NMEA 0183 GPS Buffer
PostPosted: Sun Mar 19, 2006 11:07 am    Post subject: NMEA 0183 GPS Buffer Reply with quote
Every new piece of electronics I get has a NMEA 0183 input for GPS, and the !@#$ GPS output only buffers two (TTL) loads. Does anybody know where there's a cheap buffer?
I've found several: $300, or made in England. All I need is a digital buffer. Radio Shack? Help.
flapbreaker
City/Region: Hillsboro
Vessel Name: Playin' Hooky
Photos: Playin' Hooky
PostPosted: Sun Mar 19, 2006 7:12 pm    Post subject: Reply with quote
I don't know anything about buffering NMEA. I'm not even sure what the problem is. Are you talking about a multiplexer? If so Raymarine sells one for $200 It basically lets you connect more than one "talker" together and multiple "listeners".
Almas Only
City/Region: Richmond
Vessel Name: Alma's Only
Photos: Alma's Only
PostPosted: Sun Mar 19, 2006 7:49 pm    Post subject: Reply with quote
I'm curious, too, and wondering what kind of setup you have that requires buffering?
2003 CD22 Cruiser with Honda 90
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Sun Mar 19, 2006 8:18 pm    Post subject: Reply with quote
Boris, maybe it's the difference between an engineer and a tech, but I've paralleled TTL NEMA outputs to three separate inputs before, and in spite of the specs that say "maximum of two", they've worked just fine.
You have nothing to lose by trying.
Don
Almas Only
Photos: Alma's Only
PostPosted: Sun Mar 19, 2006 10:23 pm    Post subject: Reply with quote
I see that some manufacturers indicate the spec is that a talker should have the power to talk to 2 listeners, but the following indicates 4, rather than 2, as the NMEA standard:
http://www.shipmodul.com/en/multiplexer.html
This higher number would be consistent with having 3 work fine, so long as they just listen.
PostPosted: Mon Mar 20, 2006 12:30 pm    Post subject: Reply with quote
wow, I'm impressed by the help. I do appreciate that.
I'll either try loading up the radar/gps output with three "listeners" or buy a buffer, which I found for $130. If I get a buffer, I'm sure that the GPS NMEA driver will not be overloaded and blow. Being a design engineer, I want margin (sound familiar?)
Almas Only
Photos: Alma's Only
PostPosted: Mon Mar 20, 2006 7:04 pm    Post subject: Reply with quote
Let us know how you finally get it set up, and what the results are. It would be interesting to switch back and forth between buffered and non-buffered, and see if there's any difference in performance.
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
PostPosted: Mon Mar 20, 2006 10:07 pm    Post subject: Reply with quote
I'm not entirely positive, but NMEA is a broadcast just like television. The effect of adding listeners is like adding televisions in your house. Pretty soon the signal or picture gets unusable. The buffer is really an amplifier (may also be termed a repeater) that replaces the signal lost due to splitting.
I don't think you will blow anything. It will just stop working as a result of signal being too low.
Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981-
Page generation time: 0.0272s (PHP: 75% - SQL: 25%) - SQL queries: 25 - GZIP disabled - Debug on
