Wood Zeppelin
C-Dory Year: 1997
Vessel Name: C-Creature
Photos: Childhood Dream
Posted: Sat Sep 02, 2023 1:26 pm Post subject: My boat has an amazing Suspension system in choppy water |
Who new a boat could have a suspension!?!
It's so cool. As soon as the hull starts to bang, it's just enough vibration to make the throttle level "throttle back" a hair, which slows the boat down just enough to not bang anymore! Then I get the most speed possible while still having a relatively smooth ride! Ingenious! Who thought of this!?
So, is this actually by design? (I'm guessing not).
Actual question (tuning the suspension!): Can the throttle lever be adjusted to be either more or less likely to slip back? _________________ James Salay - Real Estate Broker / Investor, Engineer, Artist, Fisherman, Canyoneer, Outdoor Enthusiast
Current boats:
1988 16' Angler - "E-fishn-C" (Project boat)
Also:
14.5' Drift Boat - "Wood Zeppelin" |
Joined: 27 Oct 2012 Posts: 3386 City/Region: SW Michigan
Posted: Sat Sep 02, 2023 1:31 pm Post subject: Re: My boat has an amazing Suspension system in choppy water |
Wood Zeppelin wrote: | ... Actual question (tuning the suspension!): Can the throttle lever be adjusted to be either more or less likely to slip back? |
There should be a friction adjustment in the control binnacle. Might be under the cover. Depends on your setup. |
Joined: 02 Nov 2003 Posts: 20860 City/Region: Pensacola
Posted: Sat Sep 02, 2023 2:48 pm Post subject: |
I cannot recollect owning a boat where the throttle would change due to speed or vibration. I would much rather have a boat where the throttle setting remains the same. If it will give a better ride and be easier on the boat. I want to control that. Nothing to do with "suspension". _________________ Bob Austin
Robert H. Wilkinson
Joined: 26 Jan 2011 Posts: 1236 City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
Posted: Sat Sep 02, 2023 4:06 pm Post subject: |
https://www.youtube.com/watch?v=z5oXmOG_2Q8
Nauti Craft with suspension ride. _________________ Talk to me and I will listen-- but if its not about boats or fishing all I will hear is bla,bla,bla,yada,yada,zzzzzzzz |
Foggy
Joined: 01 Aug 2013 Posts: 1524 City/Region: Traverse City; Northern Lake Michigan
C-Dory Year: 2014
Photos: W B Nod
Posted: Sun Sep 03, 2023 11:26 am Post subject: |
I do not know a qualified source that recommends allowing a motorized vessel
to find its own sea condition ride comfort level, i.e., depend on hull banging to
lessen throttle and soften the ride.
My understanding: it is the vessel operator (aka captain, the one in charge) who
has the duty and responsiblity to safeguard the vessel, it's surrounds and it's
occupants while underway.
One such function is to set course and speed, adjusted per conditions, to
maintain comfort and safety for the afore mentioned throughout the voyage.
Aye. _________________ "I don't want any cake" - said no one ever.
If someone tells you they don't eat cake, unfriend them. You don't need that kind of negativity in your life. |
Joined: 01 Mar 2005 Posts: 7447 City/Region: from island boy to desert dweller
Posted: Sun Sep 03, 2023 2:47 pm Post subject: |
Pretty sure the OP's question was tongue-in-cheek. Your throttle will have a tension adjustment screw, depending on the motor/model under the shroud around the throttle. |
Foggy
C-Dory Year: 2014
Photos: W B Nod
Posted: Sun Sep 03, 2023 9:35 pm Post subject: |
JamesTXSD wrote: | Pretty sure the OP's question was tongue-in-cheek. Your throttle will have a tension adjustment screw, depending on the motor/model under the shroud around the throttle. |
I agree that throttles, I have experienced, have an adjustment to regulate the
resistance to maintain a given position at the desired engine rpm. Tongue-in-
cheek printed comments are confusing to decipher without more information.
Without tone and body language, words alone, especially brief and printed, do not
convey clear meaning. It's all about accurate communication.
Take the following: "A woman without her man is nothing."
So, who is nothing; the man or the woman? Add some inflection...
"A woman, without her man, is nothing." (Conclusion, the woman is nothing.) Then...
"A woman, without her, man is nothing." (Conclusion, the man is nothing.)
Same words. Different meaning. Thus, words alone can mislead and create
misunderstanding.
Aye. |
