Generator Utility Platform
-Waypoint-
C-Dory Year: 1998
Vessel Name: Waypoint
Photos: Waypoint
PostPosted: Tue Feb 11, 2025 5:56 pm    Post subject: Generator Utility Platform Reply with quote
I wanted to share my final version of a fiberglass generator/ utility platform I made for my boat. I am able to use this underway at cruising speed also.
Mark n' Yuka Elwell
clayhubler
City/Region: La Center
C-Dory Year: 1986
C-Dory Model: 26 Pro Angler
Vessel Name: Merlin
Photos: Merlin and Hammerhead
PostPosted: Tue Feb 11, 2025 7:57 pm    Post subject: Reply with quote
Waypoint, that looks very slick. What generator is that?
Clay
Hammerhead
2003 22’ Cruiser
Merlin
1986 26’ Cruiser
-Waypoint-
C-Dory Year: 1998
Photos: Waypoint
PostPosted: Tue Feb 11, 2025 8:58 pm    Post subject: Reply with quote
Thanks! It’s the Honda EU2200 Companion (with 30amp socket).
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Tue Feb 11, 2025 9:25 pm    Post subject: Reply with quote
Nice work Waypoint.
Jody Kidd
KE7WNG
Northern, Utah
Schuster
City/Region: Port Orchard
Vessel Name: Sea Witch
Photos: Sea Witch
PostPosted: Wed Feb 12, 2025 10:01 am    Post subject: Reply with quote
Waypoint,
Is that 30amp socket putting lout 30 amps with the 2200 companion or is there another eu2200I in line?
Also, do the engines tilt all the way out of the water with this arrangement?
Nice work, looks professional.
(Sea Witch)
25' Cruiser
-Waypoint-
C-Dory Year: 1998
Photos: Waypoint
PostPosted: Wed Feb 12, 2025 12:27 pm    Post subject: Reply with quote
The 30 amp socket is putting out 1850watts consistent load. I have one generator, I bought the Companion model only for the 30amp plug. I found using the 20 amp plug it tends to pull out easily from the weight of the shore power cord. For me, I wanted a clean installation that’s why I am using the companion model. The engines tilt all the way up and the platform supports 350lbs of weight.
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Wed Feb 12, 2025 3:28 pm    Post subject: Reply with quote
What a beautiful job! I particularly like the molded-in foot holders. What a great idea. You obviously know your way around a shop!
I can't claim any particular expertise or skill, but I built a generator platform for my CC Venture - a boat with a full-height transom. The net relative location of the platform is about the same as yours, but I had to hang mine off the aft face of the transom to make it fit, and the generator has to ride abeam to allow full tilt & turn of the twin engines. If anyone with a CC or CD Venture model or other full-transom boat is interested, pictures are here :
http://www.c-brats.com/modules.php?set_albumName=album1468&op=modload&name=gallery&file=index&include=view_album.php
Again, my hat is off to you for great design and execution!
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
-Waypoint-
C-Dory Year: 1998
Photos: Waypoint
PostPosted: Wed Feb 12, 2025 4:25 pm    Post subject: Reply with quote
Thanks Noro Lim! This is actually my 3rd attempt at making a generator shelf. As you know how difficult this can be. I checked out the shelf you made for your boat, great idea with the aluminum bracket clips. The brace underneath of your shelf looks almost identical as the one underneath mine. Great job. I went with the raised molded foot brackets because using a sunken hole actually rotted out the wooden one that I had made before this one. Thanks again!
gulfcoast john
City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
PostPosted: Wed Feb 12, 2025 7:18 pm    Post subject: Reply with quote
Great Job, Mark!
I think multimediasmith managed to plumb a three way fuel valve after his fuel filter into a plumbed Honda Extended Run gas tank cap to make a semi-permanent system that never requires pouring gas into the Honda.
https://www.amazon.com/Extended-Compatible-Westinghouse-WH2200iXLT-Generators/dp/B08GKR4344/ref=asc_df_B08GKR4344?mcid=118fc6b388843ac0ab50110b3920d39e&tag=hyprod-20&linkCode=df0&hvadid=693613231827&hvpos=&hvnetw=g&hvrand=10904593960829868309&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9012225&hvtargid=pla-1162808246146&psc=1
Get the anti-theft Honda handle bar for the Honda grab handle for better security.
Thanks, someday maybe I'll get that...
John and Eileen Highsmith
2010 Tom Cat 255, Cat O' Mine
2024 twin Yamaha F150 digital throttle & shift, integral electric steering
Over 7,000 water miles, 234 Locks on our Loop since 2017
-Waypoint-
C-Dory Year: 1998
Photos: Waypoint
PostPosted: Wed Feb 12, 2025 8:58 pm    Post subject: Reply with quote
Thanks John! We’ll see you guys at Hontoon Island this year.
PostPosted: Thu Feb 13, 2025 12:44 am    Post subject: Reply with quote
gulfcoast john wrote:
Great Job, Mark!
I tried that one my Honda EU1000. It could not draw fuel hard enough to get a constant flow. The generator would run poorly and surge. I ended up using a 3 gallon outboard tank that I can place closer to the generator. Maybe the 2000 has better fuel suction.
PostPosted: Thu Feb 13, 2025 3:11 am    Post subject: Reply with quote
We made our Honda 2200 "theft proof" by removing the 5 mm machine screws holding the leg to the "feet" with ones of the correct thickness of the platform, with a recessed metric machine screw. No one tried to steal the Honda. It wold be unusual for a thief to carry a specific allen wrench for these SS srews.
Very nice work! Thank you for sharing with photos.
Schuster
Photos: Sea Witch
PostPosted: Thu Feb 13, 2025 10:38 am    Post subject: Reply with quote
John, or anyone with experience with the hose cap for the Honda generators. How would i get the fuel from the tank under the floor to the generator? It would seem to me that it would require a fuel pump to push the fuel up to the cap. I have the eu2000i generator on a platform similar to the one shown that sits approximately level with the top of the motor well.
Donald Tyson
City/Region: Easton
Photos: Thistle
PostPosted: Thu Feb 13, 2025 11:43 am    Post subject: Reply with quote
Hello Waypoint, Nice job on your project.
I see some sort of aluminum fuel tank across the back under the engine well. Could you describe this tank. is is a larger capacity than the normal tanks.....(learning here).
Don
-Waypoint-
C-Dory Year: 1998
Photos: Waypoint
PostPosted: Thu Feb 13, 2025 2:07 pm    Post subject: Reply with quote
Thanks! This is the original fuel tank that came with the boat. It is two tanks in one. Each side holds 27 gallons, I can hold a total of 54 gallons. I got lucky with this boat, having such a large fuel cap. When I re-powered, the tank had to come out. I had the opportunity to clean the outside tank and inspect it. This is why it looks so shiny. Thanks again.
Page generation time: 0.036s (PHP: 74% - SQL: 26%) - SQL queries: 28 - GZIP disabled - Debug on
