Steering is very stiff left and ok to right. Autopilot stall
Goto page 1, 2, 3  Next
serpa4
City/Region: Melbourne
C-Dory Year: 2018
Vessel Name: DayLo
Photos: DayLo
PostPosted: Mon Apr 10, 2023 7:57 am    Post subject: Steering is very stiff left and ok to right. Autopilot stall Reply with quote
I have a Venture 26 with Garmin autopilot and GPH 10 pump.
I was using it for the first time this weekend. My autopilot often says hydraulic pump stall. I noticed the boat is hard to steer left/port and right is much easier. It been this way in my past boat with hydraulic steering and higher horsepower boats. I think the pump is stalling due to being stiff to steer. It will often go off course then abruptly steer to get back on course. Like it sticks then get free and over corrects. I spend a lot of time wondering way off course.
I used to have a Cutwater C30 with a 10' beam. The GPH pump was sort of under sized in past conversations, but never stalled. I didn't care for it much.
I'm at work, but what should I check this week when I get home?
1) Fluid level.
2) Possible bleed it.
3) ?
4) ?
5) ?
Only my Cutwater, I contemplated upgrading the pump $$ but never got around to it.
2018 C-Dory Venture 26. Suzuki DF200A,autopilot, solar, 412ahr of lithium.
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Mon Apr 10, 2023 9:29 am    Post subject: Reply with quote
Disconnect the steering ram from the motor and see if the motor binds when moving it by hand. Then turn the wheel with it disconnected and see if it binds or is free. The only time my Garmin stalls is when it reaches the end of the cylinder.
Jody Kidd
KE7WNG
Northern, Utah
PostPosted: Mon Apr 10, 2023 9:54 am    Post subject: Reply with quote
I assume you do not have a second helm. My 25 steered much stiffer than my 22, but pretty much in both directions. My replies from Seastar pretty much fell upon, it's hydraulic steering, not power steering. BTW, I also have a cockpit helm, so two steering stations plus the autopilot pump. I replaced all my lines and put tees for the cockpit helm and autopilot pump close to them, rather than teeing at the helms. Steering seems to be a little easier, but still stiffer than the 22 was. Perhaps longer hose runs? Before changing out all the hoses, perhaps I had some kinks where the fittings were installed? I also replaced the steering line/bar between my main and kicker. I agree with Jody, first disconnect the steering ram at the outboard and see if it turns any easier. Also, in my case, having both regular seastar helms (as opposed to their pro helms), the helms bled through each other, especially if turning the cabin helm to starboard. I rectified that issue by installing shutoff valves at my cockpit helm. Colby
PostPosted: Mon Apr 10, 2023 12:38 pm    Post subject: Reply with quote
Excellent suggestions above. Also you don't know what fluid has been used in the past. At 5 years, the hydraulic system should be drained, and then replaced with the proper mil spec fluid. I buy mine on line. Or you may buy some at any fixed base recreational aircraft repair shops. Do not mix in transmission fluid, brake fluid etc. (in an emergency you can use Dexron II transmission fluid). Only the Mil spec equivalent of the Sea Star should be used on the refill:
H5606 Mil Spec: Texaco: HO15; Shell Aero 4; Esso Univis 4; Chevron Aviation fluid A; Mobile Aero HPA; Phillips 66 X/C 5606A There are others, but be sure they meet the Mil Spec.
Also there is a grease fitting on the support/turning tube of the outboard which is often missed, and may have to have all old grease pumped out and new grease pumped in. (I use a Lincoln pneumatic grease gun, set on lower presser, to do this. (You don't want to blow seals with higher pressures).
It is very possible that there could be an issue with seals either the ram, or the helm. There are rebuild kits for these, but be aware that they are pump and cylinder specifically dependent. I have rebuilt both using kits either from my local dealer or on line. One of the toughest jobs often is getting the helm steering wheel off its shaft. I bought a wheel puller which just fit, and made the job much easier. There is a special tool (Pin wrench) , you can make or buy with the kit for the ram seals. I have made several pin wrenches thru the years--not difficult, using flat bar and proper size machine screws threaded thru the holes in flat bar and a nut. I have had to cut out a slot for the shaft. For many it is just easier to buy the proper wrench or an adjustable Pin Wrench.
SeaStar has been purchased by Dometic. The technician has been very active on the Hull truth:
The Marine division can be reached at:
marinetech@dometic.com. or 800.730.4082 Press 3
Boatsteer in North Venice, FL is a reliable parts dealer and rebuilder, if you cannot find the item on line or at local shops.
Finally, what size Auto pilot pump do. you have? I believe that 1.2 liter pump would be the smallest for the ram (up to 14 Cu In.. (The 1 liter pump only up to 10 cu in).
Keep us all in the loop as to what you find.
C-Wolfe
Vessel Name: Valhalla
Photos: C-Wolfe
PostPosted: Mon Apr 10, 2023 12:40 pm    Post subject: Reply with quote
I had issue with very stiff steering on my first use of the boat, it had been sitting for almost a year when I purchased it. I disconnected the ram from the engine as Colby mention and find out the problem was coming from build up on the rod on the hydraulic ram. I clean it up and it solved the issue, work fine after been store during winter month for the next two year. I haven't use it yet this year but I did notice that the steering was stiff again, I disconnected the engines from it and they moving freely, I just need to clean the rod again, haven't done it yet because it's been cold and snowing for the last few days Angry Angry I didn't have auto pilot when I purchase the boat, I do now but have not try using it with a stiff steering.
