Cleaning bottom antifouling paint
vaugse
City/Region: Wilmington
C-Dory Model: 19 Angler
PostPosted: Mon Feb 05, 2024 8:10 pm    Post subject: Cleaning bottom antifouling paint Reply with quote
Is there some sort of mat available to catch the bad stuff when I wet sand the bottom coat? Also, through the years I sanded a lot without protection. Am I in danger of, well, bad stuff? 19' C. dory since 1993
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Wed Feb 07, 2024 6:42 am    Post subject: Re: Cleaning bottom antifouling paint Reply with quote
vaugse wrote:
SNIP Am I in danger of, well, bad stuff? 19' C. dory since 1993
I am sorry to tell you this. I will try to to be gentle.
For one reason or another, sooner or later, the Grim Reaper claims everyone.
You are included.
Aye.
PostPosted: Wed Feb 07, 2024 11:31 am    Post subject: Reply with quote
Most folks use a blue polypropylene tarp. Then vacuum it up.
Hard to say about health hazard--may shorten your life span, but since 1993 and you are still alive. The amount and nature of toxins depends on the paint. I sanded some of the really toxic stuff back in the 1940's, and have lived to be 87. In later years I did wear a respirator and mask.
PostPosted: Wed Feb 07, 2024 12:25 pm    Post subject: Reply with quote
Wet sanding would also help.
Robert H. Wilkinson
City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
PostPosted: Wed Feb 07, 2024 3:46 pm    Post subject: Reply with quote
The op did say he was wet sanding so I will assume he is looking for a solution to catching the runoff. A tarp might work if you raised the edges to make a dyke then a wet vac to clean out the pool. Not sure if he is looking to remove material down to the gel coat - or just to clean and rough up the surface prior to recoating.
The only wet sanding I have seen boaters do is racing sailors burnishing their bottom coat to gain a knot or 2 but it is a very messy operation since you are working overhead with everything falling on you and yes many bottom coats contain some nasty and toxic substances.
I did a lot of wet sanding on cars when base/clear paint became popular. Still have an air power wet sander that a hose hooks up to and water runs out through holes in the sand paper. If any members have a use for it I will ship it for a very reasonable price.
Good luck with your project,
Rob
Reelin2
City/Region: Ferndale
C-Dory Year: 1990
Vessel Name: Go Fish
Photos: Reelin2
PostPosted: Wed Feb 07, 2024 10:22 pm    Post subject: Reply with quote
If you are looking to remove antifouling paint. I used paint stripper for the thick stuff and sanded the balance. Wear a respirator.
Page generation time: 0.0436s (PHP: 42% - SQL: 58%) - SQL queries: 19 - GZIP disabled - Debug on
