pcg
Vessel Name: C-Quest
Photos: pcg
Posted: Sat Nov 04, 2023 3:09 pm Post subject: anchor roller selection |
I'd like advice on what sort of anchor roller/retrieval system I should use on my 22' Cruiser. This is a restoration project starting from a bare hull so I can basically do anything I want at this point. I've purchased a Rocna 13# anchor and Lewmar H700 windlass.
What do you suggest for an anchor roller setup? _________________ Paul |
Joined: 02 Nov 2003 Posts: 21501 City/Region: Pensacola
Posted: Sat Nov 04, 2023 5:36 pm Post subject: |
Be sure to put a backing plate or at least fender washers on the back side of the bolts attaching both the anchor roller and the windlass. I usually use 1/4 to 5/16 aluminum as the backing plate. Easy to drill with a hand drill (although I use a drill press). It cuts easy with a coarse tooth hacksaw.
I have just used the standard bow roller which comes on the boats--but at times it is better to have the articulating plate Colby mentions.
I noted that you have a chain stopper on the foredeck in your photos. This is only meant to hold the anchor when you are running or trailering. It should not take the load if you are anchored. You want the bow anchor line to be cleated off, no load on the windlass. You only use the windlass to take up slack as you power to right over the anchor. Use the boat to pull the anchor out of the sea bottom, and then use the windlass to raise the anchor from the bottom. Often you will need to either use a brush, or back the boat down with the chain and anchor in the water to get all of the mud off. Remove any debris manually. _________________ Bob Austin
clayhubler
Joined: 03 Aug 2019 Posts: 374 City/Region: La Center
Vessel Name: Hammerhead
Photos: Merlin and Hammerhead
Posted: Sat Nov 04, 2023 5:45 pm Post subject: |
I use one like the one Colby linked to and I like it even though I think my delta would launch with a fixed roller. The original anchor when I got the boat was the lewmar claw and it held well but I had to go on the bow every time to dislodge it. _________________ Clay
Hammerhead
2003 22’ Cruiser
Merlin
1986 26’ Cruiser |
pcg
Photos: pcg
Posted: Sun Nov 05, 2023 6:20 pm Post subject: |
thataway wrote: | ...I noted that you have a chain stopper on the foredeck in your photos. This is only meant to hold the anchor when you are running or trailering. | Thanks, I didn't even know what that was. All hardware has been removed from the deck now and all holes filled in so I'm starting from scratch. Is that chain stopper necessary to hold the anchor when running or trailering? Can the tension provided by the windlass serve the same purpose, or should the windlass not be used for that and the anchor tied off to a cleat instead, while running or trailering? |
drbridge
Vessel Name: Susan Marie
Photos: Susan Marie
Posted: Mon Nov 06, 2023 2:51 am Post subject: |
We also use the Pivoting Self-Launch Roller. It works really well. The other thing about this type of roller is that the anchor rides a lot lower When it is up, allowing for better viability while running. _________________ Doug & Susan |
Posted: Mon Nov 06, 2023 9:47 am Post subject: |
pcg wrote: | thataway wrote: | ...I noted that you have a chain stopper on the foredeck in your photos. This is only meant to hold the anchor when you are running or trailering. | Thanks, I didn't even know what that was. All hardware has been removed from the deck now and all holes filled in so I'm starting from scratch. Is that chain stopper necessary to hold the anchor when running or trailering? Can the tension provided by the windlass serve the same purpose, or should the windlass not be used for that and the anchor tied off to a cleat instead, while running or trailering? |
That chain stopper is for when trailering or running. It is not made to take the load of anchoring. I prefer to tie the anchor with a line and carabiner (one of the few uses of a carabiner on a boat. I fix the inboard end with an eye splice over the main cleat, which I left right behind the Windless.
There are other chain stoppers, which are made to take the load of the chain (using snubbed) but I don’t see the sense of these on our small C Dorys. |
pcg
Photos: pcg
Posted: Tue Nov 07, 2023 12:32 pm Post subject: |
Thank you all! I ordered the bow roller that Colby recommended. |
