Pelican
Joined: 13 Aug 2021 Posts: 20 City/Region: Port Townsend
Posted: Sun Jul 16, 2023 9:51 am Post subject: Outboard hydraulic lifter rams |
I have twin Honda 40’s on my 2006 C Dory transom. The port engine just started giving me trouble when I lift it out of the water. It makes a grinding kind of noise and only comes half-way up. I’m wondering if there’s a place to add hydraulic oil to each lifter ram. The starboard side works fine. Or maybe I need a new ram. Where is the pump that operates those rams? Are they independent? Is there one reservoir? Or any reservoir? So many question. Brats often have an answer. Thanks. |
tsturm
Joined: 01 Nov 2003 Posts: 1135 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Thu Jul 20, 2023 9:18 am Post subject: Re: Outboard hydraulic lifter rams |
Pelican wrote: | I have twin Honda 40’s on my 2006 C Dory transom. The port engine just started giving me trouble when I lift it out of the water. It makes a grinding kind of noise and only comes half-way up. I’m wondering if there’s a place to add hydraulic oil to each lifter ram. The starboard side works fine. Or maybe I need a new ram. Where is the pump that operates those rams? Are they independent? Is there one reservoir? Or any reservoir? So many question. Brats often have an answer. Thanks. |
Look in the owners manual?
Yes you can add trim/tilt oil to your motor. The pump is bolted to the trim/tilt assy.
Google? |
