Repowering a 2009 22 Cruiser
Gungho
City/Region: Pender Island
Vessel Name: Nomad
PostPosted: Fri Dec 15, 2023 10:25 am    Post subject: Repowering a 2009 22 Cruiser Reply with quote
I know this topic has been kicked around previously but seems like many years ago. My current set up is with twin 40hp Yamahas. Should I stay with twin 40 or 50 Yamahas or go to a single Merc 90-115 with a kicker? Any feedback would be appreciated. Thank you in advance
Flashyfish
City/Region: Windsor
C-Dory Model: 19 Angler
Vessel Name: Kraken
PostPosted: Fri Dec 15, 2023 10:59 am    Post subject: Reply with quote
If you need the redundancy and safety factors with having two motors stay with the present setup.
Otherwise, a single larger outboard offers advantages in maintenance costs, transom weight savings and simplicity.
I have owned several new fuel injected 90 and 115 hp motors over the years and found them to be reliable and trouble free. No big secrets, fresh filtered fuel treated with stabil and doing the routine maintenance.
Gungho
Vessel Name: Nomad
PostPosted: Fri Dec 15, 2023 11:05 am    Post subject: Reply with quote
Thank you Flashy for your response. I don't think the weight is that much different when adding a kicker to the equation. I will double check. Thanks
PostPosted: Fri Dec 15, 2023 12:45 pm    Post subject: Reply with quote
First why do you want to re-power? (I note that the engines had 930 hours when you bought the boat about a year and a half ago.). I am aware of many of those motors getting 2,000 hours. On the other hand, if there is a reliability issue, the going with new is a wise move. There can be multiple other reasons.
How well do the 2 40 hp motors fit your needs? Can you envision a reason to go with a single and kicker (such as lower speed for trolling for salmon? If that is a need--go with the single and kicker
I happen to be a single and kicker guy, only having owned one boat in over 65 years of owning power and sail boats which were suited for offshore use that I owned a boat with twin engines, and that was a 42' "trawler/motor yacht. I have never owned twin outboards...
Jay of Hunkydory fame, choose to re-power with twin 60's, because he could get better speed if lost one engine, and often has a heavily loaded boat.
Here is a link to his excellent thought process on re-powering with twin 60's. A must read for someone in your "boat".
Gungho
Vessel Name: Nomad
PostPosted: Fri Dec 15, 2023 1:13 pm    Post subject: Reply with quote
Thanks for your reply. Good work knowing the boat. The main reason is in the time I've owned the boat it has been out of the water with engine issues for 4 weeks (month of August) and now. First issue required a new stator and idling problems with both motors and now one engine wouldn't start and the other can't run with any load on it. The shaft to the lower end is stuck and the mechanic hasn't been able to remove. Says the lower ends haven't been removed for some time. I was hoping they could be fixed but ... At this time I don't have any confidence in these motors and don't feel they are reliable any more. Thank you for the link
PostPosted: Fri Dec 15, 2023 3:00 pm    Post subject: Reply with quote
That certainly is a good reason to get new outboards! Ouch~!
One of my friends didn't do a sea trial, or have a mechanic look at the 150 on a C Dory 25 he bought...The first time he used it, the engine overheated. The corrosion was so bad, the engine was scrapped. New Suzuki set him back about $ 15K. That was before Covid, and prices have gone up.
Gungho
Vessel Name: Nomad
PostPosted: Fri Dec 15, 2023 4:03 pm    Post subject: Reply with quote
Just got back from the mechanic and he has the shaft out of the motor but it's now stuck in the lower bushing. Still not off. I think at this point I'm going to wait and see if he can fix. Get the other fully serviced. May just replace one. Thanks for the discussion. Till next time lol
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Fri Dec 15, 2023 4:54 pm    Post subject: Reply with quote
I've said it before and I'll say it again: more is better.
Review a previous post:
You're gonna love'em if they're propped right.
I've never regretted making the "more vs less" power choice;
cars, trucks, boats or bikes.
Get the most HP, attending weight. You can always slow down
with higher HP, but, in need, can never ask for more from
underpowered engine(s).
Aye.
"I don't want any cake" - said no one ever.
If someone tells you they don't eat cake, unfriend them. You don't need that kind of negativity in your life.
PostPosted: Fri Dec 15, 2023 9:44 pm    Post subject: Reply with quote
Unless that more is in fuel and weight. Mr. Green
PostPosted: Sat Dec 16, 2023 10:41 am    Post subject: Reply with quote
Foggy wrote:
I've said it before and I'll say it again: more is better. ...
Or water inside your boat.
drbridge
Vessel Name: Susan Marie
Photos: Susan Marie
PostPosted: Sat Dec 16, 2023 1:49 pm    Post subject: Reply with quote
We have had our 22 Cruiser for 9 years now. Had a Honda 90HP originally and re powered with a 90HP Yamaha a few years ago. We travel fully loaded from Sequim to Desolation Sound and the Discovery Islands and also use it for fishing in the Strait of Juan De Fuca as well as off shore when conditions allow. I have never once had a need for more power. We also have a 8 HP Honda to get us home if needed. Only had to use it for that purpose once. That is when we decided to re power with new Yamaha due to corrosion issues with the Honda.
Doug & Susan
PostPosted: Sat Dec 16, 2023 3:32 pm    Post subject: Reply with quote
I had a 115 on my 22, because that's what it came with. I found when running (racing) with other 22's that had the 90's, I maybe only had about a knot or two on them. At normal cruising speeds their fuel flow was better though! Maybe I could have towed more behind the boat, but I wasn't a towboat!
Gungho
Vessel Name: Nomad
PostPosted: Sun Dec 17, 2023 12:02 pm    Post subject: Reply with quote
Thank you for all your input. Much appreciated.
Reelin2
City/Region: Ferndale
C-Dory Year: 1990
Photos: Reelin2
PostPosted: Tue Dec 26, 2023 2:36 pm    Post subject: Reply with quote
I repowered with a Mercury CT 115 last year, couldn’t be happier. I went with a 25” shaft with a manual jackplate as the boat lives in the water six months of the year. I cannot comment on the twins as they were junk when I bought the boat.
-Waypoint-
C-Dory Year: 1998
Vessel Name: Waypoint
Photos: Waypoint
PostPosted: Wed Dec 27, 2023 8:57 am    Post subject: Reply with quote
I repowered my boat last year with new 2022 EFI, Honda BF40 twins. Replaced the exact same engines 26 years newer. Repowering cost with rigging nema 2000 everything, latest controls, new SS props, $18,000. The boat feels like it has a 115 hp. with the torque of the twins! Easy to replace no holes added to the transom or to fill. For my boat this was an easy decision.
Mark n' Yuka Elwell
Page generation time: 0.0391s (PHP: 69% - SQL: 31%) - SQL queries: 33 - GZIP disabled - Debug on
