How to remove Cd Venture 26 or 25 fuel tank?
serpa4
City/Region: Melbourne
C-Dory Year: 2018
Vessel Name: DayLo
Photos: DayLo
PostPosted: Thu Mar 02, 2023 8:31 am    Post subject: How to remove Cd Venture 26 or 25 fuel tank? Reply with quote
I need to access the trim tab to replace it on the starboard side.
I have unbolted the two ears on the tank; one in the front, one on the side by the bilge pump.
I pulled the two platic strips on the floor infront of the tanks.
I have not pulled hoses yet, but I cannot lift or move the tank.
Is it glued down? Is there hiddent ears that hold it down?
I need to empty the tank still, so it's heavy, but I figured I could at least slide it around a tad, but it won't budge.
Maybe I expect 200lbs of fuel to slide around to easy and I need to empty it out. However, is the tank glued down?
2018 C-Dory Venture 26. Suzuki DF200A,autopilot, solar, 412ahr of lithium.
PostPosted: Thu Mar 02, 2023 2:42 pm    Post subject: Reply with quote
On my 22 cruiser, the filler hoses are very effective at keeping the tank in place. They are stiff and there is zero slack.
PostPosted: Thu Mar 02, 2023 5:23 pm    Post subject: Reply with quote
I don't know if your setup is the same, but I pulled the fuel tank out of my CD-25 last year. The hardest part was getting the filler and vent hoses off and on. This is my thread on the job: http://www.c-brats.com/viewtopic.php?t=31093&postdays=0&postorder=asc&start=0&sid=dbce34d844f99431b49873dae1c7d7cd Colby
serpa4
C-Dory Year: 2018
Vessel Name: DayLo
Photos: DayLo
PostPosted: Thu Mar 23, 2023 1:34 pm    Post subject: Reply with quote
Just pulled every drop I could out. Mabye they were too heavy, but the seem to pop loose when empty an dunbolted.
Page generation time: 0.0209s (PHP: 62% - SQL: 38%) - SQL queries: 17 - GZIP disabled - Debug on
