Salt Away, Garden sprayers
Donald Tyson
Photos: Thistle
PostPosted: Mon May 12, 2025 10:05 am    Post subject: Salt Away, Garden sprayers Reply with quote
Anyone have a dilution rate for salt away for general spray down of Boat after boating in salt.
I plant to use The product in a garden sprayer for boat, brakes and engine exterior. Unless we've taken a slip with dockside water I won't treat engines internally until arriving home. But I want to do brakes before and after launching whenever possible.
I see a number of you use garden sprayers. If I only had one for now what size should it be, one, two or three gallon (think storage).
Since the invention of sealed LeD taillights I no longer unhook the trailer lights. Should I ? Should I be spraying that area with salt away as well?
kaelc
City/Region: Saanich
Vessel Name: Island Magic
Photos: Stil-Afloat
PostPosted: Mon May 12, 2025 10:29 am    Post subject: Reply with quote
I have never unhooked the trailer lights and haven't had problems. I use a 1 gallon to spray down the brakes, I spray both through the wheel holes and around the back especially to get the calipers. Any of these will work. If I had a 22 single axle I'd look at a 1/2 gallon but with dual axle it's nice to have the wand https://amzn.to/4m3fYaO #ad
https://youtube.com/channel/UCnUbJzZcoK4pA-bdXpO380Q
Donald Tyson
Photos: Thistle
PostPosted: Mon May 12, 2025 10:36 am    Post subject: Reply with quote
Thanks for the info. How much product are you using per gallon. I have Surge brakes so this is likely going to be helpful to spray them down with each use.
kaelc
Photos: Stil-Afloat
PostPosted: Mon May 12, 2025 3:56 pm    Post subject: Reply with quote
I should really measure but I just dump a bunch in as I'm usually in a hurry. 1 ounce per gallon is high but the cost of trailer brakes and maintenance is a lot higher.
Pacificcoast101
City/Region: Torrance
Vessel Name: No Pressure
Photos: No Pressure
PostPosted: Mon May 12, 2025 7:48 pm    Post subject: Reply with quote
I use the hose attachment. It automatically mixes the Salt Away and water.
Phil Garner
2008 Tomcat 255
No Pressure
My Photos
Donald Tyson
Photos: Thistle
PostPosted: Mon May 12, 2025 11:02 pm    Post subject: Reply with quote
Thanks Phil,
I guess I'll order the hose attachment.
Page generation time: 0.0279s (PHP: 62% - SQL: 38%) - SQL queries: 23 - GZIP disabled - Debug on
