Uploading photos from iPhone
clayhubler
City/Region: La Center
Vessel Name: Hammerhead
Photos: Merlin and Hammerhead
PostPosted: Sat Sep 28, 2024 11:11 am    Post subject: Uploading photos from iPhone Reply with quote
Is there a way to upload photos to the album from the iPhone? I always have to offload photos from the phone to the computer first. When using the site with my phone I can access the album and click on ADD PHOTOS but nothing happens.
Clay
Hammerhead
2003 22’ Cruiser
Merlin
1986 26’ Cruiser
PostPosted: Sat Sep 28, 2024 12:12 pm    Post subject: Reply with quote
Your phone saves in HEIF or HEVC format. You need to convert this to JPEG format--can be done in your i phone or computer--easiest to google, rather than post process here.
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Sat Sep 28, 2024 2:21 pm    Post subject: Reply with quote
Clay, I have a iPhone 11 Pro & the converting is done automatically. Same with my iPad. When I do like you said & click on, add a photo to an album or start a new nested album, a pop up appears to do the photo choosing uploading process. Perhaps you have pop ups blocked in your iPhone, as this has happened to me in the past, causing what you described. Presently with the new Apple OS18 I don’t see a way to control pop ups, though I just uploaded a couple photos with the iPhone using the latest OS18 & it went smoothly.
When using the iPhone or iPad & wanting to add a photo from my albums to a post, then it does have to be manually changed to a jpeg as Bob said. For me to do this, I switch from Safari to Chrome & even then a somewhat complicated process.
What has dramatically changed for me is adding video to an album. In the past it was easy to do with the process being identical to adding a photo & would go smoothly as long as the video was under a minute in length. During my Alaska cruise with my granddaughter this summer, I tried to upload video, as I have done in the past & it wouldn’t upload, no matter how short the video. I thought it was the lower upload speed, I had on the trip, but since getting back home it still won’t upload even with fiber optic speed. Other than a couple photos, I have for the most part given up photo & video uploading, until the changes, that Danag has said are coming, arrive, as I would like to arrange the photos & video in order of trip sequence, as I upload them.
clayhubler
PostPosted: Sun Sep 29, 2024 2:06 pm    Post subject: Reply with quote
Thank you. It ended up being the pop up blocker.
clayhubler
PostPosted: Sun Sep 29, 2024 2:18 pm    Post subject: Reply with quote
Next question:
Can I put photos into posts from the iPhone? I usually right click and select ‘copy image address’ on the computer but can only find ‘copy’ using iPhone. I keep getting the below:
[img] http://www.c-brats.com/modules.php?set_albumName=album3358&id=IMG_0764&op=modload&name=gallery&file=index&include=view_photo.php[/img]
Also tried it with a space before the final img:
[img] http://www.c-brats.com/modules.php?set_albumName=album3358&id=IMG_0764&op=modload&name=gallery&file=index&include=view_photo.php [/img]
Hunkydory
PostPosted: Sun Sep 29, 2024 3:02 pm    Post subject: Reply with quote
I don’t know if it can be done as you want without using Chrome on a iPhone or iPad.
It will work for me if I use Crome & go to a photo in an album & then to the photo you want to post. Touch & hold on that photo & a pop up will appear giving you a list of various choices. Choose “open image in a new tab”. This tab will now be in a jpeg format. I copy this address & paste to my post adding in front [img] & on the end [/img] & the photo will post in a C-Brat post.
clayhubler
PostPosted: Sun Sep 29, 2024 7:14 pm    Post subject: Reply with quote
Thanks Jay,
I thought it was going to work like you described because I am getting a different address using this method. This is also the same address I get when using a PC. Unfortunately I still get the below:
[img] http://www.c-brats.com/albums/album3358/IMG_0764.jpeg[/img]
Hunkydory
PostPosted: Sun Sep 29, 2024 7:50 pm    Post subject: Reply with quote
It works you just have to close the space between [img] and http
Nice photo
clayhubler
PostPosted: Sun Sep 29, 2024 9:22 pm    Post subject: Reply with quote
Oh, nice! Thank you!
Page generation time: 0.0396s (PHP: 65% - SQL: 35%) - SQL queries: 22 - GZIP disabled - Debug on
