JohnnyRambles
Joined: 09 May 2020 Posts: 12 City/Region: Michigan/Florida
Posted: Mon Dec 02, 2024 5:45 pm Post subject: Twin 20hp on 16ft Cruiser. Doel Fin? Permatrim? One or two? |
I recently purchased a well cared for 2002 16ft Cruiser with newer, low hour twin 20hp Mercury outboards. I'm considering adding some type of trim tabs or fins and was wondering if anyone has done this on the 16 Cruiser? Any thoughts on how one would go about Permatrims or Doel Fins on small twin engines? Should I use two? Or possibly 1/2 of a Doel fin on each engine? Or use two and trim them down? Any thoughts would be appreciated. |
DayBreak
Joined: 16 Jul 2017 Posts: 1022 City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
Posted: Tue Dec 03, 2024 10:57 pm Post subject: |
JohnnyRambles,
Surprised that nobody has gotten back to you sooner. Permatrims on your motors would be a great addition to get a better lift on your transom upon acceleration. I hope others will chime in but this addition will be cost effective for your needs. With our boat, we still do not have a Permatrim or whales tail type devise installed including trim tabs and we are still doing well. My advice is to try out your new purchase for one full year before making any changes. _________________ Gary F
DayBreak, 23 Venture, 2018 - present |
Joined: 02 Nov 2003 Posts: 21467 City/Region: Pensacola
Posted: Wed Dec 04, 2024 6:12 am Post subject: |
I have not owned a 16, but all of the C Dory seem to benefit with Permatrims. The Doel fins are not as effective (I have had one boat with the Doel Fin, which came that way. The idea is to get the bow down as much as possible for going into heavy chop--and bow up when going down wave or quartering waves aft.
With the two motors and Permatrims, you should not need trim tabs, but the 22 and 25's do better with trim tabs and Permatrims--and I am including single engine boats; not twins.
If you run on one engine at displacement speeds, with the other engine trimmed up you should get really good "fuel mileage".
It is possible that the top speed may suffer as much as a knot with the addition of the foils. But none of the C Dory (except maybe the Tom Cats) are about speed. _________________ Bob Austin
Foggy
Joined: 01 Aug 2013 Posts: 1580 City/Region: Traverse City; Northern Lake Michigan
C-Dory Year: 2014
Photos: W B Nod
Posted: Wed Dec 04, 2024 6:39 am Post subject: |
My boating experience started with a 16' wooden hull Peterborough (CA) outboard
powered by a 10 HP Johnson. I learned how to waterski behind it. Over the years,
I got "2' itis" resulting in, with many other water lovers, multiple larger boats with
single engines (mostly, but not all sailbotes [cats]) and twin engines.
The single/twin engine topic has been lashed, whipped and intimidated to death -
but I will add one more component to it I have not come across: Primary propulsion
twin engines are redundant on small boats like a 16'er.
Keeping w/in the Mfg specs on HP, I feel twin engines on power boats over 20' are
more fun, better looking, definitely heavier and more expensive - all satisfying
'want' not 'need' (which kinda says 'that is' recreational boating).
Aye.
Grandpa used to say, "You become your choices. Choose wisely". _________________ Keep an open mind just enough to not let your brain fall out. |
Joefairbanks
Vessel Name: Sjøhest
Photos: C-Darling
Posted: Wed Dec 04, 2024 6:14 pm Post subject: |
I have a 1991 16' Angler that I purchased earlier this year. I bought it with a 50hp Honda without trim tabs or fin of any kind. After reading many, many articles on here I bought a Permatrim for my boat. It has been by far the best addition on any boat that I have owned! Before adding the Permatrim, I had very little control of the bow of my boat. Sure, I could raise it and lower it a small amount by trimming the motor. Now, I can watch my bow raise or feel it getting stuffed by trimming my motor.
One thing that I noticed while installing my Permatrim- my antiventilation (cavitation) plate on my outboard was almost 2 inches lower than the bottom of my hull. I ran it once with the Permatrim with the motor at that height, then raised it up one hole on the transom. I am extremely happy with the results. I may have lost 1 mph in top speed, but I never run it WOT if I can help it any way. Having better control of my bow more than made up for the slight speed loss.
They don't add much width to the lower unit, so I would think it should fit fine running them on twins. _________________ -Ken
2006 CC23 Sjøhest
1991 CD16 Angler C-Darling Sold 2025 |
