papanui
Posted: Sun Feb 26, 2023 12:42 pm Post subject: 2006 16ft Cruiser bronze keel protection strip |
Hello friends, I’m looking at a 2006 16ft Cruiser and notice it has a bronze keel strip screwed to the outside of the hull as protection during beaching.
Is this a factory install, or an owner mod that may have introduced water into to balsa core?
Thanks for your feedback.
Drew |
Joined: 27 Oct 2012 Posts: 3580 City/Region: SW Michigan
Posted: Sun Feb 26, 2023 1:04 pm Post subject: Re: 2006 16ft Cruiser bronze keel protection strip |
papanui wrote: | Hello friends, I’m looking at a 2006 16ft Cruiser and notice it has a bronze keel strip screwed to the outside of the hull as protection during beaching.
Drew |
That's a factory thing. My 22 has one. It is possible for the installation of the strip to lead to water intrusion. |
Joined: 02 Nov 2003 Posts: 21469 City/Region: Pensacola
Posted: Sun Feb 26, 2023 2:00 pm Post subject: |
The area forward of the helm are is most all of the C Dory monohulls is solid glass, not cored in the bottom. The only way this brass strip (factory installed) can leak is that the pilot holes are drilled too deep, or glass was made thinner. Basically most hulls have good overlap of material from each side in the middle. If they are leaking, then the screws, and strip should be removed. The holes filled with an epoxy and highdenstiy filler, then the strip reinstalled, being very careful not to drill the holes too deep, and using 5200 as the bedding compound.
No way this water intrusion can cause core rot. _________________ Bob Austin
Karl Konecny
Vessel Name: Nowhere Fast
Photos: Nowhere Fast
Posted: Sun Feb 26, 2023 2:43 pm Post subject: |
I have a 2008 22' which has the bronze keel strip but it end forward of the section of the hull that is balsa filled so it should not lead to a water intrusion problem. _________________ "Believe me my young friend, there is nothing-absolutely nothing-half so much worth doing as simply messing around in boats."
Rat to Mole, Wind in the Willows |
srbaum
Joined: 30 Aug 2010 Posts: 909 City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
Posted: Sun Feb 26, 2023 3:15 pm Post subject: |
Drew,
I have seen and help troubleshoot 2 C-Dory's that had water in the bow. Both boats leaked due to factory drilled holes, where the screws for the brass strip was installed.
Your question is not about repair, but in both cases, as mentioned by the previous comments, there was no permanent damage and the repair was simply to oversize drill, then fill the holes with thickened epoxy, then drill to the correct size for the original fasteners, apply a sealant and screw the strip back on. _________________ Steve Baum
Homeport of Portsmouth, VA
