alone a nut. I purchased the 1101 30" boom model. Any insight on how to fasten these down would be great.
MOOSE
State or Province: MN
Vessel Name: MOOSE
Photos: MOOSE
PostPosted: Sat Apr 01, 2006 4:04 pm    Post subject: Reply with quote
I mounted my Cannon swivel base not on the gunwhale but on the forward edge of the port lazarette. Two of the mounting bolts go through the top of the lazarette. The other two, which overhang the edge of the lazarette, are bolted to a big-ass chunk of SS angle which in turn is bolted through the front face of the lazarette with a SS backer plate. It's solid as the rock. You could do the same on the gunwhale which would allow you to get at least two bolts in the middle.
Al
Cutty Sark
City/Region: Kenmore, Sammamish Slough
Vessel Name: TBD
Photos: Cutty Sark
PostPosted: Sat Apr 01, 2006 9:19 pm    Post subject: Reply with quote
I had the same problem on my palmer with the scotty bases, thats why I went with the offshore mounts in the first place, but it should fit somehow, I know Tom on the Susan E has the scotty swivel bases. I'll be mounting my riggers this week or nextas well, When done I will post a pic of the bases I use.
Sark
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Sat Apr 01, 2006 9:41 pm    Post subject: Reply with quote
Flapbreaker,
Unless they have changed the width of the gunwale since 2002 it will fit. I made a cardboard template to exactly locate the mounting holes and then put it under the gunwale to check where the holes will come through. A little careful measuring should locate it right.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
flapbreaker
PostPosted: Sun Apr 02, 2006 11:34 pm    Post subject: Reply with quote
Just thought I would update my "issue". Well it would appear that in my initial haste I didn't notice that the mounting plates hole patern is a rectangle and not a square like the base so I figured out today if I just rotate the mounting plate 90 degrees the holes will fit the gunnel Embarrased Thanks for all your help. Someday I'll have something to contribute. Laughing
Page generation time: 0.11s (PHP: 90% - SQL: 10%) - SQL queries: 23 - GZIP disabled - Debug on
