New (used) lower unit, a new noise, an other variables
Wood Zeppelin
C-Dory Year: 1997
Vessel Name: C-Creature
Photos: Childhood Dream
PostPosted: Tue Jun 04, 2024 12:52 am    Post subject: New (used) lower unit, a new noise, an other variables Reply with quote
I was able to find a used version of the upgraded lower unit design for my 1998 Honda BF40. I got it all put together and went for a test drive today. There is a noise I never heard before, kind of a "whirring/ringing" sound that occurs between about 2000-2700 RPM.
With the motor in neutral, I can manually spin the prop just fine, no noise or anything. Here are the things that have changed since before the noise:
New (used 2007) lower unit.
New impeller
New gear case oil
New prop (different pitch as I've gone from sea level to 3000' elevation)
Elevation change: using the 3000' prop, but I'm now running at 6000' elev.
h
My fear is that after dropping $1000 on a *used* lower unit, there's something wrong with it?
Or could it be something else?
Should I even worry since it sounds just fine above and below that RPM range?
Current boats:
1988 16' Angler - "E-fishn-C"
Also:
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Tue Jun 04, 2024 10:32 am    Post subject: Reply with quote
I would put the old prop on and see what happens.
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Tue Jun 04, 2024 11:04 am    Post subject: Reply with quote
It is a gearcase and sometimes they make noises. Why? The gear contact pattern was not set up correctly, or they are worn and that is basically about it. If the noise is subtle, and the tolerances are ok inside the case, it probably is just annoying and nothing else will come of it. But the prop can cause strange noises too.
T.R. Bauer
PostPosted: Tue Jun 04, 2024 11:07 am    Post subject: Reply with quote
If you run for a few hours and then drain the lower unit oil and there are metal shavings, you have issues. Can you take it back?
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Thu Jun 06, 2024 1:56 am    Post subject: Reply with quote
Thanks for the suggestion! I confirmed today that the noise does not happen when it’s in neutral through the RPM range. It didn’t seem to be happening in reverse either.
Then I switched props, Back to my original one that I use at sea level, And the noise was gone. But what does this tell me? (it was a brand new Prop, but pitched for 3000 feet elevation. I’ve noticed it also also has a larger diameter and more surface area on the blades). is there such thing as a bad prop? Is there another Prop with the same specs as this one that would not make the noise?
I know things can get funky in the mechanical world sometimes. Is it possible that it’s a combination of this gearcase and this prop that that’s creating the noise? In other words, if I put this same prop on a brand new lower unit, might there be NO noise?
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Thu Jun 06, 2024 1:57 am    Post subject: Reply with quote
So if it’s a noisy Prop, what does that tell me? (The prop was brand new).
T.R. Bauer
PostPosted: Thu Jun 06, 2024 2:32 am    Post subject: Reply with quote
In my opinion a worn out gear case or one that wasn't set up perfectly will make the noise with any prop on it under load. I'm glad it went away.
ATPNW
City/Region: Covington
Vessel Name: Fellowship
Photos: Fellowship
PostPosted: Thu Jun 06, 2024 9:37 am    Post subject: Reply with quote
Did you get all the thrust nut/washers back on and in the correct place? Sometimes they stick to the back of the prop when you take them off. If you are missing one they can definitely make that kind of sound. You can easily tell because the back of the prop housing would be grinding metal on metal to the gear case housing. Depending on how long it was run, there might also be some free play forward and aft of the prop
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Thu Jun 06, 2024 11:09 am    Post subject: Reply with quote
Yes, thanks. I’m still a little worried about this lower unit though. Here’s Why: It came from Florida = sea level. So it’s probably used to pushing a “sea level prop” (pitch and diameter). And the noise goes away when I put my sea level prop on there. But now I’m at a significantly higher elevation, And using a correspondingly differently pitched Prop. I wonder if this prop is loading the gear case differently than its current wear pattern… and therefore causing a noise.
if this was true, (a) I assume a brand new case with fresh gears would not have any built-in wear pattern and would handle any Prop OK? And (b) would this mean that the noise is not a problem or is not causing any excess wear, but just a matter of being “broken in“?
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Thu Jun 06, 2024 11:15 am    Post subject: Reply with quote
Thanks for the suggestion. I did check that. The thrust washer behind the prop can only go on one way. I tried reversing it and things simply don’t fit that way. And when I spin the prop by hand, it was not rubbing on the housing. Anything else I could check?
T.R. Bauer
PostPosted: Thu Jun 06, 2024 12:57 pm    Post subject: Reply with quote
The prop will not impact the wear pattern on the gear set because the end play and bearing tolerances are not going to move regardless of what prop you put on it. To a small degree they are dynamic, but they are as close to static as you can get. If they were not, then you would have serious problems.
And yeah, like another person said, that thrust washer thing happens to people. But in my experience the result is catastrophic and nearly immediate. And something that will require a new aluminum case because it doesn't take much to wreck them. There might be exceptions and somebody may have gotten lucky - I just don't know of any.
The only thing I can think of is that the sea level prop changes the rpm and moves the wavelength of the soundwave to a place in the spectrum that you can't hear it....meaning it's still doing it and you just can no longer hear it. If you think everything is correct with your installation, it would not be the first gearset that makes a bit of noise with nothing really wrong with it. It's really pretty common.
But I'm glad it's gone. And I hope it stays gone. When you drain your gear oil in it at the end of the year and there are lots of pretty sparkles in it, you have real issues. If the prop shaft starts leaking it is indicator something inside isn't right as well. Hopefully none of that happens.
Salmon Fisher
PostPosted: Thu Jun 06, 2024 2:52 pm    Post subject: Reply with quote
There's also a thing called "prop sing."
Google it and you'll learn a bunch. Might be what you have with that noisy prop.
On a another boat I had, changed to a different prop and it made noise at a certain rpm. No noise under and above that rpm range.
T.R. Bauer
PostPosted: Thu Jun 06, 2024 6:40 pm    Post subject: Reply with quote
I didn't think prop "sing" was an issue with outboard motors. I learned something today.
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Fri Jun 07, 2024 8:42 pm    Post subject: Reply with quote
Here something Google led me to:
"Just jump in and use a piece of emory cloth to slightly ease the sharp ( may be squared) edges on each blade. Very quick, easy & effective
Or wait and the suspended particles in the water column will gradually do the same thing ..... but it might take a while."
Apparently it usually happens on new or recently repaired props, and a trailing edge bevel can make the difference!
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Fri Jun 07, 2024 8:43 pm    Post subject: Reply with quote
Thanks for this. Very heplful!
Page generation time: 0.0514s (PHP: 67% - SQL: 33%) - SQL queries: 32 - GZIP disabled - Debug on
