Wood Zeppelin
C-Dory Year: 1997
Vessel Name: C-Creature
Photos: Childhood Dream
Posted: Tue Mar 28, 2023 2:12 pm Post subject: Nav lights on when motor is running? |
So my navigation lights only seem to come on when the motor is running. With the motor off, and they key in the "on" position, I get power to the dash, etc, but no Nav lighs until I actually turn the key fully clockwise and start and run the motor.
Is that how it's supposed to be?
For example, I'd like to be able to turn the motor off and just float for a few minutes at night without going dark or putting up the anchor light... (?) _________________ James Salay - Real Estate Broker / Investor, Engineer, Artist, Fisherman, Canyoneer, Outdoor Enthusiast
Current boats:
1988 16' Angler - "E-fishn-C" (Project boat)
Also:
14.5' Drift Boat - "Wood Zeppelin" |
Robert H. Wilkinson
Joined: 26 Jan 2011 Posts: 1234 City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
Posted: Tue Mar 28, 2023 3:51 pm Post subject: |
Probably wired to the "run" position because the red/green nav. lights are only supposed to be displayed while a boat is underway. An anchor light may be required but it may depend on your location and the speed of your drift.
Rob _________________ Talk to me and I will listen-- but if its not about boats or fishing all I will hear is bla,bla,bla,yada,yada,zzzzzzzz |
Posted: Tue Mar 28, 2023 11:33 pm Post subject: |
You will have to get. your volt meter out, and find out where the wiring is hooked up. None of my boats have been that way (there the engine had to be running), so someone has changed the factory wiring. It will be very easy for you to change it back, and most likely only will involve a spade connector.
You say "put the anchor light up"? When the red and green navigation lights are one, the all around anchor or steaming light should also be on. A few of the earlier boats had a stern steaming light and forward steaming lights. Is your boat one of these? _________________ Bob Austin
Joined: 27 Oct 2012 Posts: 3372 City/Region: SW Michigan
Posted: Wed Mar 29, 2023 7:01 pm Post subject: |
I think he means going up top and installing the anchor light. Mine is removable, and stored in clips in the berth. It is removed for trailering and storage. I only install it when I know I am going to be out after dark. |
Posted: Wed Mar 29, 2023 7:27 pm Post subject: |
Quote: | An anchor light may be required but it may depend on your location and the speed of your drift. |
The anchor light is required to be on (360* White light visible 2 miles) when anchored. If the boat is not anchored and is drifting, it is considered underway, and the red/green side lites and both bow and stern or 360* steaming lights are required. (Navigation rules 20 thru 23 and 30.). I believe that Canadian inland waters are the same as international and US. |
Wood Zeppelin
C-Dory Year: 1997
Posted: Sat Apr 01, 2023 1:23 am Post subject: |
This raises a really interesting question
My 16' Cruiser only has the red/green Nav light and the "all-around" anchor light.
My 22' Angler has the red/green nav lights, and "all-around" anchor light, and an aft-facing "steaming light". There is no forward facing steaming light.
So now I'm confused. Does this mean both of these boats should be running the anchor light at night so that there is an all-round white light? |
Posted: Sat Apr 01, 2023 11:38 am Post subject: |
Quote: | So now I'm confused. Does this mean both of these boats should be running the anchor light at night so that there is an all-round white light? |
The answer to your question is "yes". Disconnect the aft steaming light if you running with the all around white.
Some of the C Dorys were built with the aft streaming light (135 degrees). The forward/anchor light is in two sectors: Forward steaming:arc of visibility of 225 degrees. When the "navigation lights were "on", the forward light on the "anchor light" (225*) and the aft sector of that white light is off. The fixed light on the back of the cabin house is on and the aft steaming light.
When you turn the "anchor" light on, both bulbs in the white light are on. So if your boat was converted to a single 360 light, the whole wiring for nav and anchor lights may have been changed---or you may still have two bulbs in the anchor/steaming light. Check to see. |
