More Honda corrosion problems in my BF-200
forrest
City/Region: Chehalis
Vessel Name: Long Story
Photos: Long Story
PostPosted: Thu Aug 21, 2025 10:09 pm    Post subject: More Honda corrosion problems in my BF-200 Reply with quote
My BF-200 was cutting out and coming to a stall whenever I exceeded 4000 rpm. Turns out the problem was that the corrosion was so bad where the cables and fuel line entered the motor, the fuel supply was getting choked off by the corrosion buildup. If I stayed below 4000 rpm the motor ran fine. Above 4000 rpm there was not enough fuel getting to the engine. This is the motor’s 19 season so it hasn’t been a terrible run but I sure wish Honda used better metal in their castings and put neverseize on the bolts in their outboards. I’m now wishing I would have went with the Yamaha.
Robert H. Wilkinson
City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
PostPosted: Thu Aug 21, 2025 11:36 pm    Post subject: Reply with quote
Years ago I had a brake sticking on my car. Assumed it was the caliper seizing so replaced it. Problem did not go away.Turned out that a metal clamp holding the flex line was corroded and choking it. Master cyl, had enough psi to push brake fluid out to the caliper but the restriction slowed the flow of fluid back to the master cyl.
Simple fix once I found the problem.
Rob
gstraub
City/Region: Callao
C-Dory Year: 1998
Vessel Name: EnDoryFun
Photos: EnDoryFun
PostPosted: Fri Aug 22, 2025 5:39 am    Post subject: Reply with quote
I had corrosion problems in my Honda 90 that caused me to repower. Mechanic looked at it and said "typical." I've now got a Mercury.
Gerhard
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Fri Aug 22, 2025 6:48 am    Post subject: Reply with quote
Forrest,
I had internal corrosion issues with the same engine and year as yours. In my case, I could have replaced the heads and gotten a few hundred more hours, but the corrosion had also eaten away a good portion of the cooling passage around the cylinder walls. I scrapped the outboard.
There were two owners before me and the second owner was not a boat guy… clearly never flushed the outboard after use. I did know what I was buying and I was able to get 1500 hours before replacing the outboard.
http://www.c-brats.com/modules.php?set_albumName=album3405&op=modload&name=gallery&file=index&include=view_album.php
Steve Baum
Homeport of Portsmouth, VA
Page generation time: 0.0205s (PHP: 75% - SQL: 25%) - SQL queries: 17 - GZIP disabled - Debug on
