Water puddle
Cowman10
City/Region: Gainesville
Vessel Name: Piper Jane
PostPosted: Mon Nov 13, 2023 9:11 am    Post subject: Water puddle Reply with quote
i have a situation that baffles me. My Cdory 22 is sitting on the trailer in my yard. Every day i find a puddle of water accumulated just inside the door. i have emptied the water tank and changed the hoses. There is no source of water left in the boat but yet i still find a water puddle in the same place. I'm wondering if the heavy dew is leaking into the cabin somehow. has anyone ever had this issue?
Love the C-life
PostPosted: Mon Nov 13, 2023 10:32 am    Post subject: Re: Water puddle Reply with quote
It is a fairly common problem. The lowest part of the boat is the aft part of the cabin at the aft cabin wall. In some cases, the aft cabin bulkhead is not sealed properly from the factory. In the case of the '08, the raised flat floor leaves a gap between the edge of the flat floor and the exterior face of the aft cabin bulkhead. The simple solution is to apply a sealant to this gap all the way across the hull. Another solution is to re-glass the joint where the aft cabin bulkhead meets the hull from the inside of the cabin. Sealing the gap from the outside also helps in keeping water from getting under the raised floor if the factory sealing is not complete.
Cowman10
PostPosted: Mon Nov 13, 2023 12:26 pm    Post subject: Reply with quote
Thank you for the reply. I will try your recommendations!
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Mon Nov 13, 2023 5:11 pm    Post subject: Reply with quote
Your "puddle" volume was not mentioned.
So, one explanation could be condensation. FL days can be warm, nights cool.
The day's humidity condenses on cooling surfaces overnight forming water
that runs down accumulating on the floor, aft in the cabin, if your trailered boat is
inclined slightly bow up to accommodate bilge drain.
Solution:
1. Increase ventilation in the cabin
2. Use water absorbers (DampRid, etc) in the cabin
3. Move North (there's room)
Aye.
"I don't want any cake" - said no one ever.
If someone tells you they don't eat cake, unfriend them. You don't need that kind of negativity in your life.
C-Wolfe
Vessel Name: Valhalla
Photos: C-Wolfe
PostPosted: Mon Nov 13, 2023 9:12 pm    Post subject: Reply with quote
Solution:
Aye.
Not too far north because then that same problem comes back.
Stephan
Page generation time: 0.0265s (PHP: 68% - SQL: 32%) - SQL queries: 22 - GZIP disabled - Debug on
