General info regarding chips, scratches to fiberglass
NickyD98
City/Region: San Jose
C-Dory Year: 2020
C-Dory Model: 19 Angler
Vessel Name: Giuliana Marie
PostPosted: Sat Sep 30, 2023 9:09 pm    Post subject: General info regarding chips, scratches to fiberglass Reply with quote
Hi there! I’m a relatively new CDory owner (Angler 19) and very new to fiberglass boats. I found this little scratch on the bottom of the hull(just slightly in the gel coat). How many fellow CDory owners end up with chips etc? I know it’s not good to get the fiberglass wet, but I’m sure not every fiberglass boat is in mint condition either. Thank you for any advice. I’m finding myself paranoid about chips and scratches worrying if one that’s unnoticed goes it will lead to a very costly repair. I’ve had bad luck getting little chips etc from rocks on the highway. I’ve never had any of the damage occur in the water.
PostPosted: Sat Sep 30, 2023 9:25 pm    Post subject: Re: General info regarding chips, scratches to fiberglass Reply with quote
NickyD98 wrote:
Hi there! I’m a relatively new CDory owner (Angler 19) and very new to fiberglass boats. I found this little scratch on the bottom of the hull(just slightly in the gel coat). What’s your opinion on it and how many fellow CDory owners end up with chips etc? I know it’s not good to get the fiberglass wet, but I’m sure not every fiberglass boat is in mint condition either. Thank you for any advice. I’m finding myself paranoid about chips and scratches worrying if one that’s unnoticed goes it will lead to a very costly repair. I’ve had bad luck getting little chips etc from rocks on the highway. I’ve never had any of the damage occur in the water.
IMO, chips in the fiberglass on your boat are like dings you get in your car over time. You can obsess about them and fix every one as they occur or you can accept them as a fact of life and not worry about it.
That said, as long as the chip is only in the gelcoat it is cosmetic. If it goes through to the fiberglass mat you should do something about it to prevent water intrusion. You can repair it with gelcoat or seal it with something else like epoxy.
There are plenty of videos on gelcoat repair on YouTube. There is a certain amount of artistry involved to get the color to match. Experience helps here.
Be aware that for small chips you will have to make the "wound" bigger in order to get good adhesion with the new gelcoat.
My boat has its share of dock rash. Some I fixed, others I let go. Every so often I make a day of repairing the dings in the gelcoat.
One thing to look at is the bottom of the boat. You can hit a variety of things in the water and may or may not register a hit. The trailer can also wear away the gelcoat or cause dings when launching or retreiving. If you keep your boat on a trailer a periodic crawl underneath looking for damage is something I suggest you do.
In my case, I've never noticed any damage from trailering. Got a number of dings from operation on the water though.
DayBreak
City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
PostPosted: Sun Oct 01, 2023 1:37 am    Post subject: Reply with quote
[quote="NickyD98" I’ve had bad luck getting little chips etc from rocks on the highway. I’ve never had any of the damage occur in the water.[/quote]
You may want to consider keeping the rock chips off the gelcoat in the first place. We bought Rock Tamer Mudflaps and find that they keep the chips off our boat virtually 100%. We are quite pleased with the results.
https://www.etrailer.com/Mud-Flaps/Rock-Tamers/ERT00108.html
Gary F
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Sun Oct 01, 2023 7:08 am    Post subject: Reply with quote
So, whattsup with ''dings an' things''? Or,
"Why doesn't my new stuff stay looking that way forever?"
ssobol got it: it's "a fact of life"
(aka The Second Law of Thermodynamics).
For a spontaneous process, the entropy (aka 'chaos') of the universe increases.
And, it never decreases.
Aye.
NickyD98
C-Dory Year: 2020
PostPosted: Wed Oct 04, 2023 1:28 am    Post subject: Reply with quote
Thank you everyone for your feedback. Much appreciated!!
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Wed Oct 04, 2023 9:31 am    Post subject: Reply with quote
Another thumbs up for Rock Tamers.
Page generation time: 0.0345s (PHP: 61% - SQL: 39%) - SQL queries: 20 - GZIP disabled - Debug on
