Deciphering honda part #'s - 1998 BF40
Wood Zeppelin
C-Dory Year: 1997
Vessel Name: C-Creature
Photos: Childhood Dream
PostPosted: Wed Apr 10, 2024 1:19 am    Post subject: Deciphering honda part #'s - 1998 BF40 Reply with quote
Hi,
I have a Honda 1998 BF40A that needs a new lower unit. Unfortunately the part numbers I find on the internet are more complicated than what's actually on my motor!
My motor just says: Serial# BAYL-2000958
However, Boats.net lists the following
BF40AW LHA VIN# BAYL-2000001 to BAYL-2099999
BF40AW LHTA VIN# BAYL-2000001 to BAYL-2099999
BF40AW LRA VIN# BAYL-2000001 to BAYL-2099999
BF40AW LRTA VIN# BAYL-2000001 to BAYL-2099999
BF40AW XRTA VIN# BAYU-2000001 to BAYU-2099999
I assume BF40A and BF40AW is the same thing? Or not?
How do I know which one of the these is mine?
Current boats:
1988 16' Angler - "E-fishn-C" (Project boat)
Also:
Schuster
City/Region: Port Orchard
Vessel Name: Sea Witch
Photos: Sea Witch
PostPosted: Wed Apr 10, 2024 11:13 am    Post subject: Reply with quote
This is a example of what you get when you google identify model no of Honda outboard
Honda Model Identification...
BF2
Manufacturer
Horse- power
Model
Year
Shaft
Length
Steering
System
Market
BF = Honda
EX:
2
DX = 1999
DY = 2000
D1 = 2001
D2 = 2002
D3 = 2003
D4 = 2004
D5 = 2005
D6 = 2006
DK0 = 2007- up
S = 15"
L = 20"
H = Throttle
Grip
C = Centrifugal
Clutch
A = American
EXAMPLE: BF2D1SCHA = Honda, 2 HP, 2001 Model, 15", Centrifugal Clutch w/Throttle Grip, American
BF5- BF20
Manufacturer
Special
Features
Horse- power
Model
Year
Shaft
Length
Steering
System
Starter
Market
BF = Honda
P = High Thrust
Propeller
= Standard
Propeller
EX:
5
20
D1 = 2001
D2 = 2002
D3 = 2003
D4 = 2004
D5 = 2005
D6 = 2006
DK0 = 2007-up
S = 15"
L = 20"
XL = 25"
H = Throttle
Grip
C = Centrifugal
Clutch
S = Electric
= Manual
T = Electric w/ Power Tilt
A = American
EXAMPLE: BFP5D1LHSA = Honda, High Thrust Prop., 5 HP, 2001 Model, 20", Throttle Grip, Elec. Start, American
BF25- BF225
Manufacturer
Horse- power
Model
Year
Shaft
Length
Steering
System
Tilt & Trim
Market
BF = Honda
EX:
25
115
225
AX = 1999
AY = 2000
A1 = 2001
A2 = 2002
A3 = 2003
A4 = 2004
A5 = 2005
A6 = 2006
K0 = 2007-up
S = 15"
L = 20"
X = 25"
XX = 30"
R = Remote
Control
H = Tiller
Handle
T = Tilt & Trim
= Manual Tilt
J = Jet Drive
A = American
EXAMPLE: BF25A1LRTA = Honda, 25 HP, 2001 Model, 20", Remote Control, Tilt & Trim, American
NOTE: After the 2006 model year Honda Marine dropped specific year designations.
Sometimes it takes a little scratching around to find exactly what you want.
https://bpi.ebasicpower.com/faq/hondamodels.html is the page i was on.
Good luck.
(Sea Witch)
25' Cruiser
Schuster
Photos: Sea Witch
PostPosted: Wed Apr 10, 2024 2:45 pm    Post subject: Reply with quote
Here is another link that may help you identify your motor. You have to know a little about your motor to identify it, shaft length, remote control, eic . Once you've determined the model # then you can search the parts catalogue for a replacement. Hope this helps.
https://www.hondaoutboardbits.com.au/honda-serial-numbers/
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Sun Apr 14, 2024 2:01 am    Post subject: Reply with quote
Thanks, this is helpful!
Page generation time: 0.0568s (PHP: 62% - SQL: 38%) - SQL queries: 23 - GZIP disabled - Debug on
