Boat HP rating
jrslost@aol.com
PostPosted: Thu Mar 02, 2023 8:33 pm    Post subject: Boat HP rating Reply with quote
horsepower rating for a boat. For example, if my boat rating is 150 hp max, is approximately 500 pounds on the transom. if I put dual 75 hp motors for total of 150 hp at 400 pounds each is equal to 800 pounds on the transom. Logic is telling me the rating for the boat would be transom weight, not horsepower. Prove me wrong.
PostPosted: Thu Mar 02, 2023 8:45 pm    Post subject: Reply with quote
There are CD-25s that have 200hp or twin 90s, that came from the factory with that setup. Proof enough?
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Thu Mar 02, 2023 9:19 pm    Post subject: Reply with quote
Factory told me it was weight not HP that mattered.
Jody Kidd
KE7WNG
Northern, Utah
PostPosted: Fri Mar 03, 2023 12:46 pm    Post subject: Reply with quote
Besides the weight, wouldn't higher HP engines put more stress on the transom. Higher thrust=higher torque moment trying to pull the transom off.
jkidd
PostPosted: Fri Mar 03, 2023 3:26 pm    Post subject: Reply with quote
Or does it just move the boat so it can't put any more stress on the transom?
PostPosted: Fri Mar 03, 2023 4:18 pm    Post subject: Reply with quote
On an outboard motor the thrust line is below the bottom of the boat (where the prop is). When the motor is producing thrust this puts a torque on the transom that wants to peal it off from the top. To not have a torque moment, the thrust line (prop) would have to be at the same level as the motor mount to the transom.
jkidd
PostPosted: Fri Mar 03, 2023 6:24 pm    Post subject: Reply with quote
When my boat was built in 2007 the yellow tag said max was 100hp. I ask the factory to mount a Suzuki DF-115 That is when they told me it was weight not HP. In 2021 I had Sportcraft mount a DF-140 on my boat and they called the factory to get approval the factory said it was ok and Sportcraft mounted a motor that was 20 lbs lighter than my 115. I did it because the boat is heavy loaded or used at altitude. For the 22 and 25 the yellow tag is a recommendation not a requirement you can just peel it off and that is what the factory did. They never installed the tag. My insurance company just says what boat and what size motor and sends me a bill. Pretty sure if my policy says what the boat is and what the motor is and the insurance company took my money there is a contract.
While I agree that a larger motor is going to apply more torque to the transom I don't think it would be 100 percent because the boat moves forward. You know for every action there is an equal and opposite reaction. ( Newtons Law ) That being said I seldom run at WOT 20-22 MPH or 16-18 MPH and there is always a little extra in case I need it.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Sun Mar 05, 2023 12:03 am    Post subject: Reply with quote
This gets discussed a lot...never seems to die actually. I honestly don't think about it much as the transoms are very sturdy and well engineered. If you were worried, you can always add in some knees to help support the weight and dynamic loads. I would think the issue and concern is weight more than anything. These boats are pretty light and weight off the back of the stern is probably the worst place you can have it. It will eventually impact handling - no idea what the point of no return is on that, but it's probably about 500-600 pounds like the factory said. I certainly wouldn't have 90s on the back of a CD 22. I suspect those sexy (and light) 70s Yamaha makes are the max - absolutely more power than you need.
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Mon Mar 06, 2023 1:48 pm    Post subject: Reply with quote
One of the many deciding factors, when I chose to go from the Honda twin forty’s to the Honda twin 60’s was C-Brat, Lew of CAT CLAW’s decision to go from twin Honda 35’s to a Honda 115, which the factory was fine with his doing & I think fine with adding a kicker to that. Lew is pleased with the Honda 115, but I noticed it weighed exactly the same as two Honda 60’s at 478 lbs & with the twin 60’s there was no need for the additional weight of 50 to a 100 lbs for a back up kicker.
The sea conditions, myself & others have experienced & shared, show a CD22 is very versatile in handling high weight variances. This inherent ability has been a good part of making some of our more extreme adventures safely possible, while going from absolute boating novices to very experienced, over the last 20 years.
PostPosted: Mon Mar 06, 2023 9:33 pm    Post subject: Reply with quote
Consider the design of the hill has a role in weight. (Broad beam aft& hard chine as examples. Also hull design factors in horsepower. Also construction of the transom.
The layup of the laminate, any stringers or knees tabbed into the transom. Will contribute to both weight & HP.
Transoms have failed with excessive HP.
Page generation time: 0.0417s (PHP: 64% - SQL: 36%) - SQL queries: 23 - GZIP disabled - Debug on
