Hydraulic leaking - Honda BF90HP - 2007
jep27
City/Region: New Haven
State or Province: VT
Vessel Name: Lunasa
Photos: Lunasa
PostPosted: Sat May 27, 2023 6:46 pm    Post subject: Hydraulic leaking - Honda BF90HP - 2007 Reply with quote
Hey --
I have a Cape Cruiser (Venture) 26 - 2007 with twin Honda 90hp outboards.
Getting ready to launch this spring (Vermont, so there are definitely seasons.. ) - I discovered leading from the hydraulic motor on one engine.
Through a Honda shop, 'O' rings were replaced and things we re-packed.. BUT, a leak persists and, with dye, it seems confirmed that there is a crack in the housing of the unit.. which leaks a small amount of fluid during the down-cycle of the motor.
* Option suggested by the shop (good guy) is replace the full unit with Honda cert. part ($ 2,600.) -- OUCH.
I'm 'calling a friend' on this forum .. to see if others have inputs and options? Maybe there is a reputable 'rebuild' option? or some other way to approach this??
If the consensus is to just buy the full price part, etc.. Id appreciate that validation as well.
Thanks-- Jeff
jep27
PostPosted: Sat May 27, 2023 7:47 pm    Post subject: Re: Hydraulic leaking - Honda BF90HP - 2007 Reply with quote
jep27 wrote:
Hey --
Thanks-- Jeff
Best solution is to replaced the cracked part. You may be able to find someone that can weld over the crack, but that could distort the cylinder.
Might depend on how much it leaks. You could decide just to live with it and carry fluid to top the system off as necessary.
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Sat May 27, 2023 11:01 pm    Post subject: Reply with quote
Give this company a call.
https://five-star-marine.myshopify.com/
My friend has his trim/tilt repaired.
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
PostPosted: Sun May 28, 2023 2:01 am    Post subject: Reply with quote
Either the 5 star as suggested by Salmon Fisher, or e-bay has used units.
Page generation time: 0.0341s (PHP: 54% - SQL: 46%) - SQL queries: 22 - GZIP disabled - Debug on
