Front Window Adjuster
erichull4
City/Region: Bellingham
PostPosted: Mon Jul 29, 2024 12:20 pm    Post subject: Front Window Adjuster Reply with quote
I'd just like to post this product I recently installed to replace the worn-out front window adjuster on our 2002 22-Cruiser.
https://www.amazon.com/dp/B07H3D4H87?psc=1&ref=ppx_yo2ov_dt_b_product_details
The brackets do not match up so I drilled out all the rivets on the old and new adjusters and replaced the rivets with some screws and locknuts. I also added some nylon bushings to center the new adjuster on the bolts.
PostPosted: Mon Jul 29, 2024 12:52 pm    Post subject: Reply with quote
The OEM front window adjuster is a Sea-Dog part. (At least on my boat.)
https://sea-dog.com/groups/434-hatch-adjuster-with-swivel
C-Green
City/Region: Houghton
Vessel Name: C-Green
Photos: C-Green
PostPosted: Tue Jul 30, 2024 10:26 pm    Post subject: Reply with quote
2002 model had a funky twist nut that was hard to tighten. I threw the nut away, replaced it with a pipe coupling with the same thread as the twist nut, drilled and tapped the coupling and screwed in a wing bolt the held the original strut by friction. It worked well and still works.
Page generation time: 0.0463s (PHP: 40% - SQL: 60%) - SQL queries: 16 - GZIP disabled - Debug on
