Donald Tyson
Photos: Thistle
Posted: Wed Aug 27, 2025 9:53 am Post subject: Make it shine. |
I’ve had the boat in the water four times since June. Nice boat. But it’s taking on a yellow patina from halfway down the white on the outside and down past the waterline. I’m thinking about using Maguire’s assortment of oxidation remover, polish and wax. It seems like a simple enough solution For use a couple times a year. I’m heavily invested in Ryobi tools and I figure I’ll just get the Ryobi random orbit polisher. I know we’ve talked about polishing and compounding before and I just wanted to go through this discussion again before I make a purchase. Critiques are welcome. |
Donald Tyson
Photos: Thistle
Posted: Wed Aug 27, 2025 10:54 am Post subject: |
Actually I’m not sure that I need the buffer to get the gelcoat clean. I see there are a number of options for cleaning that are wipe on or brush on and off and may work in the case of this staining I see on the lower surfaces of the boat.
I want to apply bottom paint and wonder if that shouldn’t be done before the application of wax. Certainly there will be some errant swipes with the wax. Won’t that affect the longevity of the bottom paint adhesion. |
alainP
C-Dory Year: 2011
Vessel Name: deja la
Posted: Wed Aug 27, 2025 1:22 pm Post subject: |
Donald, research "Barrier coat" and proper preparation of surface before you apply Bottom paint. |
Joined: 27 Oct 2012 Posts: 3625 City/Region: SW Michigan
Posted: Wed Aug 27, 2025 4:50 pm Post subject: |
Yellow patina is staining from tannic acid in the water.
Toilet bowl cleaner will take it off easily.
Toilet bowl cleaner will also take off any wax. |
Donald Tyson
Photos: Thistle
Posted: Wed Aug 27, 2025 5:13 pm Post subject: |
Yes to both of you. Thanks |
Pacificcoast101
Vessel Name: No Pressure
Photos: No Pressure
Donald Tyson
Photos: Thistle
Posted: Wed Aug 27, 2025 10:22 pm Post subject: |
Thanks Phil, I had just found that video and I'm ordering the Starbrite product. |
Joined: 02 Nov 2003 Posts: 21604 City/Region: Pensacola
Posted: Wed Aug 27, 2025 11:02 pm Post subject: |
The active ingredient of all of these is an acid. Oxylic acid works very well. Use the crystals and make a satuated solution. You can get a lifetime supply for $20 at most paint and hardware stores. _________________ Bob Austin
Pacificcoast101
Photos: No Pressure
Posted: Thu Aug 28, 2025 12:32 am Post subject: |
Donald Tyson wrote: | Thanks Phil, I had just found that video and I'm ordering the Starbrite product. | Toilet bowl cleaner costs less than two dollars and cleans better. https://youtu.be/6_OYSHkFIWY?feature=shared&t=107 |
Schuster
Joined: 25 Mar 2009 Posts: 197 City/Region: Port Orchard
Vessel Name: Sea Witch
Photos: Sea Witch
Posted: Thu Aug 28, 2025 9:28 am Post subject: |
Thanks for posting the cleaner comparison video. I had heard that toilet bowl cleaner works for removing stains on a hull but have never actually seen the results. The video pretty much seals the deal for Lysol and at about 25% of the cost of everything else out there 'I"M IN". _________________ Dave
(Sea Witch)
25' Cruiser |
Posted: Thu Aug 28, 2025 11:28 am Post subject: |
As pointed out in the video, you should leave the toilet bowl cleaner sit on the stain for awhile (depending on the amount of staining). Also, sometimes very heavy staining will require multiple applications.
Be sure to thoroughly rinse everything that is exposed to the toilet bowl cleaner. |
Foggy
Joined: 01 Aug 2013 Posts: 1593 City/Region: Traverse City; Northern Lake Michigan
C-Dory Year: 2014
Photos: W B Nod
Posted: Thu Aug 28, 2025 1:23 pm Post subject: |
ssobol wrote: | SNIP... leave the toilet bowl cleaner sit on the stain for awhile...SNIP |
Absolutely seems like the natural thing to do.
Aye. _________________ I wasn't born at the lake but I got there as soon as I could. |
Donald Tyson
Photos: Thistle
Posted: Thu Aug 28, 2025 5:15 pm Post subject: |
The more I read the more I feel I can pay for the Starbrite product. This boat is far and away the most expensive thing I ever bought so I can't chance damaging it. The article below was from AI. It was supported by a number of vids.
"Yes, toilet bowl cleaner can significantly damage gelcoat and fiberglass because its harsh, corrosive chemicals are not designed for boat surfaces. These cleaners contain acids and other substances that can chemically burn, yellow, streak, and enlarge the pores of the gelcoat, making it more susceptible to staining and degradation over time. It is crucial to use only marine-specific cleaning products to clean and protect the gelcoat, as bathroom and kitchen cleaners can cause irreparable harm.
This video demonstrates how to clean a fiberglass boat hull using toilet bowl cleaner:
57s
Probly Not The Best Garage
YouTube · Jun 1, 2022
Why toilet bowl cleaner is harmful to gelcoat:
Corrosive Chemicals:
Toilet bowl cleaners often contain strong acids, like hydrochloric acid, that are intended to dissolve hard water stains in toilets.
Gelcoat Degradation:
These harsh chemicals can chemically etch, degrade, and break down the gelcoat and underlying fiberglass.
Discoloration and Streaking:
The corrosive action of these cleaners can cause yellowing, streaking, and graying of the gelcoat's finish.
Increased Porosity:
The etching process creates more porous surfaces, which trap dirt and make the gelcoat more prone to staining.
Environmental Hazard:
The chemicals can also be dangerous to the environment.
What to use instead:
Marine-Specific Cleaners: Always use cleaning products specifically designed for marine fiberglass and gelcoat, such as those from brands like Mary Kate On & Off or Star Brite.
Boat-Safe Degreasers and Soaps: Opt for boat-specific degreasers and soaps for general cleaning.
Proper Aftercare: After cleaning with any acid-based product, ensure thorough rinsing and consider using a polymer sealant to protect and shine the gelcoat." |
Pacificcoast101
Photos: No Pressure
Posted: Fri Aug 29, 2025 11:04 am Post subject: |
Starbrite also contains oxalic acid. |
Posted: Fri Aug 29, 2025 4:01 pm Post subject: |
If you want to know what the active ingredient is for a compound, look up the MSD (Material Safety Data) Sheet. For Starbrite Marine hull cleaner it is 11 pages. Here is the material:
Quote: | TRADE NAME (AS LABELED): STARBRITE HULL CLEANER
PRODUCT #s: 81708, 81732BW, 81700N
SYNONYMS: Not Applicable
CHEMICAL NAME/CLASS: Oxalic Acid Solution
PRODUCT USE: Boat Hull Cleaning Compound |
You can pay Starbrite, or you can buy the ingredient in bulk and save considerabe dollars.
I don't agree with using various polymers to "seal the hull gel coat". Wax does this well, and can be removed if you want to paint or otherwise coat the boat. Some of those polymers are very difficult to remove, and will cause major problems if you do want to paint the boat down the line.
Even with the best of wax, sealants, or cermaic coating, the boat's gelcoat will still stain. |
