Ideal wiper setup
pcg
City/Region: Sherwood
Vessel Name: C-Quest
Photos: pcg
PostPosted: Fri Jan 12, 2024 2:08 am    Post subject: Ideal wiper setup Reply with quote
I’m looking for your opinions on what the ideal window wiper setup on a 22’ Cruiser would be. The new 22 I saw at the Portland Boat Show today has electric pantograph wiper blades mounted at the top of the windows. My ‘99 came with manual wipers mounted at the bottom of the windows. As part of my restoration I have removed all hardware (discarded the old wipers) from the hull and filled most holes, so I’m starting from scratch. I want powered wipers and I’ve purchased a single 2-speed Ongaro wiper motor to experiment with. I like the idea of mounting the motors at the top of the windows. What about wiper arms? Any particular make or style? Pantograh? What’s your vision for an ideal configuration? Thank you!
Paul
C-Wolfe
Vessel Name: Valhalla
Photos: C-Wolfe
PostPosted: Fri Jan 12, 2024 2:35 am    Post subject: Reply with quote
That is my setup on my 2006, probably similar to what you saw at the boat show. It work great for me and I can't think of better option. Let me know if you need better picture or anything else, boat is not the easiest to get to but I'll try.
Good luck on your project.
Stephan
clayhubler
City/Region: La Center
Vessel Name: Hammerhead
Photos: Hammerhead
PostPosted: Fri Jan 12, 2024 7:37 am    Post subject: Reply with quote
The fans are just about as important as the wipers. I like C-Wolfe's dual fan setup.
Clay on Hammerhead
Schuster
City/Region: Port Orchard
Vessel Name: Sea Witch
Photos: Sea Witch
PostPosted: Fri Jan 12, 2024 10:44 am    Post subject: Reply with quote
I have the same set up as C-Wolfe on my 25', it has the panographic wiper arms and allows for a complete wipe of the windows. I also like his fan set up and may come up with a modified version of that with a couple of small box fans. Good luck.
(Sea Witch)
25' Cruiser
C-Wolfe
Photos: C-Wolfe
PostPosted: Fri Jan 12, 2024 12:29 pm    Post subject: Reply with quote
The Fans are great, if it's raining, they are on.
Xtraplus18
City/Region: Vancouver
Vessel Name: C-Handler
PostPosted: Fri Jan 12, 2024 5:46 pm    Post subject: Reply with quote
Where did you get the fans from. I need to add a few to my boat?
C-Wolfe
Photos: C-Wolfe
PostPosted: Sat Jan 13, 2024 1:31 am    Post subject: Reply with quote
The fan was installed by the previous owner, I don't think it's a known name brand, most likely not available anymore. In a quick search, I did not find any comparable.
PostPosted: Sun Jan 14, 2024 10:00 pm    Post subject: Reply with quote
I have these in my boat. They've gotten to be kind of pricey over the last couple of years, but work well.
https://www.amazon.com/Caframo-Ultimate-2-Speed-Direct-White/dp/B00TLF2ZDA/ref=sr_1_12?crid=3IF0DLD05PTYJ&dib=eyJ2IjoiMSJ9.HV7hX8ewRDz6H1KlxZWzqts_xv8pqpoAmLDlOiPMMig0uNOrI8hefw7jxLjQEsw2eW2fKQZ4uunsh2YCEUTXuzkTTa6nqvt234zYt3ZuX_Riqx0psF_Wln7oWpZ4QuvN90Wx265SruhrVaqVQ-QpIw.rhSBP7LydLJ9eO62qawFS3SXtAHUHlEFvSmhpKeiXaY&dib_tag=se&keywords=caframo+fan&qid=1705287399&sprefix=caframo+fan%2Caps%2C373&sr=8-12&ufe=app_do%3Aamzn1.fos.18ed3cb5-28d5-4975-8bc7-93deae8f9840
-Waypoint-
C-Dory Year: 1998
Vessel Name: Waypoint
Photos: Waypoint
PostPosted: Thu Jan 18, 2024 1:40 pm    Post subject: Reply with quote
https://www.amazon.com/Gaiatop-Powerful-Portable-Personal-Adjustment/dp/B09LQN6815/ref=sr_1_3?crid=2FWHM1J2RPCX5&dib=eyJ2IjoiMSJ9.D8XGYHFv8lmzj9D-ADlxhfOHu6_RIFbzg5xqKaFwae4_dtDlJlxZYcAOJF6MIo5i-Lq74COx1MgO95l8DAAYl4x2zQ3_WoaoUnOHRSF33AnHwjcUR2RchxQD0cSUTOOHyA4mEECxYG39tYfNBCwtUTvT0xmMKFOoDrQGtGrSNwNgiZcByJhhd5HxP3PDEjbXvJ-0tfBKc09nkuYzmTRTQTIi3C15c_h8rqSVVRIoPbE.0ohSuA4sn2ckob_FsvOi-gHpC6CJP_sxf7oSfzZlAMc&dib_tag=se&keywords=usb%2Bfan%2Bfor%2Bdesk&qid=1705602865&sprefix=USB%2Bfan%2Caps%2C119&sr=8-3&th=1
Here's is what I am replacing my Calframo fans with; 5v USB fans they draw 2 watts on high speed, super quite, .5 watts on low speed, and move a lot of air for $8! I bought 2 of them so far...
Mark n' Yuka Elwell
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Thu Jan 18, 2024 2:27 pm    Post subject: Reply with quote
We replaced our original computer fans with these. They will work on USB or batteries. Very pleased with them. On Amazon for $12 each
Honeywell HTF090B Turbo on the Go Personal Fan, Black – Small, Portable Fan
Page generation time: 0.0337s (PHP: 76% - SQL: 24%) - SQL queries: 23 - GZIP disabled - Debug on
