White pastes I see on water hoses, sewer hoses, and such?
serpa4
City/Region: Melbourne
C-Dory Year: 2018
Vessel Name: DayLo
Photos: DayLo
PostPosted: Tue Apr 25, 2023 9:58 am    Post subject: White pastes I see on water hoses, sewer hoses, and such? Reply with quote
What is the white paste used to help seal hoses on barbs like the raw water pump, sewer lines, etc.?
I've seen white paste used for "threaded" pipes, but not sure what the goo is that is on hoses with barbs. It seems pliable after years of being on my old hoses; still tackey..
2018 C-Dory Venture 26. Suzuki DF200A,autopilot, solar, 412ahr of lithium.
PostPosted: Tue Apr 25, 2023 11:30 am    Post subject: Reply with quote
I cannot speak to the practice in 2018, but earlier in the C Dory history, the factory put one of the Bostek Sealants on the hose barbs. I guess they felt that that give more security on the connection. The standard practice should be double clamp hoses to the thru hull fittings. I don't know how well this material (similar to 3M 4000) sticks to the fittings, or tubing. This is either the same or very similar to the material they used to seal the cabin top to the cabin side walls (as well as one layer of tabbing). The reason I know about this is when I received my Tom Cat 255, there was no caulking between the cabin top and sides. C Dory sent me 9 tubes of this sealant.
An aside, I have had issues with some hose barbs and tubing; for this I used "form a gasket" by Permatex, #2, (non hardening, approved for air craft). This works well in critical conditions, but with heat it will loosen. I am not sure about heat on the material which C Dory used. You may want to contact the factory.
Robert H. Wilkinson
City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
PostPosted: Tue Apr 25, 2023 2:06 pm    Post subject: Reply with quote
When removing old hose some techs will slice it length wise down the barb with a razor knife. This can score the peaks of the barb and under pressure I have seen it leak even well clamped.
Rob
drbridge
Vessel Name: Susan Marie
Photos: Susan Marie
PostPosted: Tue Apr 25, 2023 5:54 pm    Post subject: Reply with quote
Standard pipe thread Teflon pipe sealant is often used on barbed fittings. It does two things. It acts as a lubricant to help a tight hose slide over the barb and it also helps to seal the fitting once it is clamped tight.
Doug & Susan
serpa4
C-Dory Year: 2018
Vessel Name: DayLo
Photos: DayLo
PostPosted: Tue Apr 25, 2023 7:51 pm    Post subject: Reply with quote
Thanks. Will use that Teflon paste to assist.
forrest
City/Region: Chehalis
Vessel Name: Long Story
Photos: Long Story
PostPosted: Wed Apr 26, 2023 10:49 am    Post subject: Reply with quote
Boil a pan of water on your stove. Dip the end of the hose in the pan of hot water for a minute or two. The hose will slip right over the barbs while hot and supple. Tighten the clamp on the soft end of the hose over the barbs. It will won't leak.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Wed Apr 26, 2023 8:46 pm    Post subject: Reply with quote
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up
I use a heat gun.
What ever was used at the factory in 2003 on all the hose barbs I have found pieces of it in the valves of my fresh water pump.
Bad idea to use any sealant on a hose barb. As far as scoring a barb so bad removing a hose that a clamp won't seal, if it leaks replace it!
If you can't push a new hose on a barb warm it up.
Mr. Green
Page generation time: 0.0244s (PHP: 70% - SQL: 30%) - SQL queries: 20 - GZIP disabled - Debug on
