2004 C-Dory 25 For Sale, Washington
Blase-Jean
City/Region: hoodsport
Vessel Name: San Souci
Photos: San Souci
PostPosted: Sun Apr 30, 2023 4:53 pm    Post subject: 2004 C-Dory 25 For Sale, Washington Reply with quote
* 2004 C-Dory 25 Cruiser/ Trawler in Washington state
* Professional up-grade with solid, high-density closed-cell foam
core below water-line as well as cabin and cockpit floors
* Tandem axle JohnCo all-aluminum trailer with hydraulic breaks. New
low friction bunk pads, excellent tires and spare.
* Clean functioning cruising boat, 6.5 ft cabin headroom and large
V-berth.
* Powered by 2005 115 HP Mercury (Yamaha power head/engine) with
396 hours and 10 HP Mercury auxiliary with manual and electric start as
well as charging.
* Fuel consumption at 6-7 Knot trawler speed in 7 KN per gallon.
* Many extras including those added since 2019: Swim platform and
ladder, Lewmar anchor windlass with foot control, 50 ft, 5/16" chain
and 200 ft, 1/2 nylon rode, 2-100 watt solar panels, Sunbrella Bimini, 2-
batteries, Cannon down-rigger, LED lighting through out, bow flood and
cockpit lights.
* Kenyon Homestrand double burner alcohol stove and induction plate.
* Chest fridge/freezer, 12 and 110 volt.
* Standard Horizon VHS radios (1 hand-held).
* Teleflex hydraulic steering, hydraulic trim tabs, new windshield wipers
and motors.
* Raymarine C-Series Radar and Chart Plotter, Garmin Sonar and Fish
finder.
* Flowscan 9000 fuel monitor, NMEA network, allowing fuel consumption,
range and speed to be displayed in real time.
* Raymarine Smart autopilot.
* Full custom window coverings.
* Seat and V-berth cushions in good condition.
* Trailer with boat tow very well by a 4 Liter SUV (5000 tow capacity)
* Boat has been stored, heated under RV port.
* Extras included with boat: Portable 6 gal. fuel tank (new), Complete
engine and electronics manuals, Jensen stereo and Bose speakers,
secondary anchor, chain and rode, dock line and fenders, full cabin floor
mat, spare aluminum prop, 8 ft Saturn inflatable dingy with 3 HP, 4cycle
kicker (new), Dometic marine head with pump out port and manual
pump out, new but uninstalled, shower pump and instant water heater,
engine spare parts.
* $65,000
donnerwetter
City/Region: Midcoast
State or Province: ME
PostPosted: Sun May 07, 2023 8:09 am    Post subject: Reply with quote
Is foam replacement something I should be looking for in any 2004 25 cruiser? I’m looking at one that is much less expensive and wouldn’t want to overlook something that critical - thx.
PostPosted: Sun May 07, 2023 11:11 am    Post subject: Reply with quote
No, in several ways balsa is a better core material. Just don't put holes in it, without putting epoxy plugs to seal any core material. Any foam can delaminate, and that is still an issue if water gets underneath the inner glass layer. The core gives the "I" beam effect. If there is loss of adherence to either layer, the "I" beam effect is lost.
Perhaps the seller can enlighten us as to why the boat was recored. The owner did put a thread up about the record. But I would ask if all interior furniture was removed, and if the fuel tank was removed. Usually this is because there is water intrusion, delimitation and rot. Recoring is a major repair, especially under the fuel tank (which is under the cockpit) and it is difficult to know if there is core failure under the tank, until the tank is pulled. Unless the tank is in perfect condition, I would replace it when the cockpit deck is off.
With the 115 hp outboard, you will be basically limited to hull speed or 7 knots. You can push the boat faster, but not up to the 18 to 30 mph which most 25's will reach. Many go to 200 hp when repowering the 25's.[url][/url]
Page generation time: 0.0466s (PHP: 68% - SQL: 32%) - SQL queries: 20 - GZIP disabled - Debug on
