Donald Tyson
Photos: Thistle
Posted: Thu Dec 12, 2024 2:43 pm Post subject: Trailering a C-Dory, Trailer only |
How do you feel about towing the trailer for a 22 or 25 while the trailer is empty, especially when the trip is a couple hundred miles? I had an inexpensive trailer under my Mac 25 and it sort of shook itself apart slowly.....The wooden bunks were tha problem.
In this scenario a tag team would drop us and then return home with the trailer empty. Is this done much?
Don |
Foggy
Joined: 01 Aug 2013 Posts: 1593 City/Region: Traverse City; Northern Lake Michigan
C-Dory Year: 2014
Photos: W B Nod
Posted: Thu Dec 12, 2024 4:35 pm Post subject: |
The boat trailers I've had, including a tandem trailer for a CD 26 Venture, do not
ride well without a load; bouncing, noise, vibrations. Short distances are tolerable.
This should be no surprise since their engineering and purpose is to function
properly under load.
Aye. _________________ I wasn't born at the lake but I got there as soon as I could. |
gulfcoast john
Joined: 14 Dec 2012 Posts: 1061 City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
Posted: Thu Dec 12, 2024 5:23 pm Post subject: |
We seem to favor doing one-way segments more than most. All our 5,300 Loop segment miles since 2017 have been one-way except for the Triangle Loop into Canada, so we’ve done a lot of empty-trailer rig shuttling. The 2,000 pound trailer alone tows smooth as silk for 1,000 or 100 miles. The EOH brakes are strong enough I have to turn them way down in the cab. Trailer tires tend to be very cheaply made and a little bulge on one on a prior trailer shook it so badly that both PVC guide-on posts broke off on I-10. Goodyear Endurance ST (made in USA) tires have served us very well since we switched years ago. Just be sure you’re not buying a ‘new’ tire that’s already 2 years old. We replace all five at 36-48 months from MFG date (week/yr) stamped on the tire. Before that we’ve had six explosive structural failures with other brands over the years. Paying a good trailer shop for annual maintenance/checkup is reasonable if you’re not comfortable with doing it yourself. They found torsion axle issues that I never would have detected on my own. If it doesn’t tow well let a pro check it out. Truckers tow empty 53 foot trailers all the time.
Don’t nix the idea until you try it. It could work out just fine.
2010 Tom Cat 255, Cat O' Mine
2024 twin Yamaha F150 digital throttle & shift, integral electric steering
Over 7,000 water miles, 234 Locks on our Loop since 2017 |
Donald Tyson
Photos: Thistle
Posted: Thu Dec 12, 2024 5:26 pm Post subject: |
Hmmm. How do you do it economically if you're a trailering boater? |
outbackbill
Joined: 23 Apr 2011 Posts: 49 City/Region: Mocksville
Vessel Name: Blue Days
Photos: Blue Days
Posted: Thu Dec 12, 2024 5:27 pm Post subject: |
I have pulled my empty trailer long distances many times. I often make one way river or coastal trips by renting a car to get back to my truck and trailer. This Summer for example I launched in Trenton Ontario and did the Trent Severn waterway to Georgian Bay. We then cruised Georgian Bay to Parry Sound. We left the boat in the marina there while we rented a car for the one day trip to pick up the truck. This also kept us from doing the 45 locks twice. One small modification that I have done is to put a toggle switch near the brake controller to turn off the trailer brakes when trailering without the boat. |
Donald Tyson
Photos: Thistle
Posted: Thu Dec 12, 2024 8:40 pm Post subject: |
This is brilliant. I'm used to renting after many years on the road in sales. I usually use Priceline.
The brakes trick is nice but I'm hoping for electric brakes that work off the controller on the dash. Any thoughts on that?
outbackbill wrote: | I have pulled my empty trailer long distances many times. I often make one way river or coastal trips by renting a car to get back to my truck and trailer. This Summer for example I launched in Trenton Ontario and did the Trent Severn waterway to Georgian Bay. We then cruised Georgian Bay to Parry Sound. We left the boat in the marina there while we rented a car for the one day trip to pick up the truck. This also kept us from doing the 45 locks twice. One small modification that I have done is to put a toggle switch near the brake controller to turn off the trailer brakes when trailering without the boat. |
DayBreak
Joined: 16 Jul 2017 Posts: 1045 City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
Posted: Thu Dec 12, 2024 9:01 pm Post subject: |
EOH brakes we’re a $1400 option when we bought our new trailer. A lot of money for us at the time but glad to have them now. With experience on surge brakes, EOH is the way to go! Gary _________________ Gary F
DayBreak, 23 Venture, 2018 - present |
Joined: 02 Nov 2003 Posts: 21604 City/Region: Pensacola
Posted: Thu Dec 12, 2024 9:20 pm Post subject: |
If you are trailering long distances, get a two axel trailer for the 22. For the 25 get a trailer rated for at least 8,000 lbs. We have towed up to 1500 miles with an empty trailer--not that pleasant.
