Battery switch
rock knocker
City/Region: Georgetown
PostPosted: Tue Oct 31, 2023 4:51 pm    Post subject: Battery switch Reply with quote
Just bought our 2004 angler 22. My question is what battery selection should I run my switch on? 1,2 or all? Last owner said he runs on #2 with no issues. There's 2 batteries. One big one where all the wires are hooked to marked 2. Smaller one marked 1 just has positive and negative cables hooked to it. Thank-you for any advice.
PostPosted: Tue Oct 31, 2023 6:18 pm    Post subject: Reply with quote
You should start your engine with the smaller (probably a group 24 battery) and then switch to "all". This allows a both batteries to be charged as your outboard is running and charing. After you stop, and are going to be at anchor, drifting etc, you should shift to the House battery. In your case the larger of the two.
There is a better way, that most of us use: That is to use an automatic combiner, called a voltage sensitive relay or automatic charging relay. This allows the engine to start on the proper battery, then as that batter begins to charge automatically switches to charge both batteries. They will be combined until the charging stops, and then will again isolate the starting battery,
You should have one one or two wires attached to the house battery. If there are multiple wires, you need to be using a positive and negative bus bar. All of the circuits should have a fuse within 7" of the battery. To start with, be sure that all terminals are bright and clear, including the negatives. Retighten the connections and then coat with a protective grease. (I use a product called corrosion block.)
Enjoy the "new" boat! Post some photos.
PostPosted: Tue Oct 31, 2023 11:28 pm    Post subject: Reply with quote
This also depends on how your wiring is hooked up. I learned that my Yamaha 150 outboard has an alternate charging post. Battery 2, my starting battery, is connected to that post, and is always charging when the engine is running. (This battery is also connected through the main battery switch, so can be charged through the normal way as well.) My house battery is only charged through the main battery switch. Before learning about the alternate charging, I would start my engine with battery 2, then switch to both batteries to charge. Once I learned about the alternate charging wiring, I would start on 2, but then switch my battery switch to 1.
Page generation time: 0.0399s (PHP: 38% - SQL: 62%) - SQL queries: 16 - GZIP disabled - Debug on
