Finzup
State or Province: NY
Vessel Name: Finz-up
Posted: Wed May 24, 2023 8:30 pm Post subject: C-Dory Construction |
What type of resin (polyester, vinylester or epoxy) is used in the construction of a C-Dory?
Can epoxy be used in hull repair work? |
Joined: 02 Nov 2003 Posts: 21497 City/Region: Pensacola
Posted: Thu May 25, 2023 12:18 am Post subject: |
Epoxy is often used in repairs because of its secondary bonding strength is better than Polyester and Vinyl Ester resin.
Older C Dories were done with polyester resin. No epoxy in current or old boats. It is possible that vinyl ester resin is used for the first couple of layers currently, but check with the factory. _________________ Bob Austin
