terry alexander
Vessel Name: raven
Posted: Mon Aug 28, 2023 6:03 pm Post subject: Winterizing my 25 |
I'm winterizing my 25 here in valdez. I'm going to put the rv antifreeze in my fresh water tank and then turn on the pump to charge the lines. How do I bypass the hot water heater? Seems like there should be a bypass valve. |
Schuster
Joined: 25 Mar 2009 Posts: 178 City/Region: Port Orchard
Vessel Name: Sea Witch
Photos: Sea Witch
Posted: Mon Aug 28, 2023 7:23 pm Post subject: |
Terry, I have a 2007 25' cruiser and it is plumbed for bypass of the hot water tank. You might post a picture of the piping, someone will be able to analyze it. _________________ Dave
(Sea Witch)
25' Cruiser |
Joined: 02 Nov 2003 Posts: 21375 City/Region: Pensacola
Posted: Mon Aug 28, 2023 7:37 pm Post subject: |
In a 2008 25 there will be a drain valve in the bottom of the hot water heater. Also in my last 25 there were dual water lines from a manifold after the water pump, so there was a greater volume of hoses to fill with the RV antifreeze. We removed the factory water heater, cut out these extra hoses, and put a 2 1/2 gallon Bosch water heater right under the galley sink. This got rid of the dead space of water you wasted trying to get hot water for both the sink and the shower. _________________ Bob Austin
terry alexander
Vessel Name: raven
Posted: Mon Aug 28, 2023 7:55 pm Post subject: |
Thanks Dave. I'll try that. And thanks Bob, great idea. I'll look into doing just that. Just finished two months fishing here in Valdez. Great season and I absolutely love the new boat. Loved my 22 but this one is a big step up |
rshuman531
Vessel Name: Raven
Photos: Raven
Posted: Thu Aug 31, 2023 9:06 pm Post subject: |
On our 25(also named Raven) we installed an RV bypass for the water heater tank, easily available at Camping World, etc. That way you drain your HW heater and use much less RV antifreeze for your system. Don't forget the shower and the head. _________________ Raven 1983 22’ Classic, 2009-2020
Raven 2004 25’ Cruiser, 2020- |
