Donald Tyson
Photos: Thistle
Posted: Sun Aug 31, 2025 12:35 pm Post subject: Electric Heater |
Some of you were able to break down how long something would run on the batteries I have (two 27 size AGM storage). Is this even possible to run a ceramic heater for more than a couple of hours. Would I be tremendously wiser to take a slip and use shore power for the three nights I'll be there. Kim and I are planning to visit New England during the second week of October...probably the Newport area or Mystic. We don't have a Wallace or similar.
I've heard that a cast Iron Frying pan over the Alcohol burner works well but I can't imagine it to be for any duration to speak of and safety would be questionable. While we could probably just tough-it-up and do without heat for three nights it may be nice to have it as well.
Thoughts? |
djy887
Joined: 22 Feb 2008 Posts: 33 City/Region: Bainbridge Island
C-Dory Model: 24 Tomcat
Vessel Name: Still un-named (yeah, I know)
Photos: djy887
Flashyfish
C-Dory Model: 19 Angler
Vessel Name: Kraken
Posted: Sun Aug 31, 2025 1:30 pm Post subject: |
A 12 volt 300 Watt electric heater needs 25 amps of DC power to work. With an average storage battery, you would be lucky to see an hour of heating before voltage dropped too low to continue functioning. I don't know if a 300 watt heater would make much difference. |
Joined: 02 Nov 2003 Posts: 21607 City/Region: Pensacola
Posted: Sun Aug 31, 2025 4:16 pm Post subject: |
To run a 120 V AC heater would require at east a 1500 watt inverter (12V DC to 120 V AC). On low these heaters pull 800 to 1000 watts. (80 to 100 amps 12 V DC) At this level, you are looking at about an hour max for two group 27 batteries.
A 12 volt 300 watt heater woud pull somewhere near the 25 amps (as per Flashyfish.). That would last about 4 hours, but would not really give you enough heat.
I don't like the Mr heater or Mr. Buddy. They do have oxygen sensors, but CO remaoins an issue. You can buy expensive CO meters for airplanes or less sensative househod types.
Best are the forced draft/blower type which are used in trucks and RV's. There are boat specific boat units both real Esphar or Chinese/Russian copies.
In AK we used the electric at the dock and the Wallas stovetop when on the hook. It took the chill off, but not "warm".
I have pronoucned dead all too many who have used CO producing heaters in boats and RV's....Each was a tragedy in itsef. _________________ Bob Austin
Tom Hruby
C-Dory Year: 2024
Vessel Name: WATT NOW
Photos: WATT NOW
Posted: Sun Aug 31, 2025 4:42 pm Post subject: |
As mentioned by others, two 12 V batteries will not provide enough power to heat the cabin overnight in October in Massachusetts. In my 22' cruiser I have found that I need about 500 watts to keep the cabin temperature above 65 degrees when the outside temp fall to the low 50's. Even with electric heating I still need to keep some windows open to keep the carbon dioxide levels from our breathing below 800 ppm. Carbon dioxide levels above that can lead to headaches. Any combustion based heaters without adequate ventilation will raise CO2 to toxic levels within minutes. FYI the CO2 levels we breathe out is about 40,000 ppm. Two of us in our cabin with everything closed will raise the CO2 levels to 1500 ppm in less than hour (actually measured).
Since I don't like the noise of heater fans running I am using a convection heater with a thermostat and two settings 700 and 1500 watts.
My 48 V battery bank for propulsion holds 20kWh or energy, and I do have a 48V to 120V inverter. Even with that I probably could not heat the cabin for more than a day or so. But in colder weather we do plan our cruising from marina to marina with shore power. |
robhwa
Joined: 04 Dec 2013 Posts: 319 City/Region: Anderson Island
Vessel Name: Marcia C
Photos: Problemadela
Posted: Sun Aug 31, 2025 7:44 pm Post subject: |
Though it varies, your body will produce about 100 watts of heat sleeping, or about 800 watt-hours through the night. Add a partner, and you have twice that, or more energy than a 100 amp 12 volt battery LiFePO4 battery will provide in that same time, and you don't need to recharge the heater. You can sleep warmly if you add insulation, and a mummy-style sleeping bag works fine for me. I have two that zip together, and we've been relatively comfortable in -30F winter Alberta. Add a couple of dogs, and you're golden. You really need to be careful with buddy-type heaters, which I do use, but only with great ventilation in the cockpit of my boat and in deer blinds. I also am extremely cautious about propane, which is heavier than air and can fill you cabin and cockpit if it leaks. Propane emissions produce both CO2 and water vapor, and the water vapor condenses on cold surfaces. It is best to put combustion air outside of your cabin, and to guard against the possibility of CO poisoning which Bob mentions. Webasto diesel heaters are a gold standard and well worth the investment if you use your boat in colder areas and/or places. I just took a trip south from Prince Rupert, BC, Canada, and it was always a joy to step back into a warm, dry cabin after fishing outside in the cold rain. _________________ Rob Harrison & Marcia Ciol
Anderson Island, WA
2003 22 Cruiser "Mar-C" |
Posted: Mon Sep 01, 2025 12:10 am Post subject: |
Install a Webasto heater! I had one in my 22, and now in my 25. Safe and efficient. At least as well as can be expected for an uninsulated C-Dory! Colby |
gulfcoast john
Joined: 14 Dec 2012 Posts: 1062 City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
Posted: Mon Sep 01, 2025 6:43 am Post subject: |
Hi Don from Kennebunkport, Maine aboard American Patriot.
