Mounting a crab pot puller
rock knocker
City/Region: Georgetown
PostPosted: Fri Dec 08, 2023 3:48 pm    Post subject: Mounting a crab pot puller Reply with quote
We just got a commercial crab pot puller for our 22ft angler
My question is we have to mount the bottom plate to floor. How much room is there on bottom and sides to put lag bolts?[/u]
PostPosted: Fri Dec 08, 2023 6:49 pm    Post subject: Re: Mounting a crab pot puller Reply with quote
Most boats have an inch and a half of balsa core between the hull bottom and cockpit floor FG skins. If you have a later boat with the flat floor in the cockpit, there is a void between the inside of the flat floor and the top hull skin.
The hull sides are solid FG about 3/8 inch thick.
If it were my boat I would not be using lag bolts for this application. Mounting something that is going to have good load on it will require through drilling, a backing plate, and fastening with nuts and bolts.
My boat does have a few lag bolts on it. But these are used for loads that are only in compression (i.e. not pulling on the bolts).
PostPosted: Fri Dec 08, 2023 11:29 pm    Post subject: Reply with quote
Another way to secure an item to a floor or side of the C Dory (I agree not to use lag bolts!) is to either epoxy or 5200 a block of wood (like teak or Iroko) PVG lumber or Coosa board are alternatives. When using any glue or adhesive, which takes time to cure, I hold the piece in place with hot glue until the adhesive cures. You can put a "T" nut or threaded insert on the back side of the board, and then run a bolt into that, given you a good strong area for the foot of the hauler.
Captain Starbucks
City/Region: Tacoma
Vessel Name: DOUBLE BARREL
Photos: Captain Starbucks
PostPosted: Sat Dec 09, 2023 1:10 am    Post subject: Reply with quote
Take it back and get the Scotty. Small, light, powerful albeit a bit slower than the commercial one but the Scotty plugs into a downrigger mount. Customer service is top notch. I've pulled up large shrimp pots offshore in 600' with 900' of line plus anchors. No problems.
Current boats
12' Lund with oars
17' Grumman expedition
Previous boats
DayBreak
City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
PostPosted: Sat Dec 09, 2023 9:06 pm    Post subject: Re: Mounting a crab pot puller Reply with quote
rock knocker wrote:
We just got a commercial crab pot puller for our 22ft angler[/u]
Another way to mount your puller is by using a Burnewiin mount with a Scotty Swivel Mount. We have used this to pull crab pots that were full and very heavy. We also use the same Burnewiin and a Scotty Swivel Mount for our electric downrigger pulling a 15 lb. ball with no problems.
http://www.c-brats.com/modules.php?set_albumName=album2856&id=Scotty_DownRigger_Mounted_to_Burnewiin&op=modload&name=gallery&file=index&include=view_photo.php
http://www.c-brats.com/modules.php?set_albumName=album2856&id=Mount_Adapter_Plate&op=modload&name=gallery&file=index&include=view_photo.php
http://www.c-brats.com/modules.php?set_albumName=album2856&id=Davit&op=modload&name=gallery&file=index&include=view_photo.php
http://www.c-brats.com/modules.php?set_albumName=album2856&id=Burnawin_Mount&op=modload&name=gallery&file=index&include=view_photo.php
Gary F
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Mon Dec 11, 2023 11:18 pm    Post subject: Re: Mounting a crab pot puller Reply with quote
look in my album Thumbs Up Thumbs Up
You do not want to LAG bolt a puller!
[url][/url]
Hellsranger
City/Region: Bellingham
C-Dory Year: 1991
Vessel Name: Golden Heart
Photos: Golden Heart
PostPosted: Thu Dec 14, 2023 3:56 pm    Post subject: reply to rock knocker Reply with quote
IMHO tsturm's install is the way to go. I have personally seen an entire scotty mount fail, along with a sizable chunk of the fiber glass it was mounted to.
What's so funny bout
peace, love and understanding?
Page generation time: 0.0455s (PHP: 50% - SQL: 50%) - SQL queries: 24 - GZIP disabled - Debug on
