2023 C-Dory 22 Cruiser Charging Diagram
Post new topic   Reply to topic    The C-Brats Forum Index -> Documents
LJM
City/Region: Lynch Station
C-Dory Year: 2023
PostPosted: Mon Mar 11, 2024 6:30 pm    Post subject: 2023 C-Dory 22 Cruiser Charging Diagram Reply with quote
Hello all!. About a year ago I tried to locate a charging diagram for my cd22. I called the mfg and was told they were working on one. I have checked their web page recently and still have not located one.
Attached is a charging diagram that I made after chasing wires down. I look forward to any comments especially if someone sees a glaring error.
Thanks in advance,
Larry
Scan Mar 11, 2024 at 17.57.pdf
 Description:
Download
 Filename:  Scan Mar 11, 2024 at 17.57.pdf
 Filesize:  488.79 KB
 Downloaded:  175 Time(s)
PostPosted: Mon Mar 11, 2024 7:09 pm    Post subject: Reply with quote
I think you'll find that there are a lot of differences in the electrical systems between boats. Some are rigged at the factory and some are rigged by the dealers. There is a wide range of possible configurations.
I don't have a diagram for my setup, but I know it is different from your schematic.
PostPosted: Mon Mar 11, 2024 10:24 pm    Post subject: Reply with quote
Not sure where to start. Do you have two house batteries?. If so how are they arranged and connected? Do you have a "on/Off" switch or "1,2,all, off switch? The battery output, except the starter, should have a fuse within 7 " of the battery. Most C Dory's have a 60 to 100 amp breaker, which all of the "house circuits go to. The starter should be fed directly off the engine start battery.
I realize that Scan Marine and instructions say to connect the Wallas stove/heater directly to the battery. You still need a fuse within the 7". I use a separate wire (positive and neg) properly sized to allow no more than 3% voltage drop with the start up load. I would wire and fuse for 15 amps, with a run of 30 feet for a 22. (the length is the round trip--not just one way between the battery and stove).
The one wire from the battery output post should go directly to a fuse block (Blue Seas # 5026, which is twelve outputs.) Often the boats come with a smaller fuse block and several wires off each terminal. Best practice is one off each terminal. Sometimes it pays to put in a second fuse block.
I put in a Victron monitor (702 to 712 or smart shunt) to monitor the house battery bank. I replace the main wire to the console, with one considerably larger: at least #10. Preferably #8 or #6.
Do you have a windlass? How is the circuit for that arranged? Maybe I missed the battery charger? I usually replace it with better model. What charger did your boat come with?
The VSR should be directly connected to the start battery and then the output directly to the house batteries. The VSR combines the house bank and start battery when the start battery reaches 13.7 Volts. It drops the house load at 12.7 Volts.
This is a start. I would label every wire you have both at end use (appliance or electronics) and origin.
LJM
C-Dory Year: 2023
PostPosted: Tue Mar 12, 2024 6:46 pm    Post subject: Reply with quote
Bob, thanks for taking a look at my schematic and taking the time to comment.
Your questions are as follows:
1. Do you have two house batteries?
No only one and it’s the very reason I’ve taken this boat apart to discover how it’s wired. I want to add a second house battery. I’ll probably put it under the sink and wire it in parallel to the existing house battery.
2. What kind of switch do I have? It’s a 1,2,all (Blue Sea)
3. There is a 100 amp circuit breaker between the house battery and the load. Nothing between the starting battery and the engine.
4. If the stove instructions say to wire it to the battery then that why it was initially wired that way … I’ll change it back.
5. I want to add a Victron monitor… is the shunt connected to the negative buss? If so there are two… one behind the dash and one in the starboard battery box. Which did you connect to?
6. Yes this boat came with a windless with dash mounted controls. I’m wiring in a handheld controller to allow me to be near the anchor as it comes up or near the rope locker as needed.
7. The battery charger is a three bank 20 amp model.
Thanks again,
Larry
Post new topic   Reply to topic    The C-Brats Forum Index -> Documents All times are GMT - 5 Hours
Page generation time: 0.06s (PHP: 55% - SQL: 45%) - SQL queries: 23 - GZIP disabled - Debug on
