Window screens for 1999 22?
BigSwede
State or Province: MN
Vessel Name: Coddiwomple
PostPosted: Mon Feb 05, 2024 9:18 pm    Post subject: Window screens for 1999 22? Reply with quote
My "new" 1999 22 does not have window screens. The sliding side windows appear to have an extra track on the inside that might accommodate a screen, although I'm not sure how you would operate the sliding glass on the outside of the screen.
I have searched and read about some of the DIY ideas, but I'm wondering if there ever was a factory setup for screens?
PostPosted: Mon Feb 05, 2024 11:03 pm    Post subject: Reply with quote
Good luck finding any screens. My 25 was missing the screens from the port aft window and the head window. I tried getting them from NMI, since they make the boats, but no luck. They suggested Sea Glaze the maker of the window. No luck there either. I finally just fabricated my own window screens using PVC board to make a frame. The problem with finding any commercial provider or screen shop, is that these screens are not square of with square corners. And nobody wants or can make the rounded corners...
BigSwede
PostPosted: Tue Feb 06, 2024 12:43 pm    Post subject: Reply with quote
Thanks - I sent an inquiry to Advantec (SeaGlaze) on the advice of another member, so we'll see if anything comes of that.
I wonder if a guy could make a screen frame out of heavy wire, like the wire they use to hang suspended tile ceilings in commercial buildings?
PostPosted: Tue Feb 06, 2024 4:19 pm    Post subject: Reply with quote
Don't think that would last. It works well enough in buildings because it is pretty much only in tension.
BigSwede
PostPosted: Tue Feb 06, 2024 7:25 pm    Post subject: Reply with quote
I have a few pieces of ceiling wire that I use to hang brake calipers when working on my truck, seems like it might be stiff enough to hold its shape, if handled gently. Maybe.
PostPosted: Tue Feb 06, 2024 8:20 pm    Post subject: Reply with quote
I think your best bet for making screens is to fabricate a frame out of wood or plastic. You can find or plane something down to the appropriate thickness. Cut out the center then to install the screen. I then routed a groove all the way around for the screen retainer to be pressed into.
gulfcoast john
City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
PostPosted: Tue Feb 06, 2024 8:37 pm    Post subject: Reply with quote
Listen to Colby.
I don't, but many years of experience here have shown that I should have.
Good luck!
John and Eileen Highsmith
2010 Tom Cat 255, Cat O' Mine
2024 Yamaha F150xsa x2
Page generation time: 0.0285s (PHP: 61% - SQL: 39%) - SQL queries: 24 - GZIP disabled - Debug on
