22 Cruiser top speed - with a used 75hp motor
murthog
City/Region: NANAIMO
Vessel Name: Lu-C
PostPosted: Thu May 25, 2023 9:35 am    Post subject: 22 Cruiser top speed - with a used 75hp motor Reply with quote
Just adding to the database. A 2009 75hp Yamaha, with over 850 hours shown, powered our 22' Cruiser - with a normal 2-person fishing load, to 26.9mph yesterday. Admittedly it was a perfect boating day off Nanaimo, BC.
I was considering a larger motor, but I'm OK now....
WCF
City/Region: Central
PostPosted: Thu May 25, 2023 11:45 am    Post subject: Reply with quote
Just to add to the 75hp data:
Similar setup/weight with a 2006 Mercury 75 4-stroke (Standard model, carbs, Yamaha-made powerhead, 1.6L) consistently saw 32 MPH on GPS @5500 RPM with a 17 pitch 3 blade prop.
Acceleration and performance in strong currents improved when going to a new 115 with a 15P 4-blade, but the main difference is really just the noise level and fuel use.
murthog
Vessel Name: Lu-C
PostPosted: Thu May 25, 2023 6:31 pm    Post subject: More data... Reply with quote
I neglected to mention that the 75hp was a 4-stroke; and that this speed was at 4900 rpm.
Bennet trim tabs engaged.
The Yamaha manual says 5000-6000 rpm is WOT. I tried it at higher RPM, but that seemed to produce more noise and greater fuel use, but not significantly greater speed.
I have not identified the prop on mine yet but will do so as a new spare came with the boat and may be a different configuration.
Page generation time: 0.0435s (PHP: 34% - SQL: 66%) - SQL queries: 17 - GZIP disabled - Debug on
