JHans2678
Posted: Sat Aug 03, 2024 1:36 pm Post subject: 12v Water Pump |
I just purchased a 1999 22 Cruiser. The foot pump works flawlessly, but wondering if anyone has converted theirs to an electric pump? Pictures? Pump type? Thanks! |
Joined: 27 Oct 2012 Posts: 3446 City/Region: SW Michigan
Posted: Sat Aug 03, 2024 4:23 pm Post subject: Re: 12v Water Pump |
JHans2678 wrote: | I just purchased a 1999 22 Cruiser. The foot pump works flawlessly, but wondering if anyone has converted theirs to an electric pump? Pictures? Pump type? Thanks! |
I'm looking to do this on my boat. Plenty of examples and descriptions if you look at van conversion sites and Youtube videos. |
Joined: 02 Nov 2003 Posts: 20988 City/Region: Pensacola
Posted: Sat Aug 03, 2024 6:05 pm Post subject: |
One conversion I did, left the foot pump in place for most uses, but a small flow thru pump from Jabsco is turned on with a momentary switch. (I put the switch on the front of the galley cabinet. I would use the switch for filling up large containers such as the Breta filter. Adding a pressure electric pump will tend to waste water if one is not careful.
The small electric pump is not pressure activated--and is placed before the foot pump.
If you want to take showers or freshwater wash down--then this type of installation is not for you. For most others it is a good way to go. _________________ Bob Austin
Posted: Sun Aug 04, 2024 10:25 am Post subject: |
I would consider putting in an electric pump with a momentary contact foot switch in place of the manual foot pump. |
Posted: Sun Aug 04, 2024 12:34 pm Post subject: |
The pump I referred to is Jabsco part number: 42510-0000 pump only. Unfortunately these are discontinued. There is an alternate, most likely made In China:
"TMC Replacement Marine Electric Galley Water Pump with Mounting Clamp 12V for Boats and RVs, Five Oceans FO739"
For $32 I probably would take a chance. All of these are 3/8" tubing, so I used a reducer to the 3/8 and then back up to 1/2" for the tube to the foot pump and or
These pumps are not self priming, so they have to be below the top of the water column. This is another reason to leave the foot pump in series with this pump, so it will prime it. The other way would be to put the pump near the output of the freshwater tank, if yours drains from the bottom.
Occasionally I see these pumps in consignment shop. |
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Mon Aug 05, 2024 3:31 pm Post subject: |
I prefer the self priming diaphragm pumps with a pressure switch myself. Not that the centrifugal pumps mentioned don't work, because they do. |
cbbernard
State or Province: RI
Vessel Name: SEA STORY
Posted: Mon Aug 05, 2024 3:39 pm Post subject: |
Highly recommend. Mine's got an electric pump--self-priming in theory though it usually needs help at the beginning of the season--and I use it for the sink and for a freshwater washdown/coldwater shower at the transom. Like the others, I have an on/off pull switch on the captain's seat side of the galley cabinet to power it on before I use the faucet. |
