Karl Konecny
Vessel Name: Nowhere Fast
Photos: Nowhere Fast
Posted: Tue Mar 19, 2024 11:02 am Post subject: How do you prevent trailer connector contacts from corroding |
I'm still fairly new at boating in salt water and have a question: what is the best protocol for preventing trailer connector contacts from corroding? I'm having issues with intermittent connections to my trailer that appear to be caused by corrosion. _________________ "Believe me my young friend, there is nothing-absolutely nothing-half so much worth doing as simply messing around in boats."
Rat to Mole, Wind in the Willows |
drbridge
Vessel Name: Susan Marie
Photos: Susan Marie
srbaum
Joined: 30 Aug 2010 Posts: 909 City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
Posted: Tue Mar 19, 2024 12:41 pm Post subject: |
Silicone grease. It’s synthetic, won’t damage plastic or rubber products and is a dielectric. _________________ Steve Baum
Homeport of Portsmouth, VA
-Waypoint-
Joined: 02 Nov 2019 Posts: 123 City/Region: Jensen Beach, Florida
C-Dory Year: 1998
Vessel Name: Waypoint
Photos: Waypoint
Posted: Tue Mar 19, 2024 1:20 pm Post subject: |
I second the importance of a good ground. I chased bad grounds last year on my trailer. Found out that the wiring was corroding under its insulation only getting 7 volts to the back of the trailer. Trailer is only 4 years old. I replaced all my wiring with heaver gauge tinned marine wiring, problem solved.
Not cheap at $1/ft. Having lighting issues before going to the ramp could wreck a good boating day. _________________ Mark n' Yuka Elwell |
Karl Konecny
Posted: Tue Mar 19, 2024 10:44 pm Post subject: |
Thanks for all the tips, I bought some contact cleaner and will give it a try. I've thought about dielectric grease but my truck sees lots of dusty roads and the cover on the trailer hookup doesn't keep all the grime out. I'm concerned the grease will just turn to mud, anybody have that problem? |
Posted: Tue Mar 19, 2024 11:18 pm Post subject: |
We have used a light coat of the electrical grease or Corrosion block. The contact cleaner is just that: a cleaner. The corrosion block or grease is preventative maintenance. _________________ Bob Austin
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Wed Mar 20, 2024 12:41 am Post subject: |
Best wishes preventing it entirely. They always get corroded eventually. The dielectric grease suggestion is good advice. |
Schuster
Joined: 25 Mar 2009 Posts: 181 City/Region: Port Orchard
Vessel Name: Sea Witch
Photos: Sea Witch
Posted: Wed Mar 20, 2024 12:12 pm Post subject: |
I also agree that a dielectric grease is the proper way to attempt to reduce corrosion. It would also be a good idea to have that cleaner to clean out the dust/grime build up occasionally. The idea is to prevent salt water from contacting the electrical conduction areas and the grease will be most helpful in that regard. Good luck. _________________ Dave
(Sea Witch)
25' Cruiser |
srbaum
Vessel Name: Osprey
Photos: Osprey