If you’re like us (but of course you’re not), we looked for an anchoring out option power alternative that would satisfy these needs:
Cook skillet meals (we can do without a toaster oven or toaster after learning how to toast bread on the skillet) inside the cabin with ventilation or (almost always) outside in the cockpit
Make a hot, hot pot of coffee on cold mornings
Heat water for a basin bath before bed (in the percolator)
Take the chill off the air while awake in the morning
Not requiring a lot of space, a lot of energy, or a lot of expense for something we use so rarely (only three nights over six weeks on the Great Lakes Buffalo to Paducah, KY Adventure).
We had an Origo pressurized alcohol stove and didn’t like it. We eventually settled on the portable one-pound propane bottle solution to run a $29 Coleman two burner SS camp stove in the cockpit to make percolator coffee in a high-quality SS model, a skillet that can be used on either the NuWave Gold induction plate or gas (use icons are stamped on the bottom). And a Little Buddy chill-chaser we use only while awake with good ventilation and a quality CO detector with two cheaper back-ups. Never use any while underway.
Study Bob’s comments carefully, if you go this route make a 4” sewer PVC bottle holder kept hanging OVERBOARD at all times and replace the plastic caps with screw-on bronze caps. Never refill bottles and never McGyver if it won’t light. Grand Total investment under $100 for heat, coffee, meals, bathing: stows in a small out of the way cabinet. Links to these items are elsewhere on this site. The problem with cheap CO detectors is not that they don’t work, but that they alarm too easily, which is annoying. Get UL Marine approved. If you end up anchoring out frequently, other options mentioned are safer and may work better. A portable 2,000 watt generator is another option with its own dangers and space hog concerns. We agree that if cabin heat is your only desire that the diesel heater solutions are safest and best.
Enjoy and learn from the debate; there are multiple ways to skin that cat.
2010 Tom Cat 255, Cat O' Mine
2024 twin Yamaha F150 digital throttle & shift, integral electric steering
Over 7,000 water miles, 234 Locks on our Loop since 2017 |
Avidmagnum12
Joined: 23 Mar 2013 Posts: 721 City/Region: Ocklawaha
C-Dory Year: 2011
Vessel Name: C-Otter
Photos: C-Otter
Posted: Mon Sep 01, 2025 6:45 am Post subject: |
I’m sitting on the C-Otter this chilly morning in Canada toasty warm with our Webasto diesel heater. If you plan on boating in colder weather this is the way to go. Colby turned me on to this a couple years ago. Warm is good! _________________ Tom and Joyce Schulke
2004 CD 22 Commuter "Out2C" 03/10 to 06/15 |
Donald Tyson
Photos: Thistle
Posted: Mon Sep 01, 2025 8:27 am Post subject: |
GulfcoastJohn, I'm Jealous. I'd like to be anywhere from there to Bass harbor (Acadia) right now. They are my favorite areas for dead-of-summer vacation. We currently perk our coffee and we love our Origo alcohol stove. 1lb Propane has its benefits but the gas kind of scares me.
I had wanted the classic Barge heater, the Dickinson Diesel heater or similar, as I had the desire to sit in front of a radiating style of heat. There is no place to mount it. [color=red]Tom and others thanks [/color]for breaking the numbers down for me on how long a heater would last on the available batteries. We would be wise to plan our fall trips around marina stays I guess.
Robhwa, to support your advice I guess I'd have to pay 12 human heaters to lay around the cabin in order to keep it warm for us. Sleeping bag sounds like a good solution. As a kid on the farm we had 120 cows in the barn and even during zero degree weather their heat kept the air above 45-50 degrees.
diy887, I have a nice piece of 5/8 plato stand on or place a potty or heater on. nice to have a level spot.
Colby, Ya done it again. You raised the bar so high making it necessary for me to dig deeper into my pocket for more retirement money. Makes sense to get it right but it will be on next yrs budget.
Avidmagnum12 Canada is a long way from Hontoon. Hope you make it back in time. |
Joined: 27 Oct 2012 Posts: 3627 City/Region: SW Michigan
Posted: Mon Sep 01, 2025 10:58 am Post subject: |
I have used the Little Buddy heater on my 22.
It is an infrared heater, so it heats things that absorb IR, but not really the cabin air. Since it is a combustion heater it needs fresh air. The air in the cabin can get unpleasant if the heater is used without sufficient fresh air.
Used correctly, the Little Buddy heater can be useful. However, there are better solutions. |
Donald Tyson
Photos: Thistle
Posted: Tue Sep 02, 2025 10:16 am Post subject: |
Ssobel
The radiant part sounds inviting. |