I would avoid the pure electric solenoid brakes, as used in travel trailers. They will rust out, especially if used in salt water. I know that Colby has used them--but the problem is unpredictablity as to when will fail. Surge brakes are OK--but there are issues with them. For example going down a grade they may drag all of the way, if you are using tow vehicle breaking--especially where we were using engine compression (Jake or retarder Brakes) in an RV. _________________ Bob Austin
texasair
Joined: 01 Feb 2009 Posts: 410 City/Region: Cypress, Texas
State or Province: TX
Vessel Name: Bixby's Cub
Photos: Bixbys Cub
Posted: Fri Dec 13, 2024 11:24 am Post subject: |
On long empty trailer runs, I tighten ratchet straps across my bunks and across my side guide boards.
Any where that a secure and tight strap will restrict or reduce movement and vibration will help.
Movement and vibration causes metal to fatigue, welds to crack and bolts to work loose.
Also, a significant reduction in tire pressure will greatly reduce bouncing and vibration. Just remember to air em back up before loading the boat.
A fastener that will stay tight for years on a loaded trailer will work loose in a few hours on an unloaded trailer. Re check all nuts and bolts for tightness before the trip and at gas stops.
Also check tail lights. For me long distance empty trailer towing seems to accelerate tail light failure |
outbackbill
Photos: Blue Days
Posted: Fri Dec 13, 2024 2:35 pm Post subject: |
I have EOH brakes. The toggle off switch is so that you don't have to adjust your brake settings when you pull the empty trailer. If you forget to lower your brake settings when pulling the trailer empty and have to make a hard stop the trailer wheels will lock up and wear a flat spot on your tires.I learned that the hard way. |
Donald Tyson
Photos: Thistle
Posted: Fri Dec 13, 2024 3:37 pm Post subject: |
outbackbill wrote: | I have EOH brakes. The toggle off switch is so that you don't have to adjust your brake settings when you pull the empty trailer. If you forget to lower your brake settings when pulling the trailer empty and have to make a hard stop the trailer wheels will lock up and wear a flat spot on your tires.I learned that the hard way. |
Yes you can wearer out quickly. I've used these for years and love them. Adjust them no matter the load so the trailer can't be felt pushing at all, usually power setting 3. With a load of logs it will be somewhere between 7.5 and 8.5. Having brakes lets your white knuckles relax. |
Posted: Sat Dec 14, 2024 11:21 pm Post subject: |
I pulled the new trailer home empty 700 miles, and twice on one way boat trips of about 400 miles, no real issues. Best to just check fasteners and wiring that might chaff due to more vibration. I just turned my braking down.(Electric over hydraulic). Bob brought up regular electric brakes and I’ll just say they are no more prone to failure or rusting than any other non-stainless steel brake. I’ve had more problems with EOH actuators and hydraulic calipers! (I currently have EOH, as Loadrite doesn’t offer pure electric. However I ran electric on past boat trailers and they worked well!) John likes Goodyear tires, but I’ve had much better luck with Carlisle’s. To each their own. Colby |
Donald Tyson
Photos: Thistle
Posted: Sun Dec 15, 2024 9:06 am Post subject: |
colbysmith wrote: | I pulled the new trailer home empty 700 miles, and twice on one way boat trips of about 400 miles, no real issues. Best to just check fasteners and wiring that might chaff due to more vibration. I just turned my braking down.(Electric over hydraulic). Bob brought up regular electric brakes and I’ll just say they are no more prone to failure or rusting than any other non-stainless steel brake. I’ve had more problems with EOH actuators and hydraulic calipers! (I currently have EOH, as Loadrite doesn’t offer pure electric. However I ran electric on past boat trailers and they worked well!) John likes Goodyear tires, but I’ve had much better luck with Carlisle’s. To each their own. Colby |
When I think about it there should be no difference than when I tow a box trailer or worse yet my larger Landscape Trailer. with loos floor boards and all. I learned to twist the straps so they don't sing at highway speed. On a boat trailer I picture putting ties or straps onto anything that can rattle from wind or road conditions. Grease and Oil where needed. |
Byrdman
Joined: 06 Nov 2003 Posts: 3329 City/Region: Cumberland River, Clarksville,
Photos: FreeByrd and C-Byrd
Posted: Thu Dec 19, 2024 1:37 pm Post subject: |
another thought which ive used is a weight distribution hitch which really helps on long trips and found it also keeps the trailer on the ground without a boat on it, _________________ Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
Never Deny Yourself The Pleasure of Helping Others. |
Posted: Thu Dec 19, 2024 5:48 pm Post subject: |
Quote: | another thought which ive used is a weight distribution hitch which really helps on long trips and found it also keeps the trailer on the ground without a boat on it,
"A weight distribution hitch (WDH) is generally not recommended for a boat trailer because the design of most boat trailers, with their long, narrow tongues, can cause improper weight distribution and put excessive stress on the trailer frame when used with a WDH, potentially leading to instability and damage to the trailer itself; most boat trailers are not designed to handle the forces a WDH applies to the tongue in the way a standard trailer is."
If you think about how a WDH works, you may come to realize that some of the weight on your tow vehicles rear axles is being redistributed to your trailer axles. It is the pole tongue that is being used to redistribute that weight. How much additional weight can it support? |
