Donald Tyson
Photos: Thistle
Posted: Mon May 05, 2025 8:06 pm Post subject: Bimini Frame and Radar |
If our Bimini frame and top were horizontally in line with and behind the radar dome would it interfere with the radar signal to the rear? |
Joined: 02 Nov 2003 Posts: 21497 City/Region: Pensacola
Posted: Mon May 05, 2025 9:54 pm Post subject: |
No. Even sail boat masts don't normally interfere. The reason is that the magnetron (or transistorized transmitter) is on a rotating bar. The rays are parallel and the bar is over 18" wide-some on up to 12 feet, about the maximal scanner on "smaller" private boats. Inside the "dome" there is a scanner rotating. _________________ Bob Austin