Stephan
drbridge
Vessel Name: Susan Marie
Photos: Susan Marie
PostPosted: Mon Apr 10, 2023 1:00 pm    Post subject: Reply with quote
Another possible solution could be to adjust the steering trim tab located on bottom side of cavitation plate just above the prop. This can make a big difference in how a boat steers. If it is adjusted to far to one side it could be overloading the pump. Make very small adjustments to this until you get it balanced as it is very sensitive
Also, There could be air in the hydraulic lines that needs to be bled out. This can also effect steering and especially an auto pilot pump and controls.
If you do need to remove the steering wheel here is a tip that an auto mechanic buddy of mine gave me years ago. "Loosen the steering wheel nut just a couple of turns. Grab the wheel firmly and while pulling on it hard, flex it back and forth from side to side until it pops loose." I haven't found a steering wheel yet that this does not work on including our C-Dory 22. Don't forget to leave the nut on the shaft until you get it to break loose or you could hurt yourself when it does.
Doug & Susan
serpa4
C-Dory Year: 2018
Vessel Name: DayLo
Photos: DayLo
PostPosted: Mon Apr 10, 2023 2:48 pm    Post subject: Reply with quote
Thanks all. On the note about the trim tab. Mine is pointing to starboard as viewed from behind the motor.
serpa4
C-Dory Year: 2018
Vessel Name: DayLo
Photos: DayLo
PostPosted: Sun Apr 16, 2023 7:03 pm    Post subject: Reply with quote
Actually its pointed to port. This should make it steer to port right? It's not much to port, just a little. I think I'll try more.
I topped offthe helm with fluid but not much.
Greased all fittings.
I could not get the single bolt off of the steering arm. It threads in from underneath and thus no room to pulling from underneath.
I can turn the wheel out of the water on the trailer equally both directions with 2 fingers.
PostPosted: Sun Apr 16, 2023 7:07 pm    Post subject: Reply with quote
serpa4 wrote:
Actuaits pointed to port. This should make it steer to port right?
If your tab is facing port, then it is pushing the outboard starboard when going thru the water. You said it turns harder going left. Is this when on plane or at hull speed? If at hull speed, then it makes sense that your trim tab is not set correctly. That would also be confirmed by the steering being much easier on the trailer.
PostPosted: Sun Apr 16, 2023 7:25 pm    Post subject: Reply with quote
At hull speed the tab will have little effect (at least on my Honda 90). It will be much more noticeable at speed. The offset direction of the tab depends on the direction of rotation of the prop. The tab counters the torque effect of the prop.
serpa4
C-Dory Year: 2018
Vessel Name: DayLo
Photos: DayLo
PostPosted: Sun Apr 16, 2023 7:32 pm    Post subject: Reply with quote
[quote="colbysmith"]
The tab is pointing to port. This would pull the back of the motor to port, thus steering the boat to port...correct?
It is very stiff to steer to port, and easier to steer to the starboard at curise 20-25mph. At hull speed, its easy to steer either direction.
I every outbord I've had steers easy till you go fasters then it becomes harder to steer.
PostPosted: Sun Apr 16, 2023 8:22 pm    Post subject: Reply with quote
[quote="serpa4"]
First, quickly, I need to correct a typo in my last response. I meant to say if the engine is harder to steer on plane (vs. Hull speed), then it's an improper tab setting. If your outboard trim tab is set to the port, then follow the water flow over it, it will be pushing your outboard to steer starboard. Thus why at faster speeds, the motor becomes much harder to steer to port. Everything you are saying above leads me to believe that your trim tab is incorrectly set. It shouldn't be more than a few degrees off center. Colby
serpa4
C-Dory Year: 2018
Vessel Name: DayLo
Photos: DayLo
PostPosted: Sun Apr 16, 2023 8:59 pm    Post subject: Reply with quote
I think one of us has the direction wrong.
I belive if the tab is pointing to port, it will pull the back of the motor to port which is turning to port also.
If it is hard to steer to port, then it needs to point more to port.
It is already pointing to port...a little.
I have one unknown. I took a picture infront of my house before I pull the tab to install a permatrim. Then the permatrim didn't fit, so I put the tab back. Then this week, I took another picure of the tab in the storage lot. I cannot assess from the pictures if I put it back in the same spot. I've only boated twice and the 1st time was before I moved the trim tab and didn't boat at anything above about 10mph. I only went like 20+ the second time after I pulled the tab and then reinstalled it after the permatri would not fit. Maybe I didn't put it back the same? What do you think?
http://www.c-brats.com/modules.php?full=1&set_albumName=DayLo&id=20230314_185257&op=modload&name=gallery&file=index&include=view_photo.php
http://www.c-brats.com/modules.php?full=1&set_albumName=DayLo&id=20230416_153115&op=modload&name=gallery&file=index&include=view_photo.php
serpa4
C-Dory Year: 2018
Vessel Name: DayLo
Photos: DayLo
PostPosted: Sun Apr 16, 2023 9:03 pm    Post subject: Reply with quote
PostPosted: Sun Apr 16, 2023 9:41 pm    Post subject: Reply with quote
Ok, thanks for the photo. It looks like your trim tab is set to starboard. Think we didn’t understand each other when you said it was pointed to port. In this setup then it should be helping to push the back of the engine to port to turn the boat to port. Not sure then why it’s harder to turn to port unless something else going on.
Page 1 of 3
Page generation time: 0.0501s (PHP: 73% - SQL: 27%) - SQL queries: 28 - GZIP disabled - Debug on
